If you were able to hide the fact that $1800 is gone I think you'll manage......................Anyone else receive their Hardtail vise yet? I confirmed mine is on its way this week. I thought I'd have finished building my new shop by now, nope... still in my 1/2 car garage.
What are some ideas on how to disguise this vise so my wife doesn't see it?
I am thinking about putting it on casters, covering with an old leather shop apron, clamping a seat between the jaws and pretending it's a shop stool when I'm not using it.
Beyond the fact that the USA-made one isn't in production yet, he's not selling on COO. Additionally the USA-made one would perform identically.
You should send him a letter...
But 3800$ if made in the USA as the other two. All around I get he's trying to sell it but it's not quite correct...
The chamfered screws on the Morgan position the jaws. The Wilton has a regular screw but the positioning is carried out by a pin. The Fireball has none of those, the only thing positioning the jaws is friction from the pressure. And as he himself explains many times - a larger "spindle" is not always giving you the most strength. The bigger screws have a larger pitch. At the relatively thin thickness of those jaws relative to the diameter of that screws, I do not think these screws will stay tight forever. Such screws should not hold via their shape, they are designed for tensioning. For that kind of thing, a locating screw needs to be used.
And biggest usability issue I see is how it has no overhang at all.
Compared to a big Wilton, for example...
So the fireball is practically a chipping vise which used to be used for cold chiselling metal, before mills and other cutting machines were as widespread as they are today... They're not made anymore because noone does that nowadays. I'm sure an old chipping vise from Parker or Record would be way better for those tests, because they're made for them just like the fireball vise is made for them. Except that such vises didn't even use a rotary base, they're too heavy and wouldn't have much use from it anyway, but as we can see on any vise test they're always the failure point.
So, for 3800$ you can almost get two of those big Wilton vises if you want a US made vise. I think they're much better at that comparison. For 200-500$ you can also get a pretty beefy hydraulic press if you need that. The fireball is really cool and hyped but even at 1800 I'm not sure if i wouldn't rather have a wilton (probably the fireball, it just looks coolbut from a usability standpoint... not so much).
He may be targeting those sorts of shops, but after selling hundreds of vises, many to shops, it was rare for them to buy anything bigger than a 100lb vise. I've had a pile of 6"+ vises in the 125-250lb range and going off memory all but three went to home shop guys who just "had to have" a massive vise. The Army can work on M1 tanks with a Wilton C2, but everybody on Garage Journal needs a 150lb vise...lol.I think his target market is shops that abuse tools. Think railroads, big steel shops, heavy duty equipment repair and industrial maintenance. Welders and millwrights are much more likely to wail on a vise with a sledgehammer and use it as a press versus a car mechanic or a machinist.
It’s wildly impractical unless you need that kind of vise. Then it’s perfect.
Look at the rest of his products, he’s not targeting the home shop or the machinist type. He’s selling to farmers, welders, fabricators and shops that deal with bigger weldments and parts.
The Wiltons he tests against are their machinist line. Their C series might be more appropriate but there’s not as many people who have those.
What he should be comparing against is a blacksmith’s post vise, which are designed for the abuse but then his vise wouldn’t look as good when the post vise doesn’t fail impressively.
The reality is these “tests” are more about the advertising press and eyeballs on his product than the actual real world application of bench vises. No one does what he’s doing to vises. It’s just drama to get people to look. And it’s working.
Jason is making a heck of a vise. Whether or not that’s what you want in a vise and is worth the money to you is an individual choice.
Or guys who wish they needed it.His target market is guys who think they need it. He's nobody's fool.
I wish I needed it lol.Or guys who wish they needed it.
It's got a big "washington" casted on the side. He in fact fooled a lot of people into thinking it was going to be US made. So he is trying to sell on COO and hype up people to think it's US made. He also only compared it to US made vises.Beyond the fact that the USA-made one isn't in production yet, he's not selling on COO. Additionally the USA-made one would perform identically.
Jeebus...
No, locating pins hold an exact position with their fit. Screws do not hold a position. For example, on a properly engineered gearbox cover which hold bearings, the flange will have two locating pins (never more than two, and for bearings never less than two) as far apart as possible. Their location is exact, so the cover sits at the exact position it needs to, and the screws only clamp it down. You will find this on any cover that holds bearings and is properly engineered, even if it is a tiny motorcycle engine.Locating pins help align large, heavy, or unwieldy assemblies prior to fastening to streamline installation. A couple of 5-10 lb jaw inserts that sit on a shelf, held in relative position by gravity alone prior to fastening, isn't an essential application for locating pins.
