Old snap on screwdriver shaft replacement
bmwpower
Can I just replace the shaft? #2
Anyone know the part number?
charbar
Midwest
Yes, you can replace just the shaft. That is how they do it on the truck, hammer the handle off and hammer it back onto a new shaft.
Sorry I don't know a part number. No Snappy trucks running around your area that could do it for you?
BlakeTheCarGuy
Roanoke Virginia
If you don’t have a truck you can call or email them they will send you a new screwdriver. They typically don’t send out replacement tips even though they just replace the tips on the trucks.
Qualitytools
SOCAL
Will Emailing them or calling them also work if I have a cross threaded and damaged cap on a ratcheting hard handle screw driver? Thanks
Qualitytools
SOCAL
Who cross threaded it?
Good question as I am the only one that uses it. One day I went to remove the cap to change tips and to my surprise I couldn’t turn it by hand to remove it. I ended up using pliers to remove it which left gouges on the cap and noticed that the threads are messed up after removal.
Raineman
central Maryland
Those handles shrink over time. I had an old one and lost the cap. I ordered a new cap (they are available separately) and it would not screw in, too tight. My truck guy ended up just giving me a complete new one.
Qualitytools
SOCAL
Maybe that’s what happened because I know I wouldn’t have forced it on If I felt any resistance while putting it back on.
bmwpower
Thought maybe I could do it myself instead of trying to track down a truck. Around here, it's not easy to find one.
johninct
I just put a washer over the shank, put it into a vise and use a prybar to pry the handle up and off.
