Mount PEX to concrete walls?
DGersic
DeKalb, IL
Still slowly planning my PEX replumbing project here. Came to something I’m not finding a lot of good ideas for, how to attach PEX to concrete.
I’ll be working in unfinished basement, running a 3/4” trunk with 1/2” drops. If my trunks run in the floor joist space, I need three drops (water softener, washing machine, utility sink) coming down the concrete wall.
Mounting 3/4” wood or plywood with tapcons, then standard mounting clips like these nailed to the wood is one idea.
Another is a small quantity of clips like these, mounted directly with tapcons.
Any other good ideas? I’m not going to frame in or otherwise finish this wall.
Firebrick43
West central Indiana
If multiple pipes or other things might be added, use unistrut. Then you only have to drill holes for two tapcons per unistrut vs 2 per pipe.
Also if hot water is being used and you want to use pipe insulation you can use an insulation clamp. I personally use unisorb klo-shure clamps but there are others. I buy them pretty cheap on ebay.
D
DGersic
DeKalb, IL
I thought about unistrut, but that seemed like overkill. The three drops aren’t next to each other, so I’d either have a lot of unused strut, or a dozen small pieces.
Good point on the insulation. I will insulate the trunk, but probably won’t on these drops. The washing machine and utility sink don’t get a lot of use, figure those drops will get cold anyway. The water softener is cold in and out.
I’ll probably do 3/4” plywood. That’ll also allow for ball valves with mounting ears.
Firebrick43
Is there anything better than overkill on the GJ
jrsavoie
North east Illinois
I'd use stainless hardware. Stuff I installed 25 years ago is rusty
Years ago I had some plastic clips similar to what you have pictured, but the pex just snapped into it.
I've used 1/4" stainless screws for tapcons. I run the tapcon in, pull it out and run the stainless screw in.
Bert_
NW Iowa
Not sure where you are at but if those are exterior walls I wouldn't put the pex right against it. Seen lines freeze that way. Better to stand it off with a board
D
DGersic
DeKalb, IL
Northern Illinois. The current galvanized pipes are on this wall. Never froze. But I don’t want to try to drill a bunch of little holes in concrete, so board or something like it.
D
DGersic
DeKalb, IL
Yeah, there are dozens of styles of clips.
KenC
oklahoma
I'd just use the plastic clips and small tapcons. Just as easy as mounting a board with tapcons, but faster and looks better in my eye.
A good hammer drill can deal with little holes like that just a quick a drilling wood. Mark 'em out and drill all at one time. Probably 5 minutes at most.
