Thank youthat disc is designed to be used with it's own nut, not the one that comes with the grinder. you're fine
This, although you have to make sure threading matches, since both metric and fractional inch threaded arbors were both sold in the USA.that disc is designed to be used with it's own nut, not the one that comes with the grinder. you're fine
The grinding disk in your picture looks like its a depressed center disk and the nut should go on the abrasive side of the disk facing away from the angle grinder.I'm wanting to use this blade on my cut off grinder will this be safe to do so without the flange nut it ?
the nut is factory mounted to the disc. it can only go to the back side of the discThe grinding disk in your picture looks like its a depressed center disk and the nut should go on the abrasive side of the disk facing away from the angle grinder.
jah, but i'd put money on it someone putting the wheel on backwardsthe nut is factory mounted to the disc. it can only go to the back side of the disc
