Which Pass Thru/Go Through Sockets/Ratchets Swap/Interchange?
retDAC
near Huntsville, Ala.
Added 12 Aug 24: The main point of this thread is if you need to replace/add something and you cannot get it from the brand you have, you might find it under another brand. Also there might be NOS on Ebay or Cripe Distributing.
An example: last year I needed to replace Craftsman (Sears) 3/8 in. drive (equivalent) bit adapter socket. While Sears still has some NOS under Max Axess, this socket was NLA and Gearwrench no longer lists it.
I found a Crescent set with that socket: X6 3/8 in. Drive Pass-Thru Universal/Spline Standard SAE/Metric Ratchet and Socket Set (25-Piece), Model # CX6PT25. Yes a small set just to get that socket. Oh well now I have some extra if I lose another Cman piece.
Another example: This fellow wanted to fix his Cman Max Axess ratchet but no kits are available. So he bought a Gearwrench (Gearratchet) for ~$20 and swapped parts:
Original:
Actual list in post #2. BOTH Brand AND Line Names do matter for swapping as some line names are the same in various groups. Also Kobalt, Husky, Matco, Clarke Tooling, Hazet, Kincrome, Snap-on, SAM Tools, and Sealy each have two different systems listed.
Most brands of Pass Thru sets label them as 3/8", 1/4", or 1/2" Drive. This refers to the range of socket sizes for each of those and IMHO, it should be 'Drive Equivalent'.
Within it's group (subgroup under B and F) and drive size (equivalent), everything interchanges perfectly. I spent a lot of time looking for and at pix and reading. Went to local big box stores as well.
Examples:
All the A's swap. I even have some GW, Cman, and OLD Kobalt Flex Thru in both 1/4" and 3/8". The 1/4" all swap and the 3/8" all swap.
But Group A and Group B won't. I have a B1 Ampro 3/8" kit and it's different.
B1 and B2 and the other B's maybe but I can't be certain. Took an Ampro socket to Lowe's and found a ratchet loose where I could actually try my socket. and it worked but the other way, say a Kobalt socket into an Ampro ratchet, the socket will fall out. otherwise it will work. Even though the drive hex is basically the same, there is a difference in the way the socket is retained. I found 5 different designs on the 'net for socket retention, all using the same basic hex drive. Thus the B 'subgroups'. The Williams and BluePoint would have made 6, but they were deliberately changed to make it impractical to swap sockets with any of (my) group B's so I put them in a completely separate group.
This list is only for socket interchangeability if any - not usefulness, brand quality, COO, price, or 6pt vs Spline as those topics have been debated elsewhere.
Included are discontinued lines, discontinued brands, and even companies no longer in business as well as brands not sold in the US. Oh yeah, I did run into a few no-name sets for A, but the ads literally had no brand name. Didn't see any point in listing those since you can't run searches for them specifically. "No-name" as in no brand name listed at all; not even a mom&pop token brand.
Air tools are not listed.
I was looking for some pass through sockets to augment what I already have. There are other threads regarding this topic, but they don't have everything in one list. For most I could only look at pix on the 'net, so if anybody posts a correction or addition with links/pix, I will be happy to change my list.
Obviously I 'need a life'. :sad: Already demonstrated that with current vise brands, Lumidor, and my Neiko Tools threads. Since I don't have one, hope some find this list useful.
Group A Notes
1. Some NOS for Kobalt Flex Thru at Cripe Distributing. Obviously made by GearWrench.
http://www.cripedistributing.com/kobalt-21-piece-1-4-flex-thru-ratchet-set-22353.html
2. Have not checked the others but Gearwrench and Craftsman each offer sockets, etc. individually. For example, if you lose a 5/16" socket you can simply order one instead of having to get (or rob) another set. My local Sears even has some open stock for Craftsman.
3. Some Gearwrench and KD sets may have line names differing from what I listed. I think the KD sets for sale are NOS. It's confusing but GW and KD are the same tools even if some of the sets have differing numbers of pieces.
4. The six lobe drive design prevents you from using a wrench with the sockets. So if you lose your ratchet, you have to get another.
Group B Notes
1. Have not checked the others but Kobalt offers sockets, etc. individually. For example, if you lose a 5/16" socket you can simply order one instead of having to get (or rob) another set.
2. Some of the Kobalt Xtreme Access, Ampro, and Goodwrench kits have an adapter that actually lets you use the sockets with a regular square drive ratchet! Kobalt used to offer it open stock.
