Jeeper75
Picked up this vise knowing it had some sort of thread issue. Well it looks like someone torched a hole in the back slide for some reason and bunged up the threads behind the nut. Well only way to do anything is to get it open. Forced it all the way and you can see the results. Thinking about cutting the threaded portion of the spindle off and welding a steel acme rod to the smooth section. And making a new spindle nut with a coupler nut and some mild steel to form the rest. Is the spindle shaft steel or cast? Am I even going to be able to weld it together? Or make a new meatball of some sort and weld the steel acme to that. Wont look original but it will at least be useable.
