theoldwizard1
Curbing is code in many places. I would do it.
This is what I want done. Only downfall is I guess I'll loose some internal size unless I have him do a 6" x 6" stem wall
Is that in your quote/plans? Or the second one?That's an engineered slab up here.
Sounds good but you know we wants pictures as the build is going on.We agreed to a 6" curb all the way around. Thanks everyone for the help/advice!
Here ya go:Sounds good but you know we wants pictures as the build is going on.
When my shop was built, I did not think to specify what would be installed, and was very happy with what the contractor installed.
Footings were placed below frostline (about 3' here in SW oHIo), then 8x8x16 blocks placed around the perimeter. There is one course of blocks above grade level, except at the man-door and overhead door locations. The slab was poured inside that a few days later, after plumbing was installed. That gives me an 8" stem wall, which is plenty around here.
Not sure about the interface between the foundation walls and the slab, but there is something there to keep them from floating.
My guy was good, too. We were working off some "artist concept" pictures that I gave him and pretty much said "how much to make it look like this?" The night before framing, I called him to make a change. One wall was supposed to have two windows. My wife thought I would like the extra wall space of ONE window. When I came home from work, there was ONE window framed into that wall.I like this contractor though, he's really easy to work with and pivots easily. At the end I'm sure it'll be more money but hey, while he's here might as well get it done.
It makes up for the mistake they made in the front wall. They framed it with no window. Saw it when I came home from work and called him. When I came home the next day, there was a window.
You've got the wrong concrete guy. He just doesn't want to do the more difficult pour, it's a lot easier to do and slope a simple slab.He says if I want it, it has to be formed and poured after the slab is poured and it would be extra cost to me.
