Can you identify this machinists tool
snyder
Baltimore md.
Saw this at a friend’s garage today. Can you identify it. I’ve never come across one before.
The massive micrometer thing in the back? It is a super precision gage, where each big lump on the shaft is a precise inch apart, then the top knob only adjusts 1” total, add the big lump count to your thousandths of an inch from the top, and get a tall precise measurement.
Will see if I can find a part number. Digi check 258
Firebrick43
West central Indiana
I am going to guess, so don’t laugh at me.
It is something that was very very expensive. And CNC has made it mostly obsolete.
Am I close? What does the label say (besides Starrett)?
Obsolete on the shop floor but not by CNC. The style of the gauges changed and instead of a surface gauge used in conjunction with the gauges they are direct reading now.
Around 1500 dollars for a 24"
About 8500 dollars if you have the air suspension to move it on the surface plate or 7500 without.
The type of height gauge shown by the OP is not usually on the shop floor anymore but is still sold and used by the metrology labs to check other gauges and standards against.
A 610mm (24") is 16,000 dollars
I personally have an old brown and sharp 12” height gauge that lives on my surface plate.
RoninB4
Under My House
-If you've never had the need for one then you're simply not familiar with what it is. Anybody that would laugh at you for that is an idiot.
-They were (pre 1980's) because it was the only affordable means of obtaining accurate 4 place (.xxxx) dimensions larger than a stack of gauge blocks and easier to use than a micrometer for accurate numbers. They were used with a surface plate (for "zero" reference) and an indicator. There were a few different makers/models with different features (and priced accordingly) and different heights. The earlier models were like the first two shown (Cadillac PLA-CHEK) that had a shaft with only a single surface (top of disc) for measurement. A small "horseshoe" device was available to clip on when needing to reference a surface underneath instead of on top. A later design (Mitutoyo was first that I recall) used a different (and more expensive) version similar to the Brown & Sharpe model @Firebrick43 posted above. This version has two surfaces for each 1" range to use for over/under and requires no "horseshoe" attachment for an underneath surface reading. The single shaft design became a dated but less expensive option.
-It's a dated design but I wouldn't call it obsolete and certainly not by CNC. The electronic models may have replaced (new toy syndrome) the mechanical type in the inspection dept. (data logging) but many people still use/prefer the mechanical design. The CMM (coordinate measuring machine) also drew favor with QC people but the simplicity, cost, and footprint of the mechanical types is still favored by many. I have a couple of different height models (smaller is easier to use) and prefer them over an electronic model or a CMM. What others prefer largely depends upon what you need it for and how accurate you need to be. All three have advantages and disadvantages.
Am I close?
-As close as a non-shop person (civilian) would get, you did ok. Asking questions is how we all learn.
-There's a few other makers besides Starrett, they may have discontinued theirs. Sometimes called a Height Master but that name will usually bring up the Mitutoyo model.
GrayFlattop
Chicago
+100 for a C.M.M. Which can do a whole lot more than the height gage. Of course a good one will cost a whole lot more. The last one we bought at work was six-figures.
JuncleJohn
Omaha, Nebraska
They’re still very handy. I have a Mitutoyo version that I have used extensively for reverse engineering and QC work. Today a coordinate measuring machine is far more versatile and quicker.
John
RoninB4
Under My House
+100 for a C.M.M.
-The 100 is the multiple of the cost of a simple height master.
-It can do some things but it can't go out to the shop floor, or have a small footprint, or be "zeroed" out (calibrated) by anyone in the shop, and it might not even be capable of 4 place (.xxxx) dimensions that are trustworthy. Special probes are also sometimes needed for it be useful. A CMM can be easily ruined by untrained maintenance, requires clean/dry air to run, and is a permanent installation. They all have advantages and disadvantages. Higher tech and greater cost does not always mean it's better, it's just another tool.
-They are beyond the financial budgets of most small to medium shops
-I've used several and do like mapping with them but they're not always the right tool for the job. The last Mitutoyo CMM I had at work needed servicing, my Mitutoyo Height Master only needed a minor adjustment for zero when I brought it in.
GrayFlattop
Chicago
I’ve gotta disagree as well as agree.
Surely they are not portable, they require a controlled environment as well as well trained and well paid) technicians. If you just need to check simple dimensions, a height gage is fine and is much more appropriate for a small shop. As you noted, they require dry air (refrigerated air driers are just a start) as well as deep pockets. But they were far more repeatable than anything else available.