3. Group B sockets can be used with the appropriate (preferably ratcheting) box end wrench if your ratchet is too big, broken, lost, or you're afraid of breaking it. The B1s even have a check ball which helps keep them in the box end.
4. The combined metric/SAE spline sockets in the Channellock Ultra Access, Ultra Steel Go Through, Laser Tools Go Thru, OLD Mastercraft Maximum Pass-Through, and current Kobalt Xtreme Access sets don't fit the smaller size well. An example of the 1/2"-13mm: http://toolguyd.com/how-well-does-the-kobalt-multi-drive-wrench-fit-hex-fasteners/ Yes that's a wrench but Xtreme Access includes various wrenches and regular drive sockets as well as pass thrus. Their splines are the same combo style throughout.
Group C Notes
1. For its current Blue Point and Williams pass thrus, it appears Snap-on used what is basically an existing B group line design. However it was modified so that none of the B group tools could feasibly be swapped even though the drive hex seems to be the same size as the equivalent B group drive size.
2. Group C sockets can be used with the appropriate box end wrench if needed. At least it appears you can get enough purchase to do it although it will fall out if you're not careful.
Groups D-I Note
Groups D-I sockets can be used with the appropriate box end wrench (preferably ratcheting) if needed. At least one, the Hazet 436 per #22 below (thanks CB), requires a 6pt, but I bet a spline will work.
Groups F-G Notes
1. These sockets are not advertised as pass thru but I included them because they could work that way when the bolt shank/shaft is small enough. These sockets/ratchets are actually for tight quarters use and all of them are low torque.
2. F1 & F2 sockets can be used with a 1/4" square drive ratchet.
3. The combined metric/SAE spline sockets in the Astro Pneumatic Close Quarter sets don't fit the smaller size well. HOWEVER, Astro Pneumatic does offer more accessories than Snap-on and Mountain.
4. Snap-on and Mountain offer sockets individually.
Group J Notes
1. Group J sockets can be used with a 16mm spline (preferably ratcheting) box end wrench. Won't work with 6pt or 12pt though. (I checked using a Titan).
2. Cornwell, Titan, & Kabo ratchets do not reverse. Powerbuilt & Fobi ratchets reverse.
Group K Note
Hazet 536 sockets use a 24 lobe spline drive which prevents you from using a wrench if you lose your ratchet.
Groups L-N Note
Groups L-N have a ratchet-gear-integral-to-socket drive design which prevents you from using a wrench with the sockets. So if you lose your ratchet, you have to get another.
Group L-M Notes
1. The sockets may swap between Armstrong/Matco and Facom/SAM but I can't be sure without samples so I put them in separate groups for now.
2. The Group L design is long obsolete so if you lose something, good luck finding a replacement. Group M may be as well.
Group O Notes
1. O-Ratchet uses a hollow hex drive lug/post which you slide the drive end of the socket over in the same manner as putting a regular square drive socket onto a regular ratchet. HOWEVER instead of a check/security ball, there is some kind of sheet steel? plastic? flanged collar you have to slide over the hex drive lug BEFORE you put the socket on it. If you don't have the collar, the socket falls off.
2. In all the prior systems, about half or more of the length of the socket is contained inside the head of the ratchet. Which means you can get the socket into smaller areas. Not so with O-Ratchet; it's completely outside the ratchet just like a regular socket/ratchet setup.
3. Another disadvantage is the 'through hole' is smaller than the better designs.
4. If you lose your ratchet, Group O sockets can be used with a hex (L style) wrench IF you have one big enough.
5. This design is long obsolete so if you lose something, good luck finding a replacement.
6. I think this was the first of the modern general purpose pass through designs. http://www.garagejournal.com/forum/showthread.php?t=103806&showall=1
R
retDAC
Interchange List
Group / Brand Name / Line Name (Group notes in Post #1 above)
A Boxer Go-Through
A Clarke Tooling PRO222 Go Through (PRO221 different = B3)
A Craftsman Max Axess: Sears
A Crescent X6 Pass-Thru
A Draper Vortex
A Duralast Pass-Through: Autozone
A GearWrench XL Pass-Thru
A Halfords Advanced Vortex
A current Husky Pass-Thru; Home Depot
A former Husky Thru-Ratchet; Home Depot
A JobSmart Pass Through: Tractor Supply
A KD GearRatchet
A Kincrome P2025, K2046, & K2047 Go Through (K2045 & EVA65T in B3)
A OLD Kobalt Flex Thru Lowe's
A Makita Pass thru
A current Mastercraft Maximum Pass-Through (not the same as Mastercraft Pass-Thru in B5.)
