Parts washer solvent?
bowtiebuba
marion iowa
Whats a good parts washer solvent? ive got a snap on parts washer, but im looking for a good cheap if possible and easy to get solvent from a parts store or something? Im not intrested in useing diesel kerosene
Bull
How cheap do you need it to be?
When I had a parts washer while working on a couple old Pontiacs, I used Simple Green, full-strength. Might also consider Zep orange citrus degreaser, which I have used on heavily greased tools with good results. Both of these can be had from Home Depot for $10 per gallon or less.
Eldogg
Gainesville,GA / Mooresville,NC
I use mineral spirits in mine too. I buy mine a the local fuel/oil distributor.(Harrison Oil) 1/2 the price of Home Depot/Lowes. The secret additive is a quart of ATF for every 10 gal. of mineral spirits. ATF lubes the pump and it won't dry your hands out as fast.
GTO
NJ,FL
In before "we can't buy that stuff here in CA" people.
HD has the large containers of ZEP IIRC,simple green too.
saabman
Sebago Lake, Maine
I used to use "Super Agitane" (sp?) but it is now outlawed in Maine, so now I use "Oil Eater" The latter is more of a strong soap, the former while water based was more of a witches brew.
JohnFreeman
central nc
I pick solvents and chemicals by whether they're banned in California (if so, it generally means the stuff is effective). Might have to add Maine to the list it seems.
Davefr
OR
Isn't that the truth. I also avoid any label that includes "Eco" or "Green". That also means the product is ineffective.
A good homemade solvent is Ed's Red. It's equal parts of Acetone, ATF, Kerosene and mineral spirits.
Another good alternative is Coleman Fuel. It's Naptha or white gas. I find it at garage sales all the time for about $.25/gallon. No one seems to be into gas powered camping appliances these days so the fuel goes cheap.
Strouty
Southern Maine
Since when has that stopped us before? I just tried simple green, 50/50 mixed, it has a pretty overwhelming odor and I can "feel" it in my eyes. I have a 30x60x12 tall shop, if I go away for a couple of days after using the parts washer, it smells pretty strong. Maybe I am a wimp, but I have used kerosine before and it did not bug me like the simple green does.
Vinko
Los Angeles
You can buy it, sometimes, just can't use it for certain applications. And lest we condemn all of the Golden State, it's Southern California that has, afaik, the worst of the laws.
cglasgow
I've been using Zep's equivalent of Purple stuff (unheated) and have been pretty disappointed. It doesn't clean well and my parts washer is getting rusty. It's a Northern Hydraulics washer about 3 years old and the manual said "Do not use solvent-based cleaners!" The pump manual that came with it showed the pump being installed in a koi pond or something.
Anyone using a solvent-based cleaner in something like this? Would it destroy the pump and/or be a fire hazard?
Cheers!
Falcon67
Merkel, TX
Mine has 10 gal mineral spirits and a quart of ATF. I need to refresh it, bet what's left in there is most excellent weed and fire ant killer...
BlindViper
York, PA
I use the stuff from tractor supply. Its called psc 1000 its 39$ for 5 gallons. It works just like the zep stuff and has a high flash point.
nate379
Palmer, AK
10 mins of use and there is more than enough lube in there. I don't see why you would add more! They make distillers to clean the oil out even!
fomocoforrester
+1 on using plain mineral spirits.
and +1 on not adding any lube. You should be using gloves anyway...:)
Kent763
Why would anyone use acetone considering how quickly it evaporates off?
vdubnluvn
winston salem nc
i get mineral spirits off the local chemical guys. it tends to fall off the truck. 7 gallons for $20. :shocking:
i have found nothing better cept ol skool varsol, but i cant find it anymore.
nate379
Palmer, AK
The one guy that is using gas/white gas, etc... I would be careful of that stuff!
Mineral Spirits has a flash point more like diesel... IE you can pretty much smoke while using the stuff.
20 gals of gas in an open container?? :wtf: Forget the lid open and send some sparks that way from the grinder or welder... you won't be posting on here anymore!
For sure on the gloves. The stuff I use is Stoddard Solvent and it will BURN your skin if you don't use gloves. It slowly melts nitrile gloves to, just like brake cleaner does.
scooterseats
Gloves are a must and the ones passed the wrist are even better
Pure Kerosene is soothing to the skin and actually seems to reduce the pain and soreness or nicks and small cuts. Remember our ancestors routinely used Kerosene (Coal Oil) for antiseptic purposes.
nate379
Palmer, AK
Problem with Kero/diesel is it doesn't leave the part oil free. Plus the smells is a ***** to get off you! Spill a little on your pants and everything in that load of laundry will smell like it.
With mineral spirits you can pull it out of the parts washer, blow it off, and paint it.
AJ1978
Jamestown, PA
Here is what I did. I asked this question about a month ago. I bought the PSC1000 at Tractor Supply for 39.99 for 5 gallons. I got 10 gal of it. It worked good, a little hard on the skin tho. I had passed up some "stoddard kensolv 30" at my local fuel supplier. I went and got 5 gal of that, cheaper yet. In the end the PSC1000 from Tractor Supply was a good deal. But out there in IOWA you are sure to have some fuel suppliers, see if they have a stoddard solvent, they are reasonable priced and clean well.
I cannot stand simple green's odor.
Anything that is real heavy i try to clean with PURPLE POWER, and water, either in a tub, or with Pressure washer. Purple power works great on engine blocks, and heads, spray let sit, and hit with the 2500 3 GPM prx washer. Works great
