thr3squared
I am making a switch panel for my truck that will mount under an aftermarket head unit. The mounting hardware will be one M4 screw on either side.
The kicker- the mounting surface is plastic and I only have 0.47” (wide) of surface to work with for the nutserts (or similar) and most I’ve seen need a 1/2” or more. The main reason I wanted to use a nutsert was to make the panel removeable without dismantling the dash if I had a wiring issue.
Any other ideas or suggestions? I thought about epoxying hex nyloc nuts behind the dash instead of an insert. That would hold the screw tight and eliminate the need for a lock washer.
Cheers!
Cheers!
