Ohm’s shenanigans
O
Ohmthis
Outside of Louisville KY
I worked on my son’s boat. We mounted the motor to the Jack plate and connected the wiring temporarily just to be able to raise the motor from the floor. My sons went to trim it up………nothing. I jumped it out to get it up and we put things up. I looked at the trim switch and found some really bad wiring. Scotch locks and a wire nut, I wish people would just stay away from wiring sometimes! I cut the **** out and cleaned it up. Soldering Vs Crimping has been discussed ad nauseam, I prefer soldering on a boat. I soldered and shrink wrapped the wires and then secured them. Last picture is of his boat and my work area.
O
Ohmthis
I also got the handy dandy ultrasonic cleaner out and rebuilt the carbs. I love this thing, it does all of the heavy lifting in a short time. I’m waiting on a water pump kit and then we will install and synchronize the carbs. It’s getting close!
O
Ohmthis
And lastly a little update on my F100 (I need a name, but nothing has stuck). I went and picked up my Crown Vic front end today. I’m hoping to start on this soon. Thanks for looking.
O
Ohmthis
Well the wiring bandit strikes again!!! We finished up the engine and we’re ready to crank it over. This is what the battery area looked like. Holy Grounds Batman!!! It didn’t end there. Wire nuts, more extension cord (WTF!), wires spliced multiple times, and changing from gray, to green, then back to gray. I decided to just rip it all out, ok not really! I did take everything apart and figure out what was the person thinking that f’d would his all up. I ran some new wired and cleaned things up. There was a deustch plug that was molested so I replaced that. Here are some pictures.
O
Ohmthis
I found out why the positive wires were so melted. The main positive cable was corroded to the point only a very portion of the wire existed anymore. That got cut out and a new lug crimped on. Here’s one more of the battery area. I added some pictures after the cleanup too. Hope you guys enjoy.
O
Ohmthis
I know it’s been a little while, work this time of the year is crazy busy for me and I was sick on top of that. But, I was still busy in the shop.
I got an old fridge (1940 GE Imperial. I may do a little thread specifically for it when I’m ready) that was converted into a kegerator from my brother in law. He used it for awhile but complained about it tripping the GFI every so often. Eventually it stopped working and his brother and him “attempted to fix it. I got it home and started looking it over. In their attempt to repair it I found wires just hanging out in space. After finding an old schematic the relay/overload was missing. That’s where the wires went to. I ohmed out the windings of the compressor to make sure it wasn’t shorted. I then ohmed the wires to the temp control (essentially a mechanical thermostat) and found that it wouldn’t change states. I opened the temp control and determined it was bad. So I have ordered the temp control and a modern relay/overload. The insulation is in terribly bad shape. That is my guess as to why it would trip the GFI. So I’ll be running new cables also. I’ve added pictures of the wires and their condition as well as the temp control.
O
Ohmthis
My in laws lost a car to the hurricane in Florida this past fall. They bought another one and my free labor was put to work. They bought a nice Ford Edge (I’d really love to keep it for myself, but they know where I live) that needs some maintenance items taken care of and a couple little repairs done. I threw it on the lift and did a drain/fill of the transmission fluid and flushed the brake fluid. I have a vacuum brake bleeder that makes this job pretty easy. The only drawback I see is that I have to put Teflon tape on the bleeder screws to keep air from being pulled in. I checked the brake pads while I had it up also. The underside got a nice once over as well. I like to mark the size of the drain plugs on all the vehicles I maintain. It makes having the correct socket a breeze. I’ll also mark the plastic above the radiator with a grease pencil too.
O
Ohmthis
I put the tires back on and torqued the lugs and checked the air pressure. I also like to check for any pending codes that may be lurking. All was good. Now on the the small repairs.
O
Ohmthis
Which brake bleeder do you have and do you like it ? I’m thinking about picking one up.
thanks
It’s a capri branded vacuum style bleeder. Yes I like it a lot. The one thing that I wish was different (and this may be something all vacuum style have) is that I have to wrap the bleeder screws with Teflon tape (I have read that people have used heavy grease instead) to keep the bleeder from pulling air in.