Manual CMM’s lack the repeatability we needed.
We ran 6 Mitutoyo CNC CMM’s of various sizes and all of them were calibrated every 6 months or so to NIST / ‘ISO standards. Three of them had full contact scanning capability. They could all resolve to four decimal places repeatedly. Once you had the program written and the correct touch probe selected, it was the perfect tool for our world. You could measure diameters of a bore, concentricity, circularity, taper, etc., all in one shot. Measurement of multiple holes on a flange on a bolt circle or the relative position of other features to a datum - easy peasy. Flatness, parallelism, check. Output the data for statistical analysis, done.
We used them for first piece approval, in-process inspection & final inspection of production components and occasionally to verify dimensions of tooling.
Certainly not for every application or every shop, but they do represent some of the most capable instruments available if you are producing parts for the automotive or aerospace sector.
BTW they wear out and have to be replaced every 15-20 years if used in a busy 2 or 3 shift shop.
RoninB4
Under My House
-That's ok, I gotta agree and disagree with you too. Different circumstances often produce different perspectives.
-A repeatable reading is important but not the same as accuracy
-Different operator, different "touch" can/will do that. I don't diminish or disregard the consistency a CNC driven CMM can offer, particularly where multiple geometric features need to be verified across multiple shifts/operators.
-A good practice to have periodic calibration when expensive contracts are at stake. I'll presume this was the setting for your facility.
-Resolution is the smallest value something is capable of reading and discerning between two different values. Precision/repeatability is important for consistent readings. That's not the same thing as accuracy, reading to a true value. You may have had calibration to NIST/ISO standards but that still doesn't speak to what tolerances were part of that calibration. Calibration for a yardstick isn't the same as for a DTI. My first exposure to a CMM (1987) was a Cordax, don't recall the model. I was hugely impressed with it until I found variations during a 1st piece approval. I asked the inspection dept. about it and was assured it had +/-.0003 resolution. A week later a Cordax tech had come in so the question was put to him. Apparently the CMM was only capable of +/- .003 (or so) accuracy for mapping distances. Yes that was quite some time ago and CMM's have vastly improved but my point here is that while precision and accuracy are both important they are NOT the same thing.
-No question about that. A programmed CMM will blaze through a multi dimensional inspection while I'm still setting up on the surface plate. The speed, especially for repeat checking of a batch during the run (tool deterioration) is a huge factor for QC. The capability of data logging is also quite important, especially when a part fails and the finger pointing begins. It may not sound like it but I do have a great amount of respect for the technology capability and what it can bring to manufacturing provided it's applied properly.
-Sure, I'd choose to use a CMM to map out a plate when drawings/CAD files weren't available or even use one to compare when dimensions were available. Reverse engineering with traditional instruments might take hours where a CMM could be done in minutes. My point is that I already trust my instruments to a defined level of accuracy, the accuracy level of a CMM would have to proven to me before I'd trust it. Every measuring instrument has an amount of acceptable error. An unofficial guideline from aerospace was your instrument should have 10x the accuracy/resolution of the target dimension tolerance you were seeking. Overkill? A bit, but the intent was to negate any error in the instrument so the reading could be considered trustworthy. Every measuring instrument has a margin for error at some level, even an expensive CMM.
-But vital to others. I'd speculate that there are some CMM purchases out there that are just the QC dept. validating themselves through company expenditure, the "new toy" syndrome. Others leap at technology as a panacea for problems they're not able to solve. There certainly is a place for CMM's, an old tech Height Master and an indicator has a place too.
-They can sure help secure a contract for aerospace, DOD, or DOE work. My indicators and Height Master certainly wouldn't impress. I did defeat an entire engineering dept. and their laser/optical equipment readings with just an indicator years ago, maybe I'm still too impressed with that incident. Maybe I don't have access to a nice CMM anymore. :sad:
-So let's buy more than one and keep it for a spare? Thanks for posting your experience, I'm out of the technology loop now.
bugnut
Central Ohio
I'll start popping the popcorn and just drop this off here.
welcome to 1984, it ain't necessarily so.
Mil spec/ISO standard cmm accuracy in the 80's was beyond a cadillac gage of the same timeframe. Spending a few years doing GRR reviews/studies and Mil aerospace work would differ. Car parts, not so much.
freearm, in use today in shop environments are capable of measuring to an accurracy often quoted to +/- .001"
Argue away.
