Hinge Screw Source
FourthQuarter
Cape Ann
Ugh. I'm having trouble finding online source of hinge screws in decent quantity, ~200. Looking for #9 slotted plain or painted black. I'll settle for Phillips if I have to.
Thanks
DHCrocks
Hawaii
what is this for, a standard house door hinge? I've used construction screws like a 3" spax to replace screws for exterior door hinges to get a solid connection into the studs.
F
FourthQuarter
Cape Ann
I want to put a few long screws on the top hinges. Doors are particleboard core so they're heavy. The jambs are poplar (honorary wood).
Interior Emtek, residential grade, plain bearing. I would never use them again; they shipped with prehung doors. Bean counters must have told manufacturing to cut costs. The countersinks aren't deep enough to keep screws from sitting proud of the hinge.
So glad to be in the fourth quarter. Disgusts me that few take pride in anything they do... all about the benjamins.
I've done the same on exterior doors.
Leaflessshadetree
Don't ask.
I've always bought longer screws for hinges, never knew they were anything special. Brass can be chemically treated to make them black though it may not be the finish you are wanting.
F
FourthQuarter
Cape Ann
You're right, they're not special. It's the sizes that much door hardware uses, e.g. #9.
F
FourthQuarter
Cape Ann
You lost me there..
I steer away from poplar for anything that I care about or want to last. It's easy to work with, light weight, takes paint well but bruises too easily and isn't very strong. Also, with short fibers/grain seems like fasteners tend to loosen when subject to loading/unloading cycles.
jar944
Northern VA
IMHO it's an upgrade compared to most jambs. 1" poplar jambs are fantastic. Never noticed any issues with screw holding.
dogdog
I used the decking screws that yellow or green one T-25 bit from HD… it seems to work well, and it’s anti temping some what.
