Shovelhead
I’ve got 4S deep boxes set for a single receptacle and 3/4” mud rings.
Some are mounted on a common wall between shop and a room built inside the shop.
Since the T1-11 5/8” siding was already up before I started wiring I had to cut it so the receptacles on the shop side would be flush with the wall. The picture shows how I cut the wall to only expose the mud ring and not the 4” box.
Question is, are these steel mud rings designed to be screwed on the box and never have access to their screws?
If I were to cut out for the 4” box and use the single device mud ring, a standard cover plate wouldn’t cover it.
I do not like the looks of oversized cover plates.
Next question.
I have three 4S boxes dedicated for future 240v woodworking tools. I want to wire them for 120v right now.
Since I don’t know what 240v receptacle may wind up in these boxes, what 3/4” mud rings should I use that would allow me to swap from a single gang 120 receptacle to a 240 receptacle in the future?
I’m thinking I may need to make my wall cutouts the size of the box in order to change out the mud ring later on.
And that would require a big *** cover plate.
Is there a single round 120v receptacle I could use that would fit a 3/4” mud ring, and also fit a 240v receptacle?
Thanks
Next question.
Thanks
