- Joined
- Nov 4, 2017
- Messages
- 10,484
OTG, I need some education here, What is it?Snagged mine for 10$, then felt a bit guilty the seller did nor know what it was.
No - only $1! (Which is only 25¢ more than new ninety-five years ago.)Was it to much money to gamble on?
Thank my eyes were seeing the pit as a partial line for a 6 which my brain took as gospel.That’d be a 1955
shows in the 8/29 catAnyone have a reference for a 7/8” drive of this era in 2 1/4” hex?
I made that connection a few years ago, empirically, here...My understanding of the gripper stuff is it was supplied by lauber.
Does anyone have any documentation that connects "THE GRIPPER" wooden tool and file handles sometimes found with Snap-on shanks (screwdriver, 9/32" spinner) stuck inside of them with the Snap-on Tool Company? Reason I ask is, I am doing some re-organizing in the Lugzsonian, I came upon my box of antique and vintage file and tool handles, and I have one called "THE LAUBER." As you can see, it is made exactly like "THE GRIPPER." Except for the name.
...and I still have an extremely high level of confidence in my deduction, but I have not been able to confirm it with independent documentation.Here's an ad from a 1920's trade mag. The design is patented. So theres no way Snap-on made them. Now look where the Lauber Company was located. I'd bet not only my next paycheck, but every paycheck until I retire, that I just discovered who made Snap-on's early radio set handles.
Thanks for posting. Clearly expands the local principle.Not exactly Snap On but pertinent to handle sourcing in Brewtown.
Reminds me of this driver many of you have… or Walker Jacks of Racine using Milwaukee’s American Grinder. / Blackhawk 1920’s sheet metal hand grip patent on their jack handles.Not exactly Snap On but pertinent to handle sourcing in Brewtown. So a Lauber style handle is clearly visible in a 20's era MTF catalog and still shows up in a 31 cat as well thou in both it's a screwdriver while the bearing scraper illustration looks like a more conventional handle. Anyway, make of that what you want.
Dang, nice find on this carb set!I found this the other day, while flipping through FBM
he had it listed as a tap and die set oddly, and while there was most of one in there among all the other stuff
there was what appeared to be a mostly complete, late 40s early 50s carb repair set
I had to add the ratchet and spinner from my stash, but I am not sure if the Carter carb parts where sold by SO as part of the set or not. The '50 cat sure looks like it, but earlier cats don't show those parts.
it even has some of the remaining decal left. Not sure what I am going to do about a key yet.
Can't ignore that little Plomb ratchet, very hard to find. Did you get lucky and find a functional one?
Yes, the 4951 is a hard one to find for sure. The ratchet seems dirty inside so I will clean it up and then see if it works any better. It’s not bound up but also not great either but it also feels dry insideCan't ignore that little Plomb ratchet, very hard to find. Did you get lucky and find a functional one?
