Bending 1/4 inch steel
bluedog225
Texas
I’m taking a new approach on making my metal brackets. Is there any real downside to bending 1/4 inch x 2” flat bar into 90 degree angles?
Specificallly, will a single field bend appreciably weaken the steel? And would heating red hot then bending help, or hurt, in terms of final strength? Quench or no?
I’ve got the material to make a bending jig with a long lever arm.
Thanks
gmcgeo
I have a 20ton HF press also. I change to a pneumatic 20 ton bottle jack. makes it easier to operate
crazylunker
Connecticut, Trumbull
I made a couple brakes for my press several years ago. I have no problem doing a crisp bend in 1/4 up to 8" wide. The first brake was just made from scraps and had had a ton of use which shows but it still works great
ATC
VA
gmcgeo
I purchased the finger brake set off of them, best purchase i made all year
welder4956
Birmingham, AL USA
If this is just ASTM A36 mild steel, a hot bend will not cause any significant reduction in strength. There might be some minor change in grain size if it is heated above the lower transformation temperature (1335 F), so keep it in the 1100-1200 range using a temperature crayon (Tempilstik) or a infrared thermometer. Quenching won't restore any strength because of the low carbon content of mild steel (0.30% or less), but shouldn't hurt either if you just need to cool it down after bending.
jack stand
Lakes Region Maine
I didn't mention it on your first post, but a box (50) of appropriate structural screws is more than enough to make both ply's to work as one beyond your steel wrap-brackets effort. A zig zag pattern, opposite on each side is what's recommended.
Look for either of these.
You may want a 3 1/2" to not blow out the back side.
tester19
chigago
Every time I see that SWAG finger brake I wonder why I don't have one!
Not one complaint from anyone.
So useful too.
I have the 20T HF press and upgraded that to a 20T air over hydraulic jack and one of the best things I did was to go to a foot valve to operate the press. Leaves both hands free to guide things and much safer as you can stand to side of the press while operating it. Also added casters for easy moving.
619DioFan
San Diego , Ca.
I use my press for bending and I also have the floor mount bender from HF. I really like the hf bender as it can do curved bends as well. It will barely accept 2 inch flat stock, nothing wider.
bluedog225
Texas
Close enough for my purposes. I’m wanting to tie those 16” lvl’s to the top plate and to the triple lvl.
Of course, the drill press switch broke on the first hole.
Thanks all!
bluedog225
Texas
It’s a tall structure. The engineer was well seasoned. And thought those timberstrand studs would run true. The framers hated them because the nails wouldn’t sink. I bumped the 1/2” ply to 3/4 back when it was $22 per sheet. 10d hot dipped ring shank on 4”-6” centers. The framers also hated that. 😂7BBD2AE6-A49D-425E-9CE5-AA6424F297D1.jpeg
kwb
PNW
Now I need even more info. That door and lack of a drive really begs some questions.
If there is a whole lot of piles and steel pan to pour a deck/driveway now I am really going to be interested.
