Odd-job
Good idea. My fake Milwaukee pressure washer also has a misting function although have to figure out if there is a way to lockout the trigger.
Have two of the v1 rocket lights still going strong. These things saved my **** during a couple of long duration power outages we had out here in CA. I tend to haul around other lights for working on stuff unless its an extended amount of time. The rocket lights take like a few extra minutes to setup...I don't remember if you guys have talked about this yet, but...
2131-20
M18™ ROCKET™ Dual Power Tower Light
I have several M12 6.0 batteries that won't even take a charge, all out of warranty. I bought a battery spot welder and was going to open them up and fix them... eventually. Has anyone ever swapped bad cells out in their batteries?
That doesn't effectively turn them into 2.5s though right? The board is gonna control things the same either way?
Maybe we should request TTC do an episode on that? would be cool to see if the different boards in the batteries perform different with the same cells.It does.
The 2.5ah batteries have a higher amp output but supposedly less capacity. The higher capacity is why there are higher failure rates of the m12 3.0 and 6.0 batteries, as they are a higher stressed chemistry iirc. In real world use I think the 2.5 & 5.0 basically match longevity in use, while still having more oomph available.
Looking forward to your review of it.Getting their cordless air hammer, the videos of the tests done on it are amazing. Uses my regular air hammer bits
I watched the video MrSubaru1387 put out on it which he put it to the testMaybe we should request TTC do an episode on that? would be cool to see if the different boards in the batteries perform different with the same cells.
Also, I bought a M18 Packout Jobsite Fan, 0818-20 over the weekend. Info and initial review here:
Mike
I have this fan and it's great.The only three things I'd improve is:
1. Make it oscillating.
2. Build in a charger, so when it's plugged into electricity, you can charge a battery while running the fan.
3. Make the base smaller.
The improvements you suggest are trade-offs - it would be bigger, more expensive, less stable, not fit Packout, or whatever. And then a bunch of people would complain about that.
pretty sure that holds the nozzles for the spot blower.can tell me what this is for
That makes sense. I pulled one out and tossed the package in my box and haven’t touched it since.pretty sure that holds the nozzles for the spot blower.
Hey I am sort of located right in between Napa and Livermore conveniently!
Perfect!Hey I am sort of located right in between Napa and Livermore conveniently!
Not sure if this qualifies me as an addict yet, but I may be on my way. I don't plan on migrating all my cordless tools until such time as they die.
