Oh, yeah, I should clarify me intended usage, sorry about that. I intend this for automotive use. Things such as temp before and after cat to diagnose catalytic converters, checking brake temperatures, checking for a cold cylinder, locating hot spots, watching for temp changes over time, etc. Having the ability to measure temperature via a probe for things like AC testing would be nice, but not really a requirement if it will add a lot of cost.
So I might say the temp needs to get to approx 1500 F or so. I am estimating based on the temps a typical cat sees. Precision is not really a requirement. If you tell me it is 700 degrees and it is really 650, that is not so critical as long as it is somewhat consistently off. So for example, reading one tells me 500 and reading two tells me 600, but in reality, the values are 550 and 650... that is fine. What is not fine is if the 550/650 actual temps measure to 600/600, 500/700, etc. The variance of 50 degrees I simply used as illustration, I am not suggesting that being off by so much is acceptable or not.
For many years I worked as an electrical engineer, so I am well aware of the reasons for quality in meters, such as Fluke being the king, and the rabbit hole it creates. In electronics, there are big safety issues to consider in addition to accuracy and other factors. In most cases, such precision is simply not needed and a bit of common sense (and choice of usage and application) can reduce safety risks, if not eliminate them. Just as above though, the key part in any meter is that it is reliable and does not "act up". Like in six sigma when we say I would rather produce a batch of goods that was 100% defective than a batch that was 5% defective. If they were all wrong, I know how to fix it as my process was consistent. I picked on Fluke again simply because in electronics, that is the brand of choice, like the Snap-On of tools, and for good reason. I am not trying to discriminate based on brand, just stating my thought process in selection.
@GeoBruin Please do not mistake my statements, I am looking at the Fluke models you mentioned now. Thanks for suggesting, I know already Fluke is a solid brand.
