Lift modifications Thread- Lets see them!
TerryH
Springdale, AR
Whats going on with the steering rack mounted so far back?
It's a center steer rack from RRS (Revelation Racing Supply) out of Australia. 2.5 turns lock to lock. The rack bolts in the same locations as the original steering box and pitman arm and uses the stock Maverick inner and outer tie rods. The front and rear suspension is all from them. Strut front with reinforced control arms, C5 Corvette brakes. Rear is a 3 link/torque arm with QA1's, Wilwood brakes. The 9" is located with Mumford links instead of a panard bar or watts link. 3 extra crossmembers that stiffen the car significatly. And it all bolts into the car. The crossmembers all have big doubler plates inside the floor. You can see the added front torque arm crossmember in the pic in the original post. The other 2 reinforce the floor for the coilovers in the rear and mount the Mumford links. It's a pretty wild setup.
Link to the RRS website
racecougar
Missouri
Ah frame cars, we call those trucks here ;)
Not sure the DMV would agree with that statement. I know MO doesn't offer 18k plates for my Skylark.
I have a piece of thick c channel I use across the tops of the jackstands if needed.
That certainly can work if you have suitable locations where the frame rails are the lowest component.
I'm all about finding ways to get by, but I'll say that after a year of sketchy lifting using the jack tray, I went to bridge jacks, and my only regret is that I didn't do it sooner.
Paul_VR6
Oxford, Pa USA
Bit tongue in cheek as the only things out here that have frames that aren't rusted out are trucks!
Agree on the bridge jack, definitely worth having!
TerryH
Springdale, AR
Reminds me of a old GM N-body center take-off R&P.
Might be for clearance issues with the front sump oil pan.
Not sure of his train of thought but it does work to clear the rather large Champ T pan. And it uses the OE maverick inner and outer tie rods.
Diesel Dan
TN
It'd take some out of the box thinking to get a power R&P on my Monza too.
Restomod68
There's some really interesting and clever ideas here! I especially like some of the adapted lifting hoists on the 4-posters. That gives me some ideas.
Something I didn't see here (unless I missed it) was alternative uses for a 4-post for work space. Anyone with a small shop/garage repurpose a 4-post lift for a liftable work and/or storage space with a work bench? I have been thinking about something like this until I get a new shop built. Would be a little clunky to step UP to, but if you're desperate for space, it could serve as a great flexible option.
I know for my lift, Advantage sells a solid Deck mod for multiple options, boats, ATV, Mowers, storage space.
Skellyii
KC Area
Jeez!
At that price, I would think I could either make my own, or have a local shop create one for less.
marquess
I'll do a second post for the gantry beam, as I can't figure out how to load a second photo in the desired order.
Make that a third post while I revisit that first post that didn't survive posting. My text commentary was that I made some swivel adapters for when you can't quite get the lift arms past an obstruction like a tire. One pair is shown in that photo.
marquess
Third post for second lift mod. I made a gantry beam for over 10' of lift clearance. It sits on the top of the lift carriages. I store it on two little rolling dollys and for installation use the lift arms and slings to pick the beam up high enough to sit on a pair of stepladders (the 4' orange ones in the photo). I then drop the lift arms and pivot the beam ends over the top of the carriage weldments one at a time:
gregs
How do you have it attached at each end?
FTG-05
TN
Pics of the i-beam connection to the lift carriages?
Thanks for posting!
sjvicker
SW Washington
If anyone has this style of lift with the detent in the sides, here is how I mounted unistrut on mine to hang utilities.
on the top the unistrut is bolted through the bottom bolt of the upper post assembly.
On the bottom its secured with a 1/4-20 bolt that is below the carriage when its all the way down.
cpakalolo
AS the person that started this thread....I ask that we please keep this on topic.
I am not trying to argue if mods are safe or are not. I am just trying to document the mods that people have done. The direction of this thread is starting to turn in toward that ugly place that many internet forums tend to go and I want to prevent that.
So if you have mods, whatever they are, please post pics here. If folks want to debate those mods, please open your own thread.
Now let's get back on track folks with some photos. :thumbup::thumbup:
Now I have used quite a few 2 post lifts in my days. I used to build custom cars and trucks for a living to include custom suspensions (static and air) as well as complete custom paint. I am not a stranger to the 2 post lift at all. I also used them at the auto shops on base during my service to the USA while fixing my own vehicles.
I make no claim that 2 posts are not safe in general. I just want to see all the things folks are doing to theirs and hopefully have a one stop thread for all things lift modification.
I signed up to this forum specifically to look at other people's mods. We can learn from both good and bad advice if we know the difference. Thanks for your starting of this thread.
cpakalolo
Great idea.
I feel that the extra bracing up high is very valuable. The top rail stabilizes the need for the two towers to lean toward each other. If you braced the top, it could be braced in the fore-aft direction too. A little bracing up high can make one a little more confident in their lift.
dante2
Central OK
How good does everyone think this would work with a pallet rack beam and at most 200lbs? A little bracing on the ends to keep it from tipping to one side or the other and it already have the overhang to drop into the carriages.
marquess
Thanks for posting!
Sorry, I only now noticed these questions. Oops. I see there is a "receive email notifications" option that I have just now enabled.
The beam is held in place by gravity only. There are two flanges bolted on to positively retain the beam ends on top of the carriage weldments, as shown in the two photos below (taken with the beam in its usual resting place on dollys under my welding table). The semicircular cutouts are clearance for the hydraulic hose fittings on the hydraulic rams.