A MOB Tools Socket Through?
A Neiko Tools? Hole Thru
A Neilsen Go-Thru
A Omega Pro Go-Through
A PowerLift Go-Through
A SAM Tools Pass Through?
A SATA Pass-Thru OEM?
A Sealey AK6919 Go-Through (AK6927 in Group H)
A SIGNET VORTEX
A TOPTUL Go-Thru
A US PRO Go Thru
A Westward GearRatchet
A Wurth Zebra Pass-Through
B1 AmPro Go-Thru Hex Geared
B1 BGS technic Go-Through
B1 Channellock Ultra Access
B1 Clarke Power Products Open Center
B1 GM Goodwrench Go Through
B1 Jackway Go Thru
B1 Listol Go-Thru OEM?
B1 Performax Pass Through; Menards
B1 Pittsburgh Go-Thru; Harbor Freight
B1 Pro.Point Go-Through Princess Auto
B1 Power Torque go-through? O'Reilly
B1 Repco Go-Thru
B1 Ultra Steel Go Through
B2 Hexa Go-Through OEM?
B2 current Kobalt Xtreme Access; Lowe's
B2 Urrea GO-THROUGH
B3 Bahco Pass-Through
B3 BILITOOLS Pass Through
B3 Bostitch Pass Thru
B3 Hart Pass-Thru: Walmart
B3 HI-FIVE Thru Drive OEM?
B3 Kincrome K2045 & EVA65T Go Through (P2025, K2046, & K2047 in A)
B3 KS Tools Go Through
B3 Laser Tools Go Thru
B3 Mac Go-Thru
B3 Stanley Passthru (These are made in China; the others, at least Bahco/Bostitch/HI-FIVE, are made in Taiwan.)
B3 Teng Tools Push Through
B4 Connex Push-Through
B4 OLD Mastercraft Maximum Pass-Through (not the same as Mastercraft Pass-Thru in B5.)
B4 Proxxon ???
B5 Am-Tech Go-Thru
B5 OLD Husky Open End Home Depot
B5 Mastercraft Pass-Thru (not the same as Mastercraft Maximum Pass-Through in B4 and A.)
C Blue-Point Pass Thru
C Williams Bolt Thru
D Gedore 19 SK
E Hazet 436 (536 in Group K)
F1 Snap-on 1/4" Drive Low Profile
F2 Astro Pneumatic Close Quarter
F2 Mountain Close Quarter
G Spec Tools SqueezeWrench
H Clarke Tooling PRO221 Go Through
H Sealey AK6927 Go-Through (AK6919 in Group A)
I Mac Front End Alignment Flex Ratchet and Socket Set
I Matco Shock/Strut/Front End Ratchet and Socket Set
I Snap-on WA309FLA Alignment Set
J Cornwell Go Thru
J Fobi Through Socket
J Kabo Cross-Ratchet OEM?
J Klein KNECT Pass Through
J Powerbuilt Bolt-Thru
J Titan EXO-Drive
K Hazet 536 (436 in Group E)
L Armstrong Eliminator
L Matco Pass-Through?
L Matco Special Forces
M Facom Hollow Ratchet
M SAM Tools PTT?
N Reed Thru-Bolt OEM?
O O-Ratchet no separate line name
neophyte
Pennsylvannia
Re: Which Pass Thru/Go Through Socket/Sockets Swap/Interchange?
A pass-thru socket design you missed is the Facom 67 style which I believe has since been discontinued. I don't own a set myself so I can't check, but my understanding is that Armstrong/Apex/Danaher tool group may have licensed some Facom patents. The Facom 67 sockets are double sided, and the ratchet uses a different retaining mechanism, but like the Armstrong Eliminator/Matco Special Forces sockets, the Facom 67 sockets are toothed on the outside to directly engage the ratchet pawl.
