30x40 shop concrete advice
vandal
Good day been here for some time but this is my first post and I need some advice.
After many years of delays I have started building my shop. It is a slab on grade 30x40x12 the biggest my township will allow. Currently site prep is done concrete forms are in place and the concrete trucks are booked for next week.
This will be my 4th slab that I have poured so I am not worried about the work involved. However since prices of everything have gone through the roof I do not want to order too much concrete.
Right now concrete is over $300 a yard in my area.
Slab is a 18"x12" thickened edge tapered up at 45 to 6" floor. I calculated the amount need just under 30 yards.
Now I have always order some extra to insure I has the right amount to finish the job, but I have never had the amount of rebar, wire mesh and pex in the slab that I have in this one.
So my question is should I take these items into account when ordering the concrete and not order extra or even order less then the 30 yards?
If ordering less then the 30 yards what is the best way to calculate the volume of the mesh.
600 feet of 5/8" rebar
1160 sq feet of 6x6x6 mesh
1250 feet of 1/2 pex
Thank you
jack stand
Lakes Region Maine
What's the (legal weight) yardage for a maximum load in your state?
Often you can hold the last truck for adjustment after a little jobsite math but 9 yds is the maximum in a lot of areas.
(so you might be into 4 trucks)
A lot of drivers are VERY good at their jobs and once the 3rd truck is placed you and the driver estimate the last load. They never ding me for a short load at the end of several full loads. It's the 2 yd job that gets the minimum charge in my experience.
Have a great pour👍
ConCretin
Central Maine
With all due respect, you are overthinking this. Slight variations in finish and sub grade elevations will make far more difference than the items imbedded in the slab. For example, your rebar will displace .05 cy but a variance of 1/4" in depth results in a difference of 1 cy.
Assuming the slab depth is 12" at the perimeter, I came up with 27 cy for your slab. If my sub grade was decent, I'd order 28 cy and carry on. The consequences of being short are far worse than eating an extra yard of concrete.
Congrats and good luck!
River Runner
Cascade Idaho
Dang, I thought our $225 a yard was astronomical!
I’ve found that rebar or pex makes so little difference it can’t really be factored as volume removed.
Good luck!
Dreamshop
Can you explain this? "tapered up at 45"....
Any benefit to so thick at the edges? Seems a bit overkill.
What PSI you using? Planning a lift?
Thanks
In my area I had to have an engineered slab drawing. They did it exactly like that
eegger
WI
It’s a floating slab, very standard. thicker at the edge supports the weight of the building and locks the slab in place
luvtheheat
Tucson AZ
Eegger, I see you are in Wisconsin. Is this design due to deep frostline in cold climates?
Where I live I've never seen that style.
Following is very common in Southwest. Zero frostline :)
