I’m looking at buying a sandblaster and sandblast cabinet. Mostly for small machine tool and bicycle/motorcycle restoration. I’m looking at buying a 36” wide x 24” deep x 24” tall blast cabinet. Most of what I sandblast will fit in that size, with the occasional machine stand or tool box. Most of what I hear quoted is needing 20 CFM for sand blasting. It seems the 5 HP 2 stage compressors are rated at 15-17 CFM and roughly 17-19 CFM at 100 PSI.
Who has experience sandblasting with a 5 HP 2 stage compressor, is it a sufficient amount or should I go with a 7.5 HP?
I realize bigger is always better, but I need to draw the line somewhere and even the 5 HP compressor on a 40 amp circuit seems like a lot in my 2 car garage. But this is going to be the last compressor I’m going to buy so if it needs to be 7.5 HP then that’s what I’ll make work.
I’m looking at this Eaton Polar Air quiet series.
eatoncompressor.com
5HP Single Phase Vertical Silent Air System 80 Gal|Polar Air by Eaton Compressor
Eaton Compressor carries an impressive line of quiet air compressors, including this single phase 5 HP Quiet Air Compressor with 80 Gallon Tank.