This is the Ebay listing were I saw the Facom 67 socket/ratchet set. I stole a couple pictures of the ratchet and sockets from it to post here.
http://www.ebay.com/itm/FACOM-67-J3...t=Motors_Automotive_Tools&hash=item20d32aa5f7
US Patent, #5,857,390, with Carlton L. Whiteford listed as the inventor, appears like it might a patent for the Armstrong Eliminator ratchet/socket system. In the Reference section, the patent lists a French patent, #671630. I haven't been able to look up the French patent though. This is the US Patent.
https://docs.google.com/viewer?url=patentimages.storage.googleapis.com/pdfs/US5857390.pdf
A separate Patent assigned to the Hand Tool Design Corporation of Wilmington DE. ( a subsidiary of the Danaher Corporation, owners of Armstrong) also looks like it might be for the Armstrong Eliminator Ratchet/sockets. The US Patent is #5,901,620, with Robert L. Arnold listed as the inventor.
https://docs.google.com/viewer?url=patentimages.storage.googleapis.com/pdfs/US5901620.pdf
neophyte
Pennsylvannia
SAM Outillage/SAM Tools offers a few different pass-thru ratchets with sockets. Like the Facom one, I don't own any examples, but they look like they might be the same as some in one of the above groups. The three ratchets SAM offers are models R-152B, S-155B, and S-156B. The R model ratchet is for the SAM RHS pass-thru sockets and extensions which come in sizes from 4mm to 13mm. The S model ratchets are for SHS series pass-thru sockets and extensions, which are offered in sizes from 10mm to 32mm.This is the webpage that shows the SAM pass-thru sockets and ratchets etc.
http://www.sam-outillage.fr/catalogue-sam?view=cataloguesam&fam1=7&aFam2[0]=63335
neophyte
Pennsylvannia
MOB Outillage/Tools/Peddinghaus of France also offers pass thru ratchet/sockets and sets. The drive design looks like it may be the same as the SAM Outillage design. The French term they use is "CLIQUET À TÊTE TRAVERSANTE." The sizes MOB offers are more limited than those offered by SAM Outillage. The "medium" size sockets that are available separately are only offered in 10mm thru 19mm. MOB also offers a larger set that appears to have two different sizes of ratchets. the small sockets in that set are sizes 3.5mm to 13mm. The larger sockets are 10mm thru 22mm. This is a link showing the set.
http://ecatalog-mob.maqprint.fr/produit.php?pro_id=2638
This is the webpage showing the other sets.
http://ecatalog-mob.maqprint.fr/famille.php?fam_id=124
R
retDAC
Added.
Thank you again, neophyte. I was looking for brands in the US. Did include the few foreign brands I encountered. Do appreciate your efforts, especially with links so I can see for myself.
Left off my links to prevent crowding, but if anyone asks I will post whichever is requested.
R
retDAC
Added Reed and had to do some regrouping. Now 37 brand/lines.
For its current Blue Point and Williams pass thrus, it appears Snap-on used what is basically an existing B group line design. However it was modified so that none of the B group tools will swap easily even though the drive hex seems to be the same size as the equivalent B group drive size. In other words if you have a BP or Williams set and you lose something, you HAVE to go back to Snap-on for a replacement.
Chadwilliam1
Cincinnati
so if I am reading this right a craftsman ratchet will work with my gearwrench set?
very nice write up BTW.
jmm
NC
I'm subscribed. I've always wondered, and assummed, that my Armstrong set wasn't compatible with any other pass-through set. I'm still about 80% correct, but this is very good to know, especially since I lost a couple sockets...
Jbullfrog
Avoca, Iowa
What about the alignment ratchets? They are technically a pass-thru ratchet. I have a metric and standard set of sockets and a few different ratchets. I use them on combines for belt tensioners that are basically all thread with a captured nut.
xbeatles4x
Cutler Bay, FL
I have an am pro set and my ratchet broke and I have had a very tough time getting a replacement. If there was another rand ratchet I could get that would be awesome.
lok
Greece
One more option.
Gedore.
R
retDAC
Yes and thank you.
Btw, GW and Cman have open stock in case you lose something.
Also Cripe Distributing has some NOS old style Kobalt Flex Thru which is Taiwanese GW.
http://www.cripedistributing.com/kobalt-3-8-drive-ratchet-usa-22800-ro.html
R
retDAC
The Armstrong Eliminator and Matco Special Forces swap as listed. There is some NOS on ebay for the Armstrong Eliminator. Whoever made these, especially if a Taiwanese company, may still be making them under some other brand I haven't seen, but I don't feel like trying to find out. I spend too much time on this list as it is.
I do hope you find what you need on Ebay at least.
R
retDAC
Hadn't heard of them, but I looked them up. OOP with some NOS on ebay for Snap-on, Mac, and Matco, so I added them as E, F, and G. SO listed as 7/8" drive but the other two not described adequately so I don't know if any of these swap.
