Bmxkelowna
I love all the Tone ratchets, I have quite a few of them, would be nice if they were made in japan but still the quality is excellent and I use them daily!
Yeah Tone is sneaky like that, everything is stamped Japan but never made in Japan. Like you said it doesn't matter because they are still coming out with an excellent quality product!It's funny that everywhere you look Japan is stamped all over them but I hear they're Taiwanese made. It's all good. The quality is there.
Same manufacturer from Taiwan, powerbuilt also has themThis Blackhawk looks familiar.
Home Industrial Tools Official Site | PROTO
Proto Industrial Tools - Safety Obsessedwww.protoindustrial.com
www.jerseydiscounttoolco.com
I purchased a pair of these a few years ago but rarely use them anymore. I find the handles uncomfortable, they don't cut through cardboard nearly as easily as my SK shears, and they are not as precise as my Olfas. They perform both roles adequately, and I keep them in a tool kit in my trunk. I imagine they would also make a nifty accessory for a monster robot Halloween costume.I'd like some feedback/comments from users of the Engineer PH-55 scissors please.
Nice pedicure!
Nice pedicure!
Thanks to your post it peaked my interest and I placed an order for the same impact. I recently stumbled on a video that calls out some differences between the US Makita and the Japan Makita in the chuck and that not all 1/4 drive insets will fit in the Japan Made Makita. Would you be able to comment on that?? ThanksBy far the most exciting tool of Japan I have is my Makita TD172D impact driver, made in Japan (and purchased from Japan). Immediately out of the box the quality is noticeably better compared to the chinese made Makita tools I have. My first performance impressions are A++. I don't know what all power tools you can buy from Japan but I will certainly look for more Japanese Makita in the future. I have only had it for a few days but have used it to drive Tapcons into concrete and it was a dream to use. I plan to use it for light automotive mechanic use for when I don't need the bigger impact wrench but just want something to turn the nut or bolt faster than I can by hand. Can't wait to see what else I can throw at it!
If they do not work in Milwaukee they also likely won't work in Ridgid or Ryobi. If I were you I would just use them in hand tools or in your drills with 3 jaw chucks. Buy the right bits for your power tools.For those double ended Vessel bits are you guys running these in your impacts, screw guns and drills? I came to the realization that the double ends are little too long to allow the retaining balls to lock in these bits into my Milwaukee tools. I have a couple of ball driver handles that work, but was really planning to run these in my power tools.
It seems like my options are to hack off one of the ends or resign them to use in my cordless drills which kind of **** when it comes to screwing.
I responded to your direct message but for the record, to my knowledge, I have found no inserts that don't work with the Japan one. Everything I have tried to put in it fits and locks into place. However, the tool came with a double ended bit and that bit (obviously works in the Japan driver) does NOT work in the Chinese/American driver because it is too long. But so far everything has worked for me. The only obvious difference to the eye in chuck construction is the Japanese chuck has a deeper receptacle than the Chinese one.Thanks to your post it peaked my interest and I placed an order for the same impact. I recently stumbled on a video that calls out some differences between the US Makita and the Japan Makita in the chuck and that not all 1/4 drive insets will fit in the Japan Made Makita. Would you be able to comment on that?? Thanks
I would be curious to know what brand of power tools they do work in.
Thanks for taking the time to reply!I responded to your direct message but for the record, to my knowledge, I have found no inserts that don't work with the Japan one. Everything I have tried to put in it fits and locks into place. However, the tool came with a double ended bit and that bit (obviously works in the Japan driver) does NOT work in the Chinese/American driver because it is too long. But so far everything has worked for me. The only obvious difference to the eye in chuck construction is the Japanese chuck has a deeper receptacle than the Chinese one.
Thanks this explains it. Kind of wish the US market tools have the double end capability with the deeper chucks. Japanese efficiency with less material waste.Something I Just learned today, those longer double ended vessel bits (made in Japan I'm assuming?) would likely work in Japanese tools (or at least something like my Japanese Makita impact driver) but do NOT work in American market impact drivers. My Japanese Makita has a deeper chuck than my Chinese American Makita. See pictures
Doubled ended Makita bit is longer from end to indentation than the American purchased bits also pictured.
Long double ended bit does NOT fit into the black Chinese American chuck but it DOES fit into the purple Japan Makita.
American purchased bits fit in both.
Not to my experience, I have had no issues with bit retention. I've tried many different brands (Bosch, Milwaukee, Dewalt, Makita, Warrior, other misc no name brands) and many different styles of bits (socket adapters, bit holders, nut drive bits, shock absorbing bits, etc.) and have had no problems.The deeper chuck doesn't impact bit retention I take it with shallower US style bits?
