small jack or big tap
ItsNemo
Canada
Even if that's a 2 ton bottle jack, that tap has to be at least 3-4" given the peg hole spacing...might be a tapered tap for pipe?
Dave455
Sussex, England
I see 3 1/2 x 8 UN
That’s 3 1/2“ x 8 t.p.i. Unified.
Part of the 8 t.p.i. “constant pitch” series, designed to be used where the regular UNF, UNC etc are unsuitable.
In this case I believe the 8 tpi series are intended for large diameter / high pressure joints.
If you needed a tap that size, it’s generally going to cost you more than $150…..!
WWheeler
Middleofnowhere USA
Wonder how much a tap handle that fits it is going to cost? Is it a 2 man operation?
I often chuck a tap socket in my drill to make quick easy work of it but I don't see that working with that one.
Lucid Moments
Gainesville, Ga
$150 price tag seems a little odd to me. A tool like that is worth a great deal more than $150 if you need it. But if you don't need it then it is almost worthless. I might pay $10 or $20 as a curiosity, but I can't imagine ever having a need for it so I wouldn't waste more than that.
Sumboodie
AK
We had several in that size when I ran a tool room in the USAF for cleaning threads on fuze wells in mk82 and mk84 bomb bodies.
Walkers
Cave Creek Az
Obviously an optical illusion, the jack is further back on the table!
I used to have to tighten bolts that big every once in a while. The wrenches and sockets are dang big and heavy.
mike93lx
Richmond, VA
I bet a lower offer would get it pretty easily.