Btw Mac and maybe SO have some NOS open stock.
Hey next time links please!
R
retDAC
Have you contacted Ampro?
http://www.ampro-usa.com/ContactUs.aspx?strFromURL=Contactus
What did they tell you?
What drive size equivalent ratchet do you need?
What's the part# on your ratchet?
What is the kit/set#?
If you don't have know your drive size and you don't either one of those numbers, then what is the size range of your sockets, either SAE or Metric?
R
retDAC
One more option. Gedore.
Done as D on the list. Pretty pic and next time please give me a link so I can check easily. This list is not merely brands but which ones swap easily or partially. Gedore apparently uses a unique 1/2" hex so it's alone but at least you can use a 1/2" box end/ring spanner if the ratchet breaks.
lok
Greece
Yes you re right. Apparently you found the link but here it is.
http://www.gedore.de/en/products/article_details.html?oe_opt[list_set]=146747,136230,136283,136284,141247
Or a ratcheting wrench with a swivel head, or stubby etc.
R
retDAC
Had to look at several different sites/pages to see what the drive looks like and find a description. Never saw pix adequate to show exactly how the socket is retained in the ratchet. Finally read somewhere about the 1/2" hex drive. At least that is unique so I could accurately place it in its own group. There reason I didn't simply add a new group for it at the end. These Gedore sockets can be used with box ends and etc. as you listed. I keep all those type groups sequential so one can simply remember B-G sockets can be used with box ends, should anybody ever care to know.
Otherwise interchangeability is not just the socket drive shape but also how it is retained in the ratchet. The various B groups may switch but I can't be sure without samples so I listed them in subgroups where obviously the sockets, ratchets, etc. would swap. 'Obviously' when I could find an adequate pic for a given brand line. Takes a lot of time for all this.
cosmik binturong
.fr
incomplete Hazet 436N/11 ratchet and 12-sided pass-through socket set:
edit: the forgotten pic!
if you need more, just ask... :D
R
retDAC
That is tremendously helpful. Shows Hazet does not swap in the Kabo/Cornwell/Titan group. Had not found a good enough pic before. Thanks much CB!
A few questions:
How many sides to the socket drive face?
Is it feasible to use a box end/ring spanner in place of the ratchet?
If so, what size?
If not, an open end wrench?
Again if so, what size?
cosmik binturong
.fr
A few questions:
12 sides and notched all around for the retaining steel ring in the ratchet.
yes.
If so, what size?
16mm six points, does not work with the 12 points i tried it with.
again, yes: you can use an open wrench too.
again, a 16mm one will fit fine.
:thumbup:
or you can use a metric adjustable wrench if you so desire... :D
NC-Fordguy
Great thread!!
cosmik binturong
.fr
i do have a bigger, older, SAM one somewhere, made for the french PTT(Post, Telephone and Telegraph) and was issued to the techs working up them telegraph poles, with dual size sockets(21/22mm and 25/27mm IIRC) and center teeth that i too used on repurposed telephone poles and trees to run a couple lines for a friend in the countryside, it's way less refined than the Facom but probably more sturdy too.
will try to get it out of it's hiding place next time i'm in Marseille. :)
R
retDAC
12 sides ... 16mm six points, does not work with the 12 points i tried it with ...
Thank you so much again CB. I thought it should be 12 sided; just couldn't be certain from the pix. Now I know I a wrench can work albeit a 6pt.
Incidentally, thanks to you there are now only 2 brands I can't be sure what they fit.
Oh, you said you tried a 12 point box and when that didn't work, you found a 6pt 16mm does. Can you get hold of a 16mm spline wrench or socket and try that?
Whenever you go to Marseille, if you can measure the diameter of the geared area on the socket it would be a big help.
cosmik binturong
.fr
sorry, the only splined socket i do have is 5.5mm and i won't be getting any more in a foreseeable future. :(
will do, if i find it... :D
R
retDAC
sorry, the only splined socket i do have is 5.5mm and i won't be getting any more in a foreseeable future...
Don't want to put you to any trouble but if you have the time, how about taking one of your sockets to a tool store where they do have 16mm spline and see if it fits?
