What's this wrench for? Aviation application most likely.
cavalry
Upstate NY
Stamped sheet metal, 1/2" 12 point wrench. 12" long, .125" thick, no markings other than the size.
Looks like the outer wrench for my table saw blade change, but too small opening. So maybe custom-made for a tool or application requiring reasonable torque.
4xdog
Santa Fe, NM
I'm guessing it was a specific wrench for some fairly simple homeowner-grade tool.
Others here will know more than I, but I'd be shocked sh*tless if any aviation-spec tool didn't have control numbers on it that identified all kinds of things.
C
cavalry
Upstate NY
It came out of an aviation box covered elsewhere here, so it had a some sort of. One thing I have learned to hate from avation is all the tools in the box need to be run across my demagnetizer. Damn tool tracking.
Death Row Dave
Home
Used to tighten Jesus nut . If you didn’t tighten it tight enough and it comes loose , your azz is screaming OH JESUS , just as you see the scene of the crash starting to rapidly approach you !
