Appropriate Hammer for Working On Car Suspension
logikal
Pittsburgh
This thread is absolute hilarity. Seriously, All these specific hammer suggestions....come on guys. I am a 30$ an hour Porsche master tech and you know what hammer I use for "suspension" work? A 16 oz. ball peen and, in occasions when load is needed, a 36" pry bar. It is has nothing to do with the transfer of force, bot more to do with frequency. To match the resonate frequency of your metal at or rust depending on circumstance; allows for the ease of smooth removal of suspension components. Also I work in the rust belt and haven't touched my torches except for that on car who lived in mud for ten years. Learn to swing the damn thing.
Just my two cents, usually worthless. Actually, always worthless.
Finky198
North East
That's exactly the issue you work on shinny Porsches...
And we mostly work on rusty you know...
My 16oz DB Ball peen is mainly for bench work and some light duty assembly... Here in the rust belt working on used jeeps, trucks and equipment u need very different set of tools. Especially Big Hammers.
KraftwerkMk1Jetta
Long Valley, NJ
Exactly!
W
winlinmac
USA
Being in the Northeast, along the eastern seaboard, you don't want to know how much rust forms on the under-bodies of these cars a well, especially after the winter months. :lol:
MikeF2316
Thornhill, ON
I can't believe that nobody has suggested you need at least 20 hammers of various configurations and weights. :lol_hitti
I'm not flat rate, and I'm mostly working on my own stuff, so doing no damage is priority one. So I generally start out with a 12 oz ball peen and move up in weight as required. I also find that the European brands tend to have more rust resistant bolts that come out with less bashing.
redwrench60
East Tennessee
Simple answer: 32 or 40 ounce dead blow ball peen hammer. Read on for more or stop here.
I like the heavier weight ball peens with longer handles from Trusty Cook. Lots of power potential there for dislodging stuck drums/rotors/hubs/ball joints/tie rods. Since they're polyurethane overmolded steel hammers they shrug off over swings and collisions that would ruin wooden handles and they're solvent/oil resistant.
That short drilling hammer you bought is only for punch and chisel work. It's heavy head and short handle will get your fingers and hands smashed on a neighboring part when you start swinging. You want a longer handle for swing power and it gets your hands out of the danger zone. You ever see people who always seem to have black thumbs or fingernails from hammer strikes? Chances are they are using the wrong hammer type or weight for the job.
Engineers hammers are for really going to town on some heavy piece of machinery or bent part.
Drilling hammers are only for punch and chisel work.
Ball peens in several weights satisfy work ranging from delicate gunsmithing and bench work all the way up to heavy suspension work and fabrication.
Claw hammers are only for carpentry and building trades.
Fedwrench
Valley of the sun
If you're unsure of what hammer to use, perhaps working on yours car's suspension should be left to skilled professionals:lol:
On a side note, many late model vehicles have aluminum suspension components to save weight in the dash to meet fuel economy standards.
That being said the appropriate puller may be better to have than trying to beat a part into submission.:beer:
lilredex
Toronto
This is my go to hammer, when facing a tough job. It is a Blue Point 48 OZ that was given to me with a broken handle in 1956. It was my first (salvaged) rehandled job and is still going strong. That 1 1/4" square bar was acquired shortly after, and, those ends are usually better dressed.
kythri
Lebanon, OR
So, in this context (automotive suspension), why a dead blow ball peen over a dead blow flat/flat?
What on a car suspension are you going to be peening?
byoungblood
Berryville, VA
When I did work on the axles of my Wrangler, a steel faced dead blow was my go to hammer of choice for getting tapered joints free. I have a mini-sledge that sees occasional duty when something needs heavy duty persuasion, but usually the dead blow gets the job done.
W
winlinmac
USA
Well, I'm only using the drilling hammer for punching out the pinch bolt in the upper control arms area. I see DIY enthusiasts using either drilling or ball pein hammers. I have 32, 16, and 7oz ball pein hammers, where the 32-oz should be more than adequate in helping me remove the pinch bolt. The pinch bolts are notorious for seizing way before its due to replace the upper control arms.
Moose-LandTran
The Brink of Insanity (England)
I'm pretty sure just about any hammer is suitable for hitting an 8mm pin punch with for that bolt.
Good luck with it, seized ain't the word, at my old place we had a special jig to clamp the hub in to drill that bolt out with a milling machine. We just cut the arms off to remove the hub.
I do most of them with a special adapter for an air hammer, but have had to replace entire hubs due to those seized bolts.
redwrench60
East Tennessee
Nothing that I know of, but being prolific and multipurpose with a compact head, excellent power and swing control makes them well suited. They also have the required hardness for striking harder objects.
