wreckdiver1321
Okay guys, another poll for the GJ Brain Trust.
Underneath my top cabinets and just to the right of my locker-type cabinet will be a workbench. The configuration of that workbench is something I've been trying to noodle out for a while now.
OPTION A
Do I do a Steevo bench and have more bench top to do work? Bear in mind I already have a 78x26 bench which will be essentially next to this one. The benefits of the Steevo bench are that I technically get more storage and it'll probably look a little less cluttered. A set of 46" Husky rolling benches would give me about 94" of bench, or just shy of 8 feet, then below I'd have tons of storage for tools. Downside is I'd have to bend over to grab everything, and to be honest I prefer the aesthetic of a tool chest stack. My buddy did say that bench tops have a bad habit of being a junk collection point, which is true, but I generally keep my benches clean. Plus the complexity of building the thing makes it a little less attractive. Not that I wouldn't be able to or don't want to, but it's another project to complete while I already have enough irons in the fire. Cost is about the same to be honest, so that's not a factor.
I'd buy a set of two of these roller benches, then build a frame from wood or steel to surround them.
OPTION B
The other option is a shorter workbench with a narrower stack of tool chests. The bench would be roughly 67" and I'd very likely go with Craftsman's 41" set. I think I prefer this from an aesthetics point of view frankly, and having a bench with shelving under it would be a pretty good place to store the table saw, in theory. It wouldn't be hard to box in a regular bench and make it a cabinet too, thus making even more storage. However, this is not without problems. The upright tool chest would be less storage, primarily because of depth. My main workbench is 23" away from the wall, so a 22" or 24" deep tool chest would make it feel crowded and not a good fit. That leaves either the 41" Craftsman or the 36" Husky box, which are both 18" deep.
I don't like the idea of the Husky much, because the upper drawers in the lower box aren't deep enough to keep sockets in, so I'd have to keep them up top. Doable, but I prefer the sockets in a drawer near waist-level since they're easier to dig through. The Craftsman set has it's limitations too, because of the drawer layout and the overall height. You'll notice the standard 41" set does not have a full-width drawer, which I think it it's biggest drawback. That means sockets would likely need to be spread out amongst two drawers, and guess what? The lower box's top drawers aren't deep enough for 1/2" drive deep sockets. I could put them in the top storage till, but that exposes another potential issue: height. The height is an issue because I have essentially stuck myself with a 73" max height, since the box will be under the cabinets. In order to fully open the Craftsman box top till, you need 78" of clearance, so I'd never be able to fully open it. I could take the cover off, but then I'd have dusty sockets all the time. Not the end of the world, but not necessarily ideal either.
I could use this rolling bench thingy, because it's about 3 inches shorter and it has a full-width top drawer that is more than deep enough to store sockets. Perfect, right? Well, Craftsman doesn't recommend you put a full chest on top of it. I'm not entirely sure why, I might check into how they're built compared to the standard bottom box. So I either ignore Craftsman or put a 26" box on top, which wouldn't be my favorite option. Another possible issue here is the drawer layout. While the upper drawer is great for my sockets and stuff, everything else is hot garbage.
Everybody's thoughts?
OPTION A
OPTION B
