Subaru Ball Joint Separator Question
NHtoolguy
Gilford, NH
Hi everyone! I needed to separate the front left ball joint on a 2010 Subaru Forester to replace the axle. I wanted to reuse the ball joint, so I had to use a tool that would push the stud taper out of the lower control arm and not damage the boot. After trying multiple puller types that didn't grip the arm, I wound up trying an old style one-piece pitman arm puller. It straddled the arm fairly well and the forcing screw aligned with the stud. I had to really crank on it and when the taper let go, it sounded like a gunshot. Is there a factory tool for this job? What do Subaru techs use to separate ball joints? The lower control arm narrows toward the ball joint end, and there isn't much of a lip to grab. Thanks for any input.
2ndGearRubber
Pittsburgh
Don't separate the ball joint to swap an axle. Remove the strut bolts and pry the arm down, it will just barely fit out. Mark the strut bolts with a paint pen or similar in case someone added cam eccentric bolts to set the camber. Removing the sway bar link will help you pry down easier, although standing at chest height with the suspension hanging I have enough leverage to do it by hand with the link connected and I'm not particularly strong. Pull the knuckle forward and down, bend the outer axle joint to one extreme, slip it out.
In my world, if that ball joint needs separated, it's getting replaced. Between the rotten cotter pins, small threads, and low cost of replacement I don't bother saving them.
tamaraw
Could you show a picture of the ball joint in question and how it is mounted?
I use this on my Honda, it's also sold under many different names:
And there is the C-clamp type tool and a few with a jackscrew similar to the link but no lever action.
I know some people will also tap the side of the control arm where the stud fits to jar it loose while force is simultaneously applied pushing the stud out.
mrvm
PA
Here’s a pic of the BJ in the front LCA. In my case the LCA was being replaced and banged out of the knuckle.39F03825-9D76-4DAD-816E-188F063551DF.jpeg
Kent_B
MI
Pinch bolts in the knuckle can also be troublesome. Without heat, that bolt is likely to break and sometimes even with heat.
Mr_B
Reading
If do the strut bolts the top bolt is camber concentric as standard so note the position .
easiest way pop the joint stud out of lower arm is load the joint with pry bar or chisel wedge and give it few love taps with the air hammer .
No need buy the BJ removal pullers (although astro is dirt cheap) as can make your own from couple nuts and long full thread bolt or bit of threaded bar and use some sleeves from a bush/bearing kit , I made a puller from a 8.8 grade full thread m16 bolt and m16 nut welded to old wheel nut that same m10x1.25 thread as BJ stud, you can carefully tap a chisel in knuckle split to open joint a fraction to ease removal/fitting (never cracked one yet and never will unless go gorilla on it) upgraded that tool so nut on m16 threaded rod runs on tapered bearing from some euro trash rear hub so less effort in using it, done lot of ball joints with that tool quick and easy .
Pinch bolts ****, if no heat, air hammer bold both end, spray penetrating oil and rattle bolt with air wrench turned down a notch so not going bust head off and keep rattling it few seconds forward and back and in time it may start move a little and then you add more oil and up the wrench power once moving well .
vssjim
McLean Va.
https://www.gearwrench.com/products...ve-train/3916d-universal-ball-joint-separator I use this tool and have for years on lots of cars
joe_pinehill1
Northern Virginia
I've owned 3 Subarus and live in the Northeast. If you have not done the ball joints on a 2010, they probably should be replaced. I use a Harbor Freight separator that I have grinded in some areas to fit better, pops them right off.
Rusted Ball joints are a pain in the neck to remove from the spindle if you are replacing the joint. First on a 2020 the pinch bolt will probably snap, then if you drill the bolt out, you still have to get the ball joint out. On hard ball joints, I buy a new knuckle, its save so much time, its worth the $100.
N
NHtoolguy
Gilford, NH
Thanks for all the input guys. I'll investigate alternate separators as suggested. I wanted to save the ball joint since it had been replaced recently. Interestingly, my Haynes manual recommended removing the lower ball joint for an axle replacement. Once the taper popped loose and I disconnected the sway bar link (also recently replaced), the knuckle swung out of the way and the axle slipped right out. I did install a new castle nut and cotter pin.
Outahere
Idaho
...The OEMTOOLS 25112 Ball Joint Separator tool separates ball joints from the spindle support arm on most newer domestic and import front wheel drive vehicles. Unlike other ball joint tool remover methods like hammering in a pickle fork, this tool allows for the removal of the ball joint without damaging the rubber boot. Many automotive tools can remove a ball joint with some effort and risk, but this ball joint puller tool is ideal when you need to re-use the ball joint after removing it...
2ndGearRubber
Pittsburgh
You DO NOT want to push on a subaru lower ball joint with that type of tool. The ball joints, factory design anyways, have a double keyway for a cotter pin. Pushing upward on it will crush in the threads. Even with a "air hammer nut" from assenmacher or similar, the end of the joint wants to just crush inwards. Not fun to fix, the "easiest" method is simply replacing the joint afterwards. You can grind the end flat and use a split-die in a pinch, but that's way above the level most are capable of doing.
Separate the arm from the ball joint, not the ball joint from the arm. You can beat that stamped steel arm all day with no consequences.