O
Ohmthis
So the backup camera on the edge was upside down and apparently reverse won’t work without it according to my mother in law 😂. So I did some research and got to work. I got my interior tools out and took the rear panel off. Unbolted the rear trim and got to the camera and its wiring. I was looking for a damaged wire or corroded plug. Once I didn’t find that I figured it was the camera. I took the rear trim piece that held the camera off the lift gate. I removed the fasteners. There is one torx screw that held the bracket for the camera. I swapped out the camera and reversed the process. Plugged it all back together and…….. the car can now go backwards. My pictures aren’t in order, but hopefully you get the idea.
O
Ohmthis
I worked on my old kegerator. I’m debating giving it its own thread. So a little background. My brother in law has had this fridge (1940 GE Imperial) for a decade or more. He tried his hand at brewing beer and used it for the brewing/serving of his own beer. He said that it tripped the GFI several times and finally stopped working. It’s been sitting for awhile and he wanted to get it out of his way. I’ve always loved it and quickly snapped it up.
O
Ohmthis
My Brother in law explained that he and his brother attempted to fix it and I found their “attempt” when I opened it up.
O
Ohmthis
There were parts missing and they are pretty important. The start relay/overload was gone and the schematic (usually on the inside of the access panel) was nowhere to be found. So I grabbed my meter and some colored tape and started making notes. The insulation just crumbled off of the wires and I quickly surmised that was the reason for the tripping GFI.
O
Ohmthis
After finding a drawing online I troubleshot the electrical. The temperature control (really just a mechanical thermostat) was not working. So I ordered a new temp control and a modern start relay/overload.
O
Ohmthis
I wanted to keep the fridge as original as I could. Unfortunately the wiring was not salvageable. Every time I stripped back more of the outer jacket on the cable, the more the insulation crumbled. I got some SOOW cable and replaced the old.
O
Ohmthis
To help with later troubleshooting (even if that’s not me doing it). I color coded the wires. Whether it be a stigma that every green wire is a ground (even though I know electricity doesn’t care what color the wire is) or just that I don’t like it. I put red shrink wrap on the green wire(s). I will also add labels to the cables in the bottom to help prevent confusion later. Here are the wires with new terminals for the temp control.
O
Ohmthis
I installed the new temp control and to my surprise, it bolted right up to the old cover without modification. I did use a unibit to open the hole for the dial a touch.
O
Ohmthis
I ran a new cable to the compressor. I was a little disappointed to see soldered connections at the compressor. Get these too hot and I take the chance of melting the winding insulation. I decided instead to clean the old insulation off of the existing wiring and use several layers of colored heat shrink to insulate. After ohming the windings to find the common, start, and run I needed to change the colors a bit as seen in the last picture. Before closing up the terminal box, I wrapped super 33 tape on the wires and wire nuts. (I didn’t get a picture of that, sorry).
O
Ohmthis
I used a more modern solid state relay/overload. Trying to find a NOS relay was not that hard, but expensive. By design the colors of the relay wires and compressor wires matched. I also changed the line wires to match the wiring colors as well.
O
Ohmthis
I had to lay the fridge on its back to rewire things. It’s not a good idea to stand it right back up and plug them in. The oil used in the refrigerant system has had time to pool and move to where gravity wants to take it. I left it upright overnight and let gravity do its thing. I plugged it in, set the temp control, and…………….. Success………..for a little bit. As I was inspecting things the relay is pretty damn hot. It’s rated to 1/3 hp. A lot of the compressor nameplate is faded. It does have the model number. Using my Google Fu I find out it is indeed a 1/2 hp compressor. So I pulled the plug. I have called the supply house and there is a larger relay/overload. I will be picking that up and I think I’ll clean up the wiring and use a terminal block. Picture below is with the door open and the light on, if it doesn’t show up. I’m happy with it and have plans to possibly change the colors. Thanks for following along.
Monza Harry
Windsor ON
Ohm's, I love the styling of your "Vintage" refrigerator, things back then just had more style! As for your wiring job, [related tangent] I recently added an external plug and also a remote control to my "SuperWinch" S4500" So with a little "Google Fu" I found wiring diagrams of all associated parts [P.S. there are a few different colour schematics for the HF/Badlands remote [so yes I had to re-wire a few times & 1 pending as I have it directionally reversed I will repair when I fix the release handle that just gave up and subsequent sandblast & paint/powder coat], but when finished I made a chart and added it to the wiring diagrams, and printed them and they reside where/with I store the winch and accessories as my memory is GREAT! I remember to write the particulars down and try to attach them to said device! I also kept a digital copy. This may come in handy in your future or at least the devices future. Harry
P.S. mogandaves final remarks had me in stiches! :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO: TY!
