YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 526
I have a 2005 Camry. The OEM sway bar links have no wrench flats towards the bottom of the stud of the ball joint. They are 100 % round.
I know most sway bar links, this area has a wrench flat, with an Allen head at the top of the stud. You can either put an Allen head in the top of the stud or a wrench at the base of the stud. But with Toyota, don't know why, the only option is to put in Allen head wrench at the top of the stud because there are no wrench flats at the base of the stud. You then wrench off the nut while trying to counter turn the stud.
However these always round out on me, and I have to cut them off. I don't like doing this because sometimes I accidentally ding up the knuckle or strut in the process with my angle grinder.
This got me thinking. Is there a Allen head wrench extractor socket that I could use? I know for like rounded external hex fasteners, there are special extractor sockets you can use that will bite into the nut or bolt allowing you to take it off. Something like this.
Is there a socket set I could get for rounded out internal hex (Allen) instead of external hex? Essentially an Allen key socket except with teeth on the sides to bite into the internal hex hole?
Meaning something like above, except with "teeth" on the sides that can go into a rounded out hole, bite into it, and allow for a good grip?
The specification for the nuts on the sway bar links is 55 ft lbs. So they are on there pretty good. I need something that would allow me to apply lots of torque on the internal hex of the stud, to counter turn the nut off.
Any ideas or I'm stuck just cutting these things off?