Don't know your situation but I'm always happy to have an excuse to look at tools. :bounce:
cosmik binturong
.fr
not so simple... "tool stores" here are either "big box" type(albeit smaller than in the US of A) where mostly junk tools or limited selection is available or "over the counter" where you state what you want and then, if they do have stock, they bring you what they have or they look in their catalogs and order it for you... :sad:
and if you go to the last type just to try sockets and wrench, don't expect any kind of sympathy or help if you don't have a big account with them... :lol:
send me a car* and i'll be more than happy to go check whatever tools you want to be checked! :D
* tank full please... ;)
R
retDAC
So in France it's a big pain just to go look at tools if there were any where one could simply examine them. How deprived you are! :shocking:
Am not surprised though. Thus my caveat: "Don't want to put you to any trouble".
Thanks again for your previous efforts. :thumbup:
cosmik binturong
.fr
no, it's a pain to deal with the limited sources of available*good* tools here since i'm in the middle of next to nowhere right now... that and the fact that being ~20km from anything that doesn't have hooves, horns, stinky wool or feathers does not help much... thnakfully, i'm not that far removed from civilisation to envision only fondling chinese-made junk: Belgium, Germany and Luxemburg are less than 120km max. :thumbup:
i'll just have, for now, to borrow a car though... :lol:
maybe next time we're goin' to .lu, i'll check whatever spline wrenches, sockets and screwdrivers they might have in there against one of my Hazet pass-through socket and report them findings. :)
Jbullfrog
Avoca, Iowa
They are all 7/8 drive. I didn't do links, as I was using our IPad.
R
retDAC
Okay cosmik, I stand corrected. Err sit corrected. :lol_hitti
Had been reading another post where somebody was from Greece before I came to this thread.
lok
Greece
Here I am!
And of course you can sent me your tools to check out whatever you want. :lol:
I'm trying to find some info for another hexagon pass through socket set that I had seen.
The gedore has the locking ring in the ratchet. One Japanese set use a security ball in the socket so it can be secured in every hexagon or bi-hexagon wrench.
Βut I do not remember where I had seen this.
R
retDAC
... I'm trying to find some info for another hexagon pass through socket set that I had seen.
The gedore has the locking ring in the ratchet. One Japanese set use a security ball in the socket so it can be secured in every hexagon or bi-hexagon wrench. ...
The group B1 sockets have the check ball/security ball in the socket. They are made in Taiwan or at least the Ampro's I have are. For an example, go here and just below the pic move th cursor or click the + sign to magnify: http://www.harborfreight.com/21-piece-saemetric-go-thru-socket-set-67974.html
I realize probably none of these brands are sold in Europe, but I suppose whoever makes these also makes them for somebody else.
Oh, wait, is this brand what you're looking for?
http://www.bgstechnic.de/product.php?prodID=03991 Identical to my Ampro's.
One possible source: http://www.ebay.com/itm/BGS-Tools-5...t=UK_Hand_Tools_Equipment&hash=item589a828f55
This kit may be NOS: http://www.ebay.com/itm/BGS-Tools-1...t=UK_Hand_Tools_Equipment&hash=item35c3340b57
Maybe you can get them cheaper somewhere else? :dunno:
R
retDAC
Added 9 more which make 51 brand lines total. The Laser Tools Go Thru sockets are those, ahem, combined SAE/Metric spline (ex: 1/2"-13mm) which don't work so well with the smaller size nut. Added to 5 in the group B notes.
lok
Greece
No one of these is what I'm looking for but thanks. I also thank you for all the info and your time how spend to find this link for the bgs set. It's easy for me to find this set locally (or maybe re branded), but I'm not interesting to buy one.
I searching just because I want to help you to complete your list. :)
R
retDAC
... I also thank you for all the info and your time how spend to find this link for the bgs set. It's easy for me to find this set locally (or maybe re branded), but I'm not interesting to buy one.
Thank you very much lok. You and neophyte and cosmik have been quite helpful. It's good to see this subject get more interest than I would have thought. Originally didn't expect so many brands and especially didn't expect to spend so time on this. Am reminded of how much time I spent on my current vise brands thread.
Also a big thanks to whoever put 5 stars on this thread.
erswill
Hi retDAC
Please add SATA pass thru to group A
You may have this information:
group b1: distributed or manufactured by Listol Co
http://www.listol.com.tw/products-4.asp?offset=36
group b2: distributed or manufactured by Hexa Tools/Liu Hung Industrial
http://www.hexatool.com.tw/products.php?products_class1_sn=48
I do have a few sets of these go thu sets
Ampro T45821
Ampro T45981
30 piece Mastercratf ratcheting combination wrench with matching go thru sockets
manufactured by Infar Industrial
Thanks, your research is very informative
