FourthQuarter
Ugh. I'm having trouble finding online source of hinge screws in decent quantity, ~200. Looking for #9 slotted plain or painted black. I'll settle for Phillips if I have to.
Thanks
Thanks
Might talk to a door shop, they will be Phillips though.Ugh. I'm having trouble finding online source of hinge screws in decent quantity, ~200. Looking for #9 slotted plain or painted black. I'll settle for Phillips if I have to.
Thanks
I want to put a few long screws on the top hinges. Doors are particleboard core so they're heavy. The jambs are poplar (honorary wood).what is this for, a standard house door hinge? I've used construction screws like a 3" spax to replace screws for exterior door hinges to get a solid connection into the studs.
You're right, they're not special. It's the sizes that much door hardware uses, e.g. #9.I've always bought longer screws for hinges, never knew they were anything special. Brass can be chemically treated to make them black though it may not be the finish you are wanting.
I steer away from poplar for anything that I care about or want to last. It's easy to work with, light weight, takes paint well but bruises too easily and isn't very strong. Also, with short fibers/grain seems like fasteners tend to loosen when subject to loading/unloading cycles.You lost me there..
Slotted?
What year is it?
Thanks. Had boxes of 100 of #9 Phillips but not slotted. Heads on screws that came with hinges seemed large for #9. I might be getting #10 slotted.Mcmaster and Carr
https://www.mcmaster.com/
