This looks like the logo.I think I found it too. A Powerkraft from montgomery ward. Now to find a replacement pulley.
Thanks so far for all the help
I looked at my old pulley and the only marking is the "made in USA" The top is .51 and .63. The bottom is .82. My guess is there is some ware. I forgot to check the depth. I think it may also started out in life as a 4 step pulley.Correct... made by Duro.
Duro also made their own branded machines. Parts MAY be interchangeable.
The internal splines located on the top of the spindle pulley are also very similar to some Atlas-made spindle pulleys. What are the specs on the underside of the pulley... bearing shaft diameter and depth?radfather
How does the original pulley attach? What size bearing shaft fits into the pulley from underneath? How deep does the shaft insert into the pulley?I looked at my old pulley and the only marking is the "made in USA" The top is .51 and .63. The bottom is .82. My guess is there is some ware. I forgot to check the depth. I think it may also started out in life as a 4 step pulley.
Ok thanks for letting me know. I'll keep searching and thanks for the info you have given.Ingenious? I agree! And well crafted.
I believe the female shaft of original pulley rode above that collar and the large sheave extended below the collar. It's rather typical I think.
I have a fubar Atlas spindle pulley. The female pulley shaft measures ~0.9345, so that idea won't fly. You'll need a Power Kraft or Duro part.
If the broken partially white thing you posted was the original pulley, it was likely a pot metal zinc casting.I'm now thinking the recess in the bottom of his pulley is due to ware, but I am not positive. He did install a set screw in the side of the largest slot
But your right it is working and has for over 30 years. I am hoping to find a version of the original metal pulley.
