Torx vs. Tamper Resistant Torx Screwdrivers
dkroth
Rochester, New York
I'm thinking about upgrading my Torx screwdrivers. I'm considering a tamper resistant Torx set as those should work for both tamper Torx and standard Torx, correct?
Would I be giving up anything by getting the tamper torx? They may be slightly weaker than the standard Torx, but is that enough reason to pass on them?
OTOH, I've never *needed* a tamper Torx. But when that day comes I'll be glad I have them.
brian90505
Torrance, CA
Depends on what you use them for. Light work is ok. But stuff like Harley engines, rotors etc. will twist or break the tamper-resistant Torx.
wafrederick
Holton,Mi
You will need them.Screws holding on GM mass air flow sensors use tamper resistant torx screws.Some Chrysler ignition switches have one torx resistant screw.
nisreo
Ive broken a few tamper torx. So I only really use them when I need to. Id go ahead and buy your normal torx set and just get a cheapo set of tamper torx bits.
Stick Figure
Omaha, Ne
if we are just talking screwdrivers, i doubt you will get enough torque on them to find the strength difference between the tamper resistant and regular. I own both in socket form, but have them split between work and home. The other option of course is to buy them in 1/4" bits that would get you both, and should work in 99% of needed applications.
Indy_500
Appleton, WI
i have tamper proof torx screwdrivers and regular torx sockets. i learned quick after puttin a tamper proof torx bit onto a cordless drill and the thing twisted around and snapped that tamper proof= not strong. but of course it was a HF bit :)
ephotrod
Texas
Buy a normal torx set and if you run into a tamper proof screw just break the middle tab. Now your able to use the regular torx bit on the screw.
Josh
Fedwrench
Valley of the sun
Breaking the center tab on a tamperproof torx fastener isn't a recommended option as on some applications where these are used, you'll screw up the part. If you haven't used them yet, I would opt for a quality bit set and use a magnetic screwdriver instead of buying a whole set of handled tamperproof torx drivers but, that's just me.:beer:
browntown
Salem, OR
I had to go get tamper proof torx sockets when taking seats out of either a chevy s-10 or a volvo 850. Don't remember, but was surprised to see such a big tamper torx. Get both.
Dennis The Menace
Inland Empire, SoCal
Buy a great set of Security Torx tools, then buy the Torx as needed. That's what I did and it worked out great.
As it turns out, you end up buying Security Torx in the smaller and middle sizes, large for the Torx. I have 5/16 bits for Torx and 3/8 Torx socket set. All Wiha and all less than $50.
This is what I have that covers about 99% of my Torx needs...
Wiha #76396 8 Piece TORX Bit 3/8 Socket Set On Rail T20, T25, T27, T30, T40, T45, T50, T55
You can get that set for $30.49 from MJMNATIONAL eBay.
blarf
Buy both. I don't know how the prices compare to yesterday, but if bought individually you could walk away with a set of the PB Swiss cross handled screwdrivers for $29 (T6, T7, T8, T9, T10, T15, T20, T25).
D
dkroth
Rochester, New York
Thanks for all the feedback and ideas. I may end up looking at a bit set as I am a little short on toolbox space at the moment.
mkstuls
For hand turning fasteners with screwdrivers can I use tamper-proof torx screwdrivers on torx fasteners without damage the tips of screwdrivers for sixes 15-40?
Farmall450
Marengo, Illinois
Or get all the bits for your Snappy screwdriver.
