Removing Fasteners with Over-sized Slots
NoSkills
A small town west of Knoxville, in beautiful East
Is there a special tool for removing over-sized slotted fasteners that are not designed for regular straight-blade screwdrivers?
As an example, beow is a pic of the pop-up tub drain plugs used in my bathrooms, but I seem to run across other applications on occasion. Even my largest straight-blade screwdriver (5/16") easily cams out and boogers up the soft metal, even with lots of down force applied.
I don't think a coin driver will work well since they have a radius on the tip. I'd rather not have to cobble something up if there is tool that will work. I know, first-world problem, move on with life, etc, etc!!!
Appreciate any input!
budget76
handheld impact driver bit - the largest flathead one. still too small?
Farleyfan
Tennessee
1/4" bit driver set, They usually have a flat blade type that fits those "shallow" slots pretty good.
These are the hollow ground type im talking about, there not on a taper like a regular screwdriver tip.
N
NoSkills
Thanks for the replies! A drag link socket would be the cat's meow, but a quick Amazon search shows them to be surprisingly expensive, especially for this goofy one-off use. The suggestion for an impact driver bit is looking pretty good. I see you can get bit sets that go up to 1/2" or so, and the flat blades appear to be hollow ground. So, that looks like a promising avenue.
ShuhornGarage
Depends on the access & portabability of your part, maybe consider drilling a hole in the screw & using an easy out?
JimH74
South Central Texas
You want a Vessel 5700WP faucet driver. Haven't found a seller here in the US, but you can order from Amazon Japan or on the bay. I had it in my amazon.co.jp basket and was adding other small items to get the shipping down, but then Amazon has apparently changed how they compute their shipping fee.
WWheeler
Middleofnowhere USA
ebay - $14.25 with free shipping from Japan, sales promotion ends later today
There's other ebay sellers for this item also, but that was the lowest price I saw.
Looks like a neat tool. I just ordered one myself.
619DioFan
San Diego , Ca.
Harbor freight sells a 6 piece over size screwdriver bit socket set ( 1/2 inch drive ) 3 slotted and 3 phillips. I have them and they work great. 14.00 , lifetime warranty.
I have a bunch of old brace screwdriver bits that are really wide for jobs like this. Not strong enough for a vise swivel nut, which needs a drag link, but otherwise works See the left side of this image, just to the right of the drill index. I have even wider ones elsewhere.
PMD1966
Lake Orion, Michigan
You can get larger screwdrivers, but most brands cap out at 3/8". I believe Klein and Felo offer a 1/2" driver.
Otherwise, a drag link socket might be the way to go.
I have a collection of flea market and garage sale tools. When I need something different, I can grind, heat and bend these tools. Save my good tools that way.
NoahG
Detroit, MI
mslim
Fayetteville, AR
I have one of these for use with my photography/videography gear - lots of wide slotted fasteners on tripod plates.
I wish they had these when I was a First Assistant Cameraman. It always bugged me that the widest screwdriver I could find would ****** the slot in the brass tripod screw. I would imagine you'd make a little lanyard and clip this onto your belt or AKS bag.
N
NoSkills
Great suggestions! As usual, GJ doesn't disappoint, and I learned some things (never heard of a faucet driver or hurricane bit before). While the fastener I started this thread about looks very large to me, after I measured it, it is only 3/4" in diameter, and the slot is about 1/16" wide and 1/32"+ deep. Its brass and very soft, but this is a low-torque application. Looks like a lot of the suggested tools have tips that are too thick, or at least it would be so close that I don't want to risk ordering a tool that may or may not fit.
In the meantime, I looked through all my 1/4" hex shank bits hoping to find one bigger than my 5/16" screwdriver. The largest I had was also 5/16" but it fit the slot much better. Weird. So I inspected the screwdriver tip and found that it is not perpendicular to the sides, it has a slight chamfer (almost looks like a chisel with a steep face), so it doesn't engage the shallow slot properly and cams out easily. This is an oh-so-common Craftsman acetate handle screwdriver from the '90's and has been used as a pry bar for 99.9% of its life. Tip wasn't damaged, just misshapen. So first order of business is to file the tip down and see if that does the trick. I also plan to get some larger bits for future use. I think 3/8" will do it, but I'd like to have additional larger options.
Thanks for reading, and thanks for the help!