O
Ohmthis
Yes sir, I printed off the drawing that I found and color coded the wires as well as the labels on the cables. One thing I have left to do write down the part# on the new parts I have used. Thanks for commenting. I agree the styling is what I fell in love with. I like old beautiful things. I just can’t say that to my wife though😂😂😂.
Not only would it get me in trouble, she’s 4years younger so that makes me old too!
Monza Harry
Windsor ON
Sure you can just prep the couch/dog house and or wear a cup. Don't live in fear embrace the wild beasts, and hide the sharp objects/propelled projectiles. Harry
OutlawDrifter
KS
In for the CV front end swap on the '66 F100. My FIL has a LWB '66 F100 with Ranger trim, we have discussed doing this same swap but using a 4.6l mod motor instead.
O
Ohmthis
Outlaw, I’m collecting parts right now and hopefully will be starting that at the beginning of the year. I am going through the process of organizing the job so I don’t waste time when I get started. I think I’m going to start a new thread on the truck and add highlights here. It seems like there will be a lot of info. I have a YouTube channel (Ohmthis) where I strip the factory 5.0 HO EFI harness down and build it as a stand alone harness. That will be used as well as an M5odR2 5 speed from the F150. I think the T5 is a superior transmission, but I hate where the shifter placement is in the cab with it.
O
Ohmthis
It’s been awhile since I added anything new. I work for UPS and Christmas season (we call it Peak) is always crazy. Add to that, I hurt my knee at work and I’m coming back around to feeling better. I’ve got plans, but right now I’m behind on jobs. My son wants to earn money like dad does working on other’s equipment. I got him a “side job” tuning up a 50hp Honda outboard that a client bought to replace a well worn mercury. He’s doing the work with my supervision and earning the cash. He’s 14 and I told him he’ll have more work if he’s fair on his price, does a good job, does the work in a timely fashion, and stands behind his work.
O
Ohmthis
Today we finished up the little outboard engine. Here my son is bolting the lower unit back on after replacing the water pump. I should have gotten more pictures, but I always seem to forget to take them. Until most of the work is done.
O
Ohmthis
So latest project is a feature wall in my wife’s office. She has been asking me to do this for about a year. I love spoiling her, but she has a lot of items on my honey do list and this one was down towards the bottom. So yesterday she informed me that her and a friend would be tackling this project. My wife is a hard worker, but her and tools aren’t very………………I was told if you can’t say anything nice don’t say anything at all.I helped lay out the pattern and her and I ripped the wood and cut an angled bevel on the long vertical pieces. The ladies used a level, Brad nailer, and construction adhesive to mount them. I went off to do another of my projects (I’m framing our basement) when they brought me measurements. Ummmm 4 and 4 lines is??? So I measured their pieces and cut them on the miter saw. Here’s where they left off (my wife and I finished it later tonight) they did a pretty good job!
O
Ohmthis
It’s been a little while, with material prices falling some we decided to go ahead and finish our basement. So I’ve been framing, pulling wire and cable, running rectangular duct and all of the branches, and roughing in the plumbing. I haven’t had much time for any other “jobs”. They are hanging and finishing drywall this week so I need to catch up on some things. My wife volunteered me for some mechanic work. One of her nurses needed a new catalytic converter and I have the lift, the tools, and ability so…….I started off by raising it up and spraying Kroil on all of the fasteners. I let it sit a day and creep in. I used a breaker bar and twisted the fasteners back and forth being careful not to twist too hard and break the bolts. After about 5-6 twist each the nuts loosened up and I was able take them off with my Milwaukee impact.
O
Ohmthis
Once the fasteners were off it was just a twisting and finagling to get the old one out. It sounded like it was full of gravel as I’m guessing the catalyst had broken up. The new converter is in, but I need to change the oil since it’s up on the lift. Then I’ll clear the code and give it a good test drive.
