Over Thinking Garage Epoxy Flooring
Stone17
Houston TX
After prepping the floor for epoxy coating. I acid washed the floor twice and degrease.
Should I use a Rust-Oleum Recoat Primer 1-part Gray Flat Concrete and Garage Floor Paint to prime the floor? Link to Rust-Oleum Recoat Primer
What's the better epoxy paint to use? Rust-Oleum EpoxyShield or Rust-Oleum RockSolid
Before:
After: Still need to clean behind the fridge.
sparkness
Long Island, NY
I had cleaned and etched my floor, then epoxied a few days later. It bubbled up , out gassing! I found out later , recommendations were to use water based epoxy sealer and then full solids,I did not use the primer and caused the bubbles in the surface. Floor coating should be applied early in the day as to prevent bubbles due to heat from the day. I wound up renting a floor sander and re coating to fix my mistake. Use good quality epoxy such as Rock solid or commercial stuff, you will need more than the can recommends!
Shea
California
Before:
Do not use the Rust-Oleum Recoat Primer. It is intended to be applied to bare concrete that has previously been sealed or for application over an older coating that is adhered well. It is NOT intended for bare unsealed concrete, particularly concrete that has been prepped via etching. We have an article here that discusses it.
RockSolid is a better coating than EpoxyShield. It's much glossier, more resistant to hot tire pickup, and will wear longer. Like EpoxyShield, however, it's a thin coating. In addition, it penetrates concrete much better. Due to the more aggressive etch of the surface, it may require two full coats to get the minimum mil thickness, color uniformity, and gloss. I suggest reading our article below that discusses the facts about RockSolid. There are actually much better coatings you can apply for almost the same amount you would be required to spend on RockSolid. Sinlge-part polyurea is a great example. I posted that below as well.
Stone17
Houston TX
Shea
Thanks for the information.
My garage is about 360 sq ft.
Will order two kits of the RockSolid 2.5 garage flooring. Going to coat the garage floor twice.
This weekend look like rain so many need to hold off.
dcg9381
Austin, TX
"RockSolid Polycuramine™ is the best of Polyurea, Urethane, and Epoxy chemistries. It combines these three chemistries and their key attributes into ONE indestructible, self-leveling, flexible, fast curing, high gloss coating system."
I don't know this product, but I have used the single stage "Rustolum" garage coatings years ago.
Never, never again.
All I do is polyurea (Legacy Industrial) now. I've done 3 floors, including 1500 of finished residential floor with it. Cost per sqft compared to industrial epoxy is much better. For color, I just stain the floor, but you can get it in non-transparent.
2 coat minimum of polyurea. Love it.
Easier to install.
Stone17
Houston TX
"All I do is polyurea (Legacy Industrial) now. I've done 3 floors, including 1500 of finished residential floor with it. Cost per sqft compared to industrial epoxy is much better. For color, I just stain the floor, but you can get it in non-transparent.
Easier to install.
Can you post a link to the kit?
Look like they sell 4 types of kits.
Stone17
Houston TX
Guys, again, you do not need to acid etch after grinding. Grinding is a superior method of surface prep compared to acid etching. All you’re doing is introducing water and hydrostatic pressure to your slab as a failure point.
I wish I would of grinded the floor down. This Acid etch is alot of work.
It look like some of the garage floor is not taking the acid etching. Feel like 220 grit sand paper but other area feel like 80 grit.
FJ4FUN
NorCal
Inconsistent/insufficient surface profile is one of the main detractors to acid/chemical etch as a surface prep. Especially when using thin polyurea coatings. It may take multiple etching attempts or, bite the bullet and grind...
Stone17
Houston TX
Im going to Muriatic Acid the floor again. It been working good but maybe need to seat alittle longer.
dcg9381
Austin, TX
Eh? Acid etch to me is spray with acid, wash out, neutralize, wash out again.
Having run both wet and dry concrete grinders and spent 2-3 days recovering from running those grinders, acid etch all day long!
Stone17
Houston TX
I looked into renting grinder but the price is from $200 to $600. Plus I would need to rental a trailer to get it home.
The acid etch is the easier way for me.
Stone17
Houston TX
2 more gallon of Muriatic Acid.
This time I forced on the smooth area. Now it ready for the epoxy paint this weekend.
Look like rain Saturday.
Shea
California
Yikes... As a note for others, many acid etches without neutralizing can create long-term problems. Rinsing with water does not neutralize it. It just washes the acid off the immediate surface. The acid solution that was able to penetrate stays active, even if it is partly diluted with multiple rinses. The active solution can slowly deteriorate the concrete as well as cause corrosion issues with the rebar.
FJ4FUN
NorCal
...It can also attack the coating to concrete bondline increasing the potential for future delamination. We've seen situations where a floor is coated during the dry summer months and all looks good but then the coating pops in the winter due to rising moisture levels driving insufficiently neutralized acid up towards the surface.
A couple of additional tips: *Do NOT use high pressure water when neutralizing/rinsing. Instead flood the floor and squeegee out or vacuum up the rinse water. High pressure water can drive the active acid deep into the concrete pore structure. *Verify that the acid/etch has been sufficiently neutralized by testing the rinsed concrete with pH test strips available at any pool supply store. The correct pH should be between 6.0-9.0 with 7.0 being ideal. If the pH is below 6.0, neutralize again.
Jsf721
LI, NY
I have had zero luck with epoxy. If you can return it get a tile either racedeck or ceramic or better Porcelain
Stone17
Houston TX
Here some before and after pictures. Took 3 bag of Rust-Oleum RockSolid for 360 sq ft garage.
Will recoat this Friday and add paint flacks.
Stone17
Houston TX
Just seeing this post now.
I did power wash the acid out of the garage but did it 3x time. Used a squeegee to move the water out too.
I hope I done have any problem.
benwah
Lakewood, Colorado
It seems to me like you are rushing it and not installing this properly. The acid must be neutralized before you coat it. You are probably going to have delamination issues in the future. I'm curious to why you did not neutralize the acid. Pressure washing only drives it further into the slab.
Since you coated this on Sat or Sun, and aren't going to do the 2nd coat until next weekend, you're going to have to sand the entire floor because your re-coat window is gone. Typically you want to re-coat within 12-18 hours to stay within the re-coat window and avoid sanding.
Stone17
Houston TX
Rust-Oleum said you can recoat with in 7 day.
Stone17
Houston TX
Laydown the 2nd coat Friday (1/27).
Used 2 package of the epoxy and 8 bags of flakes.
The color across the floor look the same now. I did buy the clear coat but we have rain the in forecast for the next 4 days.
Stone17
Houston TX
Its been over 36 hours now.
I walked the garage floor. Seen some mosquito hawks stuck to the floor and two small bubbles (Out gassing).
The parts next to the garage opening is wet on top of the epoxy floor. Not sure where its coming but the humidity is 80% today.
The A/C unit is off in the garage.
I did do the moisture test and no moisture on the plastic bag.
