Maxcustody
Keeping and rebuilding older equipment seems like the best bet nowadays.................. The last several years even the higher end stuff that is new is still not built as well as it's predecessor.
Keeping and rebuilding older equipment seems like the best bet nowadays.................. The last several years even the higher end stuff that is new is still not built as well as it's predecessor.![]()
Brilliant save on the carb!
I like that tap guide! I want one. Link?
-larry
I have the same guide and I really like it.
Funny you should say this. We have a piece of equipment at work that requires a go/no go gauge setup. After a few guys couldn’t remember which was which I painted them green and red. Works perfect nowHuh, I would have thought your OCD would be all over red for NOGO and green for GO.
Ah man. See Mike, the thing is you do it to yourself lol.
Now I have to ask… what is that RPM meter (?) and how do you perform that particular calibration?
Haha. “It” would be putting a bow on a current post that already had a ton of informative detail…just to add a hook right there at the end that compels us to ask more questions; ergo, if you thought you were gonna get a break from teaching shop class you were wrong haha!I have to ask John, what is it that I do to myself? You'll have to be more specific as I feel the list is long.
As for the meter, it is an analog Strandix RPM meter. I've had it for a long time and it works well and is extremely reliable and repeatable. That being said, I also have a digital Oregon meter that I use as well but I seem to reach for the Strandix more often.
I haven't seen the prices in quite some time so I am a bit shocked when I Googled it just now.
Much thanks again. I’ll be picking those tools up for my Dad. Now that he’s retired he’s really enjoying small engine repair as a hobby. He’s doing good with a basic set of tools, but specialty tools would really make his day.
I love the RPM meter to set the idle on a weed whacker! Attention to detail at it's finest!
I'll never forget being a kid and hanging around my uncle's construction business. I vividly remember working on an old water truck with him. We got done and he went to set the idle; he held a paper plate next to the exhaust and watched the way the plate fluttered and made his adjustments accordingly.
Can someone explain the paper plate trick?
Okay, this is for Ryan but will more than likely answer your question as well Ohmthis.
I originally thought this was a Tecumseh tach but when I pulled it out of my toolbox last night I remember it was actually a Briggs & Stratton, however, I think Tecumseh markets the exact same one just branded differently.
The theory of operation is the you put it on anything that rotates and it will produce vibrations/harmonics which correlate through to the pointer and indicate on the dial chart the RPM. It works amazingly well and is quite accurate. I have used this for not only IC engines, but also electric motors as I had one in my toolbox at work as well.
You simply place the outer ring (body) firmly on the motor or engine, then turn the inner ring which is attached to the wire and as the wire extends from the dial, the point at which it the wrapped end swings the largest arc is max RPM, then you simply read the corresponding range on the dial chart.
I am assuming the paper plate method is similar but you'd need a point of reference. I have heard of the trick from a few old-timers but never used it myself so Ryan may have to expand on it.
my son picked up a FS80 a few months ago, only fired up one time and didn't run but for a few seconds. The other day I ordered a $15 ebay carb, and it came with all new lines, fuel filter, air filter, gaskets , and a spark plug. 15 minutes later it was running as good as new. I'm not sure how long it will last vs. the original carb but was pretty impressed for the $15 i have in it.
Mike,Thanks John. I don't claim to be a teacher by any stretch of the word but I do enjoy documenting my projects and even doing videos of them in my shop. But I wouldn't call myself a teacher. I just see so many incorrect ways of doing things online that I try to encourage people that doing it the right way isn't that much more work and that they can be so much more fulfilled knowing it was done correctly.
Please don't get me wrong, I don't know everything, far from it in fact. That's why I spend the time here, to learn from all of the smart people on this forum just as much as I hope others are able to pick up something from one of my posts.
As for tools for your dad, have you considered a small assortment of carburetor screwdrivers? They can be had for a relatively small amount but on many of these small engines these days I have been seeing a wide range of odd screws on carburetors. Everything from double D heads to 21-spline and several others. It seems as though they are doing everything possible to encourage people not to work on these without investing in some tools. Just a thought as they are a necessity when working on these small engine carburetors.
Thanks again for the kind words.
Mike,
The best teachers are the ones we learn from and they weren’t even trying. That’s a “natural teacher” and you qualify even if you don’t have a syllabus lol.
Yes sir, after looking up your Walbro kit, I noticed several links to small screwdriver assortments from Stihl and a few others. I’ll be buying a set for each of us.
Thanks for posting your other small engine tools too.
It seems like you have a tool for everything. On every project you tackle you introduce me to a few new tools that I then instandly want. That's leading to issues as my garage is way smaller then yours.
That spray can holder is better than the original................well done Mike!
Really like the aerosol can holder Mike, and I'm selfishly glad that you weren't able to source one for purchase so that we could "watch" you build one! I'm sure that your son is stoked to have access to your empire and to spend time with his dad. I was doing some mechanic-ing just last night in the cold and gravel driveway, and while I'm grateful to have my shop and all the tools within, having access to a shop big enough to pull a vehicle inside would be a big upgrade! I hope you have a great week!
Kind of surprised you don't use a trickle charger, I use them on my cars that sit for a bit over winter, no need for the large charger and small form factor. They also put a small load on them and condition the battery also.Saturday morning my son was bringing his wife's Subaru over to address an issue with the struts so I thought I'd roll the cover back a little on the Camaro and toss the charger on for a few hours. It's been a couple of weeks since we drove the car and although I'm sure I will put a new battery in it in the spring, I want to get through the winter months with the battery in the event we are able to take it for a drive or 10 on nice weekend days.
Stay tuned for the completion of the tray and Saturday's work.
I'm with GNR96WS6, I use a Battery Tender on my Cobra and Viper as they sit a lot over winter, I need to pick up another for the mower battery as well, but is great to know when I walk out all will be ready to start.
JB
Jeep maintenance is another fun way to spend time with the Jeep!
Look into the Ctek chargers Mike. You can buy panel mounts and such to make a remote plug for the charger. I have one for everything that uses a battery, snowmobiles, quad, trailer, car, truck, etc. Never have to worry about a dead battery from sitting and keeps them lasting a lot longer too.I let me last Battery Tender go with my bike. I have my large MAC (made by Schumacher) that I throw on it as well as the battery out of my zero turn mower on occasion. I also have a small Schumacher charger but it is up on the mezzanine in the house garage and I didn't feel like grabbing it so I tossed the large one on the car in low amp mode.
