Hello all,
Question that is often covered but I may have a spin on the usual situation thanks to some "flippers" who touched our home before purchasing.
Thankfully - the flip itself was very light, so we haven't had to redo too many things... but take a look at this garage.
Note: I am aware it is a crusty old garage, I am not in the position to rebuild it or just build a new one. The flippers also only worked on the house for about 3 weeks total, simple in/out paint of the house, threw a new kitchen in (it appears they literally did) and "secured" the garage.
Issue: Garage roof sagging, side walls bowing... however, the flipper reinforced BUT apparently did NOT attempt to straighten anything. They just added some support to stop movement.
Question: Do any of you think this is safe/sufficient to stop the collapse of the garage as we use it for our car. Or if its sketchy, should I remove what they put up, attempt the straighten and THEN re-secure it?
I had wanted to replace the garage windows, fix wood siding and just overall garage cleanup... house is really nice, garage...not so much.
Pics below (don't mind the crooked chimney - there was an 1950's gas furnace I removed and that pipe is disconnected)
Thank you!
Thank you!
