Walmart Getting Serious About Tools in 2026?
Steel_Rain
To each their own, but seems like less hassle to just open it up and turn the button slide thing around.
Like you suspected, it was just installed backwards:
I guess it would have costed an extra .01c to mechanically key this to prevent incorrect installation 🙄.
Anyway, torx screws and decent guts for a $45 installation driver:
All fixed:
BlakeTheCarGuy
Roanoke Virginia
I did a lifetime warranty on a plier from Popular Mechanics bought at WalMart. Pop Mechanics magazine directed me to the mfg of the tools, Test-Rite, who gladly did a warranty exchange in 2006. The only catch? The replacement tool said AC Delco.
Nice. I always heard the tools were made by Stanley but I guess manufacturers could have switched at some point too.
willf650
I did it so you don't have to and bought the 1/4" ratchet. Most of the stuff I work on at home in my shop are motorcycles and a 1/4" ratchet is more appropriate than a 3/8 ratchet or impact.
I will say once again this seems to be a great tool price considered. The difference in price wouldn't be as much of a consideration for someone who uses this tool professionally.
The ergonomics are about the same as the 3/8" fuel I have but it's my understanding they aren't the best as they came out with a gen 2 Milwaukee that's supposed to be better.
The Milwaukee trigger is linear in comparison to the Hypertough. The Hypertough feels like it has about 6 steps in speed and not linear in comparison.
Power seems adequate for a 1/4" but I tested on a motorcycle lift lifting myself up. This lift is what I use my 3/8 ratchet for most often and performance is comparable lifting me but most of my motorcycles are more than twice the weight.
As a casual user this ratchet is a slam dunk. If I was using it for a living I would probably compare it to others.
whateg01
doo dah, kansas, usa
It's too bad all of these 12V lithium systems have proprietary battery cases. They are all the same basic shape. I bought a workpro 3/8 ratchet and it works great for my use. I bet that Walmart one will do fine for a lot of folks.
Steel_Rain
Wanted to give a shout out to HT for this EDC light:
I really like the form factor and light quality for $15 bucks. The belt clip is a nice touch and lanyard hole is decent:
Size comparison with some others in inventory:
zktk01
KY
I just bought a 3 piece Pry Bar set from Walmart I think they are made by Wilde in Kansas. I would never invest in any Battery system from Walmart
though, who knows how long that brand will be around?
willf650
For the price it isn't much of a risk. The tools with the battery are priced cheaper than just the battery of the "name" brands.
It's been my experience batteries seem to last 8 years before they go caput at this point so for the price it may be worth the risk. I'm sure use dictates life but the last "name" brand batteries I had die were Bosch 12v. Still using everything else since I retooled.
Did feel left out to dry when I went hitachi Lithium 18v and they dropped the battery platform and left me out to dry when I needed replacement batteries.
The battery powered Hypertough tools I bought seem awesome when you consider price. When you consider just ultimate performance the M12 stuff I have wins handily.
willf650
The Walmart honeymoon is over. I actually used this ratchet today and the paddle popped off on me 3 times. It’s easily popped back on but realistically shouldn’t need to be. I suspect this can easily be remedied by popping out the pin it sits on and putting in a roll pin that is longer but this shouldn’t need to be done in the first place.