The separation between the two carriages varies about 3/16" from fully down to fully up, so I had to plan the distance between the two flanges very carefully (which is why they are bolted instead of welded). As it happens I got it exactly right on the first try.
marquess
I would do a beam calculation; there are online calculators for standard size I, box, and channel beams. Just plug in your beam type, the span, the load location (point load at center of beam). I don't remember which one(s) I used, but there are many to choose from.
A commercial pallet rack beam for a comparable span can probably handle quite a large point load in the center, several thousand pounds, but it's easy enough to check.
Make sure the parts that hang into the carriage weldments don't hang up on anything anywhere during the carriage travel. After my first test fitting I had to enlarge the semi-circular cutouts to avoid any risk of contacting the hydraulic fittings. With a heavy load the beam could easily have broken a fitting off, which would have been fun as well as making a big mess.
Also keep in mind the total weight of the beam, as with my design I have to muscle it around a little getting it on and off. The lift won't care but you might. I had to pass up some prospective beams as too heavy.
zaius
Stupid question: For those screwing on outlets onto their lift posts, what did you use to drill out the hole through that thick metal plating?
Any special bit or will a standard carbide work without much slipping? Did you guys use self tapping screws afterwards or nut/bolts?
Thanks
TurnipTruck
Southcentral Alaska
I used ordinary hss drill bits and drilled and tapped for 1/4-20 bolts so there wouldn’t be any protrusion inside, and I took additional care to stay out of the path of the carriage bushings. The post steel isn’t anything special.
I suppose that fine thread self tappers designed for thick metal would work, IF you took care to snap off the excess length.
grabeb
I have a 4 post, so I used sticky double sided tape and put it up under the ramp. Then zip tied the cords up neat.
dante2
Central OK
got a 3.5 inch on my hemi right now and its dialed. way better than the 2 inch i had before. makes a huge difference for clearance and the ride feels way better too. hellcat one is sitting on something ridiculous but thats just for show lol. what lift you running?
Relax
GTA, Ontario
I may post a separate thread, but since I'm in here, is there a way to use a 4-post to lift a car like a 2-post from the frame rail lift points? I'm imagining some arms that are hung from the runways. I'd like to be able to do an EV battery exchange, but the battery is wider than the space between the runways. Also considering a C5+ Corvette, where some major maintenance is best done by dropping the entire driveline from underneath.
cpakalolo
On the four poster, the wheel bucket attaching to the side of the rail would not hold but a fraction of the weight it is designed for. If you have a cross-bar to stabilize them by rigidly coupling each axle pair, then it might work. The EV battery would drop down fore and aft of the axles, but fit between the ramps.
grabeb
The rolling jack trays would be my recommendation, but not sure going to accomplish what you want.
Relax
GTA, Ontario
I don't know what you mean about the wheel buckets, but the battery is wider than the opening between the runways of my HD-7W set to wide.
whateg01
doo dah, kansas, usa
How tall do you think a 4 post lift typically is?
Relax
GTA, Ontario
I couldn't tell you how about the typical height, but my Bendpak HD7W Rev M posts are over 8' tall and lift height is about a foot less. If you go to Bendpak's web site they have really good details on all of their models if you want to know if it will fit in your space, along with locking heights to see if your vehicles can stack.
whateg01
So if I'm understanding the question, the vehicle would be suspended from the bottom of the 4 post? That only gives ya a couple feet of lift. I guess it's no worse than a quick jack but far short of being about to walk under it
Relax
GTA, Ontario
Correct. I don't need to walk under it, I just need to lift it enough to get a dolly under the battery to drop it out and wheel it out (and a new one in). People do it on jackstands, but I'm too old for that. Subtracting the height of the car from the max lift height, it should bring it up almost 4 feet, and that's not counting how much of the roof fits between the runways.
Yankeefarmer
Connecticut
Think of the runways of your lift as being the ground. When you raise the car on the lift, it is like going under ground level.
Put the car on the lift. Then, using bridge jacks, jack trays, or other, raise the car off the runways, and use blocking to support the car high enough above the runways to allow the battery to be slid out from under the car, either sideways or out the end. Place some adequate crossmembers on the runways to support the battery. Work between the crossmembers to support/disengage/lower the battery. Once the battery is free and resting on the crossmembers, lower the lift to the floor and slide the battery out. Pieces of pipe work great as rollers for “sliding” heavy objects.
Go slow. Think everything through. I have never done this, so I might be missing something. But I have worked on equipment like golf carts and zero turns that were too narrow to fit on the lift in the conventional way. I put wooden filler pieces between the runways, drive the vehicle on from the side so the tires are on the runways, the raise the lift and remove the filler piece to access the underside.
Relax
GTA, Ontario
The battery is wider than the space between the runways, so it can't be dropped down and rolled out forward. And because of my garage setup with the mezzanine, there is no room to slide it sideways. Assume for all intents and purposes, this is a single car garage (10' wide) and the only way to remove the battery is through the garage door.
Paul_VR6
Oxford, Pa USA
Is the battery wider than where the jackstands need to be? If not just plan to drop the batt on the lift (use bridge jack to help slide it out). Not on the ground but at least as close as you can.
If the jackstands would be in the way, you could use wheel cribs at whatever height you need.
