Merkava_4
^ Insulated ring terminal size 14-16.
^ Non-insulated ring terminal size 14-16.
^ Open-Barrel spade terminal size 14-16.
^ Insulated ring terminal after being crimped.
^ Non-insulted ring terminal in position awaiting wire insertion. Notice the seam is in the ditch.
^ Flip the pliers over and this is what you see.
^ Looking at it from the back side.
^ Top side of non-insulated ring terminal after being crimped.
^ Back side of non-insulated ring terminal after being crimped.
^ Non-insulated **** splice connecter awaiting wire insertion. The seam is in the ditch.
^ Splice connection after being crimped - top side.
^ Splice connection after being crimped - back side.
^ We're sliding the heat shrink tubing on.
^ Heat shrink has now been shrunk.
^ We're closing in using section E.
^ We slide over to the flat section and complete the crimp.
^ Here we're getting ready to crimp the insulation grip using section A.
^ Here the insulation grip has been crimped.
^ Open barrel spade terminal after being crimped.
