What do I own?
Buddro
I have been looking for a restoration project to kill a little time. The other day working on cleaning up someones shop I was given a this. Obviously its some form of clutch/gear reducer but I don't know exactly what it is or if I can find any use for it. At any rate cleaning it up will give me a little practice until I can find a good deal on something I need.
Thanks.
Buddro
That was what it was suggested as when it was given to me. It would make since that it would be an integral part of a larger machine as it has no markings on it.
Buddro
Lathe counter shaft assembly seems to fit the bill. Now I just have to decide if its applicable to multiple machines or specific to one.
larry_g
oregon
You are correct that it is a lathe counter shaft/clutch assembly. It is for a specific lathe and judging by the balance holes in the big pulley it was for a higher end machine. It can be adapted to other brands.
minke
fly over country
"balance holes" answered my question. Thanks.
Buddro
it goes on an atlas 12 lathe or the craftman copy
I have looked at a few pics, from what I all of the atlas and craftsman lathes I have found have two supports mounted at either end of the axle. This one has single brace in the center of the axle. The guy I got this from has two larger atlas lathes both I believe are complete. I will check them next time I am there to see what kind of countershaft set up they have.
Buddro
Nope, I just happened over an atlas 12 with the same countershaft. Thanks for the help.