Many Wiltons were made without the center pin...just FYI. I don't know if it's one of those things that went away then came back, but I've had quite a few without center pins.For the jaws on the wilton, the centre pin means the jaws are "locked" in two axes. Even if you take the screws away, the jaws stay in place and they'll get pushed on their seat when you tighten something down anyway.
lol - oopsMany Wiltons were made without the center pin...just FYI.
Some of y'all are funny. If he'd made them exclusively in the US you'd be kissing his ****.
I also think it's laughable to say he's trying to fool people with COO.
lol - oops
Fast one? Did he not fully disclose and clarify COO before any customer vises were shipped out? Did his company not offer to refund the deposit to anyone who no longer wished to follow through with their pre-order once it became apparent that the castings are coming from Taiwan?Someone's a little fond of Jason...he pulled a fast one on people here, no doubt about it.
For the above group I think this vise needs more throat depth. What's the point of having super strong vise with great clamping force if you can't clamp on bigger parts.I think his target market is shops that abuse tools. Think railroads, big steel shops, heavy duty equipment repair and industrial maintenance. Welders and millwrights are much more likely to wail on a vise with a sledgehammer and use it as a press versus a car mechanic or a machinist.
Where's the fast one?
OKMake everyone think it's a US vise, names the foundry in the US in a video, take pre-orders....then tell everyone, ya no, not made here, sorry.
lolSomeone's a little fond of Jason...he pulled a fast one on people here, no doubt about it.
You have to wear your tinfoil conspiracy-theorist hat to see itFast one? Did he not fully disclose and clarify COO before any customer vises were shipped out? Did his company not offer to refund the deposit to anyone who no longer wished to follow through with their pre-order once it became apparent that the castings are coming from Taiwan?
I'm not saying he didn't cause confusion. I just strongly doubt he's numb enough to try to intentionally deceive people given the circles he travels in. The guy clearly understands the internet, so thinking the "secret" of MiT wouldn't get out would just be stupid.I mean, he’s not the only one who was confused by the COO thing.
So much so that Jason had to go on some podcasts and address it.
I certainly feel like he got ahead of himself on COO and has to walk it back.
I don't think intentional deception was ever really the point, but I do think he shot his mouth off about making this vise in USA for a price, started taking pre-order money and then realized he couldn't do it for the price he promised.I'm not saying he didn't cause confusion. I just strongly doubt he's numb enough to try to intentionally deceive people given the circles he travels in. The guy clearly understands the internet, so thinking the "secret" of MiT wouldn't get out would just be stupid.
Companies who buy it won't care much about COO overall. Individuals will be split along much the same lines as we see here. IMHO the customer overlap between the two price points is virtually zero. Given the cost of MiUSA manufacturing and the tooling/start-up costs required, he'd be silly to limit himself to that, and I think he wanted to offer MiUSA to those who care.
He then had to find a way to back track and keep his promise without losing face, hence the situation we currently find ourselves in. USA made vises are not available yet, but when he started taking pre-orders, the impression most everyone got, myself included, was there was only one vise, a USA model.
When I paid for my pre-order, there was not a selection for Taiwan or USA like there is now. That would have immediately thrown up red flags for me and I wouldn't have made my purchase decision as I did.
Only after there was a significant push back did they do something about it and try to play this off as how it's been from day 1.
If he just came out and said, "hey, costs were double what I originally anticipated, I'm sorry, here's your options going forward", I think he could've salvaged this better. Instead, he pretended we're all too stupid to remember what we preordered and is gaslighting us into thinking it was Taiwan from day 1 and we just all collectively missed that. Dirty pool, if you ask me.
Maybe it is just me, but when I hear someone say (or see it typed) pulling a fast one I interpret that to mean intentional deceit.Bingo, this is exactly the "fast one" I'm alluding to.
Plenty of guys on here basically hate USA coo.Some of y'all are funny. If he'd made them exclusively in the US you'd be kissing his ****.
lol - oops
Yeah Fireball will have to continue producing and selling the vise for the next decade at least before it gains any amount of traction in the professional industry sector. Probably another 20 years after that (and a couple other available sizes) to make a dent in Wilton's market share.When a shop with a bunch of Wiltons needs a new vise, they just order another Wilton; they don't spend half a day researching on tool forums for unknown companies that possibly have produced something better.