That said, there aren't many commonly available flat flat hammers with compact heads and long handles that swing like a big ball peen. That is evidenced by the excitement with Trusty Cooks soon to come out flat flat series. I'll be ordering some too.
mdtaylorjr
I work on cars all day long and the best hammer I've ever had is a snap on hbbd series 32 oz. Its heavy enough to get a good impact and light enough to swing freely. Can usually knock a ball joint out with 2 or 3 swings
Farmall450
Marengo, Illinois
That is a drilling hammer. An engineer's hammer is essentially the same thing, except with a longer handle. I find the longer handle just gets in the way.
They're designed to be used with punches and chisels. I've got a couple of the same Estwing drilling hammers (and being a huge Estwing fan, I don't think you can find a better hammer in that format) and am happy with them. But I usually reach for my 32oz deadblow ball peen first. I feel that I can get most of the same impact out of it, with only a fraction of the stress on my arm (wrist and elbow especially).
Eh, hard to beat the leverage you need from an engineer's hammer (mini sledge).
OP, the hammer you really need is an air hammer. :pimpflash
Finky198
North East
I'd say the real key to using any hammer is proper hand position, and using the thumb to guide the swing to the target.
I personally find the peening side is great when you try to strike an area smaller then the flat face of the hammer or when the area will not take a hit from a flat object say a curved part...
I think it's the choice of most more due to versitiliity of the ball peen hammer, rather than a dual face esp if you all ready own multiple size BP hammer as most of us do. The dual face has becom somewhat dare i say obsolete... The same goes for dual headed axes which are great for chopping down trees by hand. When you dull the first side you can flip it over and keep on working, but fortunately times have changed and chainsaws now do most of the work. So there's a much greater need for a std multi purpose axe... Which can chop and pound wedges VS the good old dual headed axe which can only accomplish one task chopping...
Best advice I can give is, use the Tool that gets the job done and makes "U" happy. :willy_nil or puts a smile on your face. :evil:
Jesrf
Detroit
Who's the OEM for Craftsman Engineer's Drilling Hammers? Vaughan?
spin_prod_1080145312
spin_prod_1081914512
7 years later- yes, vaughan made all the craftsman hammers of that era- they recently discontinued the fiberglass handles engineers version (the red one in your pic) here’s the vaughan version to compare—
southalabama
Brewton AL
The claw hammer has done more automotive work than the “proper” hammer. If the head isn’t big enough turn it sideways.
Ole Slewfoot
Freedom, CA
No matter how I hold the claw hammer, an 8 or 10 sledge gets the message across far faster.
I use the brass one quite a bit on little girlie cars.
And a 3lb cross pein with a 4" handle in restricted spaces.
But my favorite is hitting opposite sides of a taper simultaneously with 2 hammers so the stud can just fall out. (Easiest with 2 near identical hammers)
Death Row Dave
Home
The first hammer pictured is what I used to caulk , joints in large bell and spigot cast iron pipe . The shape of the head allowed me to strike the joint and not damage the pipe .
richfinn
Leeds, Yorkshire, England
Bit late for the OP, but I think this one makes a good alternative to a regular 32oz ball/pein hammer for automotive work (I almost never use the ball anyway)
It's dead blow and the soft face is replaceable, the large size is just under 32oz
Much cheaper than Snap-On etc.
qqzj
The best hammer is zero hammer for cars. Get the proper pullers. Avoid using hammers, pitch forks etc. There is always a better tool out there. Just spend the money. I got a pair of these, mostly hitting stuff with a block of wood in between. These are essentially dead blow hammers.
While I leave my real hammers this way
M635_Guy
NC
Dude - cars need hammers. Rotors get stuck, struts need help coming out of the knuckle (or going back in), etc.
And those are sledges, not a dead blow. A dead-blow specifically refers to the shot-filled head that nearly eliminates recoil and delivers a lot of energy to whatever you're striking. (What I posted above is a dead blow).
Odd-job
Do you remember where you got that one? It seems like everything on the Trusty Cook website is sold out and I can't find another source for the green version of this hammer. I really want to add one of these to the box.
I bought mine from JDC:
One of the rare times I paid full retail on something.
M635_Guy
NC
I got it from them directly when this was still a bit experimental - the TC guy hung around here and offered them to folks.
bubinga
There's lots of discussion of Drilling and Engineers Hammers and the terms being interchangeable. I recently picked up this hammer (pictured below), and am not sure if I purchased the right one. I intend to use this hammer in conjunction with working on my car's suspension when the time comes. Thanks
This was Inexpensive I paid like $15.00 My tools were in storage, and I needed some tools when I had an incident with my car. I paid only $15.00 with prime shipping In July/2021, But it's $24.00 and $7.00 shipping now :(
This Wilton 4# bash is really nice, It was only $28.00 in 2018 on sale, But It's $83.40 now :(
