insane 15amp receptacle
David0858
Tx
That there is a mobile home receptacle and one of the many reasons I won't set foot inside a trailer house. I admit to not watching the video.
I've had two mobile homes over the years including the one I have now and both have regular plugs, switches and boxes. I've also worked on others and I've never seen anything like that.
wyliesdiesels
Modesto, CA
I know that you must have seen UL listed devices that are total POS's. IMHO this receptacle falls into that category. We can discuss skin effect and other attributes of how current is carried, but I do not trust that type of connection for this application.
Cost reduction has it's place, but not here.
It's not a receptacle. There is no skin effect @ 60Hz under 8.3mm. #12 is 2.1mm
which is between 1/0 and 2/0.... lot larger than #12
Wiz02
Southeastern PA
I beg to differ. Whenever AC current is running through a wire, there a skin effect at 60 hz so the connection needs to account for the fact that the current is in the skin, which is about 8mm as you said.
At the connection point of the wire to the receptacle, you are relying on the spring tension of that punch down connector to make contact with sufficient force to handle the current.load. In addition, the top of the wire isn't making contact, so you have a little more than 1/2 the wire diameter available for the connection, plus springs lose tension after being exposed to vibration and heat cycles. Perfect for RV use - Not!
Mzungu
Fixed a few of those in RV's. Have never seen them used in a mobile home up here. Even in the old 2x3 walled mobile homes they used shallow boxes and normal receptacles.
Joemctag
Outside raleigh nc
Cause I've had backstab fixtures catch fire or melt down, but never punchdowns. The punchdowns dig into the conductor on two sides, the backstabs barely graze it. Again, this is assuming it was done correctly. I still prefer screwed or clamped.
Gotta say I agree. Seen lotsa back-stabs quit working, which, to me, says that , as they changed from good, solid contact to none, there was a point where they could have heated up and been a hazard.
Not much experience with the MH punchdowns, but , to me, also, they look ok. Cheap, but ok.
I’m not a professional electrician.