I'd be personally leery of the adapters also, due to the guarantee of me dropping and losing one at just the wrong freaking time, storing them, etc. That would be two things I'd drop into attic insulation or worksite mud and be forever gone. I'd have to have 8-10 spares myself! To have properly retained E6 and Type A bits looks like you'll have to buy both Makita impacts... or I think Anex sells dual Type A/E6 bits, maybe Vessel sells them also.I have Japanese Makita and Vessel drivers. Unless you use the impractical adapter reviewed in Bzeug's video, the base of the bit doesn't touch the bottom of the chuck well. In most circumstances this just means that bits have an unusual amount of play, sliding in and out about 2mm.
The problem I have experienced, at least with cheaper Vessel drivers, happens when you apply substantial downward pressure when driving a screw. Because the base of the bit is not in direct contact with the chuck, all the downward pressure is applied to the retaining bearing and it can get pushed into a position where it freezes in place and seizes the bit. I ended up having to use heat to unlock the jammed mechanism. I now slide the bit past the ball bearing detent if I need to use a Western screwdriver bit.
Well looks like I need to buy the Vessel powered screwdriver... Any input on the high speed No.220USB-S1U or the regular No.220USB-1U? Also looking into the Panasonic and Hikoki versions now...I'd be leery of the adapters also, due to the guarantee of dropping and losing one at just the wrong freaking time, storing them, etc. That would be two things to drop into attic insulation or worksite mud and be forever gone. I'd have to have 8-10 spares myself! To have properly retained E6 and Type A bits looks like you'll have to buy both Makita impacts... or I think Anex sells dual Type A/E6 bits, maybe Vessel sells them also.
I think all of this generation of powered screwdrivers are roughly equivalent, at least when it comes to the amount of force they can exert. They all look like they have the same guts inside.Well looks like I need to buy the Vessel powered screwdriver... Any input on the high speed No.220USB-S1U or the regular No.220USB-1U? Also looking into the Panasonic and Hikoki versions now...
Thanks for the feedback on skipping the regular/low speed. The low form factor is intriguing and am under no illusions about its torque capabilities. but can it do lag screws?I think all of this generation of powered screwdrivers are roughly equivalent, at least when it comes to the amount of force they can exert. They all look like they have the same guts inside.
When you have to cram a motor, gearbox, battery and electronics into a screwdriver handle, compromises are inevitable. I suspect that manufacturers are limiting the amount of current that can be supplied to the motor in order to maximize time between charges. Vessel drivers have an 800mAh 3.7V cell, which gives them less than 1/3rd the capacity of my Makitas' batteries.
As a result, these drivers don't have much torque, and that is the most common complaint I read in reviews. The other complaint is that they are too slow, which is a result of the reduction gearing necessary to provide a useable amount of torque. A bigger battery would solve these problems, but where would you put it?
I bought both Vessel versions. They have one now that is both high and low speed, but I worried that it would perform neither role as well as a dedicated driver. The slow speed one has a disappointing amount of torque and is... slow. I don't use it at all.
The faster one is used all the time on my bench. It's great for removing finely threaded screws from electronics chassis. It also sees limited use in the field. You have to "break" the screw at the start by hand when removing a fastener and give the driver a manual twist at the end when inserting one, but it has enough torque to drive machine screws most of the way. Vessel acknowledges this in their marketing materials.
The only time I've had an issue with the Vessel was early on when a Western bit got jammed in it after I manually torqued a fastener. I just stick to using Japanese bits now.
And I'm sure I've mentioned this before, but the Makita drivers I bought from Amazon Japan turned out to have been made in China.
It might be able to do a few, but I wouldn't expect it to show up for work on time the next morning.but can it do lag screws?![]()
I didn’t know there were cheap Vessel tools and non cheap vessel, this is what I am trying to avoid is the bits or adapters getting stuck. Therefore, looking for Japan style bits and adopters.The problem I have experienced, at least with cheaper Vessel drivers, happens when you apply substantial downward pressure when driving a screw. Because the base of the bit is not in direct contact with the chuck, all the downward pressure is applied to the retaining bearing and it can get pushed into a position where it freezes in place and seizes the bit. I ended up having to use heat to unlock the jammed mechanism. I now slide the bit past the ball bearing detent if I need to use a Western screwdriver bit.
I meant to say that I have only had bit compatibility problems with the relatively inexpensive Vessel tool chucks, and not with my Makita ones.I didn’t know there were cheap Vessel tools and non cheap vessel, this is what I am trying to avoid is the bits or adapters getting stuck. Therefore, looking for Japan style bits and adopters.
if you can suggest non cheap Vessels please share. Thanks.
