It’s in our hotel roomIs this sink used often? if the water evaporates out of the trap you will smell the gas, water is the barrier
Check out/ change rooms.It’s in our hotel room
Yeah we have stayed here when we come to climb ice for the last 12 years. I have read what i can find about p traps and s traps. Why else would one smell sewer gas with this setup.Did you run some water in the sink/shower/bathtub to make sure all the traps are full? Although it is hard to believe they wouldn't be used enough to stay full.
We seem to only smell it when we use the sink.Did you run some water in the sink/shower/bathtub to make sure all the traps are full? Although it is hard to believe they wouldn't be used enough to stay full.
It’s a hotel room.Is there a floor drain? If so put water in it the smell will go away. The trap for the floor drain is dry.
Thanks for that, it isn’t a matter of convenience.Dang, I’m a plumber and I’ll help out with the best advice I can when/where I can but you guys are going a bit too far with DIY plumbing troubleshooting/repairs in your hotel rooms.
Request another room man!
Hmmmmm? But wouldn’t the drains back up. Not a lot of snow lately. Maybe 5 days aho….Vent is plugged.
Had the same issue when a glue joint on the vent piping failed when snow slid down the roof and impacted the stack.
Nope. If the vent is broken off in the ceiling, the smell comes down through the wall.and out into the cabinet or electrical outlets.Hmmmmm? But wouldn’t the drains back up. Not a lot of snow lately. Maybe 5 days aho….
You in Prudhoe Bay?It’s in our hotel room
I've stayed in hotel rooms that had a floor drain in the bathroom, and in fact in one case had to pour some water in the drain to stop the sewer gas smell.It’s a hotel room.
If the vent is plugged or inadequate, when a toilet is flushed it can **** the water out of the trap in your sink opening it up to the sewer line.Hmmmmm? But wouldn’t the drains back up. Not a lot of snow lately. Maybe 5 days aho….
