Wiring in a pole shed - Is this code?
78SC4X4
Port Orchard Wa
If you keep the romex up tight against the post you can maintain the 1 1/4" requirement since your girts are 1 1/2" thick. Common practice and I passed inspection with no issues.
loganb
Omaha, NE
If you're worried about it passing an inspection, the only people who you should be asking are the local code officials who will be doing the inspecting.
But it's common practice where I'm at for the reasons mentioned, looping it behind the post is much faster than drilling a 3/4" hole thru a 6 or 8" post
