It's getting colder and I'd like to start building this weekend. Behind on learning the calculations.
The site has 5" of level gravel and corners staked out.
My background is technical but I have zero building design experience. I do have some construction experience.
Shed is 10'8"x 8'. Walls 88.5" tall. 4/12 roof pitch with rafters spanning the long way.
Contents aim to be: push mower, very small riding mower, 2-3x bicycle, generator, garden tools
Wishlist is a vaulted ceiling with no rafter ties and a wide door opening.
I am curious if my framing design is sound.
Local snow load 40lb.
Door opening is 97.5" wide by 75.5" tall.
Floor joists and rafters are 2x6's, 16 on center.
Walls 2x4's, 16 on center.
Ridge beam is (2X) 8' 2x10's with 1/2" ply laminated between. Supported on the ends by 4x4 uprights.
Door header is (2X) 2x12's with the same lamination. Running the length of the long wall.
My 4x4 skids are 62-1/4" on center.
Sitting on leveled patio pavers.
I will box in the floor joists with two boards to cap the ends, instead of how shown.
Should I have more skids?
My floor sheets should run the other way right?
Will it fall down? Is it overbuilt? (Or, what other info is needed?)
Thanks.
Thanks.
