atikovi
First time I've heard of Capri Tools and was looking around for these stubby impact wrenches. Both drive sizes from each manufacturer looks the same as the other and both the Astros say Max Torque: 400ft.lbs while on the Capri, the 3/8 drive shows 220 ft. lbs. Any idea why it's rated less if it has the same internals and is physically the same? Is the Capri worth the $100-$125 extra over the Astro?
Capri 1/2 inch drive 400 ft. lbs of maximum reverse torque
capritools.com
Capri 3/8 inch drive 220 ft. lbs of maximum reverse torque
capritools.com
Astro 1/2 inch drive 400ft.lbs MAX torque
www.astrotools.com
Astro 3/8 inch drive Max Torque: 400ft.lbs
www.astrotools.com
1/2" Drive Flex-Head Angle Impact Wrench
The Capri Tools 1/2″ Flex-Head Angle Impact Wrench has a 120-degree flexible head and ultra-compact form factor with a low air consumption.
capritools.com
3/8" Drive Flex-Head Angle Impact Wrench
The Capri Tools 3/8″ Flex-Head Angle Impact Wrench has a 120-degree flexible head which is tilt able up to 60 degrees forward and up to 60 degrees backward.
capritools.com
1/2" Nano Flex-Head Angle Impact Wrench | Astro Pneumatic Tools
An industry first true flex-head impact wrench and with our shortest length yet at 3.34" Patented design features innovative dual air intake motor and ...
3/8" Nano Flex-Head Angle Impact Wrench - 400ft/lb | Astro Pneumatic Tools
• An industry first true flex-head impact wrench and with our shortest length yet at 3.34" • Patented design features innovative dual air intake motor ...
