Have any filled joints ever cracked?
Haven't got a call back for one that did yet.....
Currently on a floor as I type.
In the first pic there are 2 joints, one running vertically and the other horizontal. The vertical "joint" is filled with felt, between the stem wall and the slab. I cut the felt out and fill with Sikaflex SL AFTER the floor is completed.
In the second pic, you see a sawcut joint. I zoomed in so you can see it has already cracked beneath the sawcut, which is supposed to happen. I have already run the grinder over it, softening the 90° edges. This will get filled flush with a "flexible" 100% solids epoxy joint filler. Then the coating system (primer, body coat w/flake, top coat) will be applied over that. This slab was poured in 2005 and I am not worried about it cracking anymore.
That's not to say it cannot happen, but the chances are much less likely on a 17yr old slab. 3rd pic shows what the Sika SL looks like
