Between 265 & 485 SQ/FT My 16 x 24 in Michigan
jon72vega
Niles Michigan
July 8, 2017.
Thanks to photo ucket's changes in it's TOS, I've had to re-host & replace all my pictures in my garage build thread.
I think I have everything fixed that can be.
If you see something that doesn't look correct, please private message me.
It's already completed, but here are some photos of my build that was started towards the end of May this year.
Our Garage was demolished and replaced.
It was built out of used lumber & added on to over the years, and had just plain outlived it's useful life.
Inside at one time there were many pictures pasted on the walls, some from World War 2. There are only a few remaining.
Pasted on wall: Bing Crosby.
Pasted on wall: Bob Hope.
Pasted on wall: Keep 'Em Flying.
Pasted on wall: US Marine Insignia.
Pasted on wall: ParaTex.
J
jon72vega
Niles Michigan
Our back yard looked "red" as in neck for awhile.
Going.............................
GONE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
The Bobcat Operator had "An Appetite for Destruction".
Mission accomplished.
The contractor had already hauled off 1 load.
J
jon72vega
Niles Michigan
This is cool! This was a home-made cabinet door that the contractor saved for us. When my wife stripped the old wallpaper from the walls in the house years ago, she found Elmer had signed his name and the date on the bare plaster.
This is what I saw when I got home from work the next day. A dump truck brought another load of fill dirt in after I took the picture.
The contractor told my wife that they should be pouring concrete the day after today.
This is what I came home to after work the following day.
The contractor told my wife that they will start framing tomorrow.
The contractor did a nice job on the concrete.
The old garage was 12' x 22'. New one will be 16' x 24'. It will be nice to have more space.
J
jon72vega
Niles Michigan
I had to add this picture.
This is the reason for the garage.
It's a 72 Chevy Vega with a V8.
I've had it since 1979.
This picture was taken right after I got home from the Lane Automotive car show on Saturday of Memorial Day weekend.
Good progress!
The builder will be back on Tuesday to continue framing. With the walls up, I can now get a sense of the size. It will be considerably larger, and taller also.
The builders are fast workers. This is what they got accomplished the next work day.
They would have gotten more done, but my wife said they had to stop around 2:00 pm because it started raining.
This is after I came home from work on Wednesday.
Progress, Progress. Shingles are on, entry door is hung, and most of the soffit and fascia is done.
Thursday: Almost done. Pic taken from the neighbor's yard.
They ran out of fascia material on the last board. They will finish Friday morning.
J
jon72vega
Niles Michigan
Minor tasks left to do.
Moving a little fill dirt and final cleanup won't take too long.
This is the money shot. Final inspection in the morning.
After the final inspection we are in the process of moving everything in.
This is for the set of steps we have on order.
I dug it out, made the form, and hand mixed 9 bags of concrete today.
Man that was alot of work!
My body is telling me right now that I should have rented a cement mixer.
My stepson came over today and dug trenching for the new electric that will run to the garage. Thanks Tommy!
More progress. The steps are done. The electrician got started today. He made good progress, including getting the cable ran in the trench so we could cover it up.
The electrician has completed the electrical work.
The outside lights are programmable for dusk to dawn, as well as motion detection.
I'll put up pictures of the inside as soon as I get the inside lights hung.
Here's a closeup of the outside lights.
J
jon72vega
Niles Michigan
The fence behind the garage is functional again.
I had to buy a post-hole digger, because the one I lined up to borrow didn't happen.
I found out after I was all done that my neighbor had 1 that I could have borrowed. Oh well.....
The fence on the front of the garage is ...... well it's a fence again.
The grass (and weeds) are starting to grow back.
The gutters / eaves-troughs (or whatever they are called in your area of the country) and the down-spouts are installed.
I had the down-spouts installed to get the rainwater aimed away from the garage towards the neighbor's property behind me.
The garage is at least in a functional state of organization at this point.
When you get older, good lighting is very important.
This is not what I originally had in mind for shelving, but it is functional.
J
jon72vega
Niles Michigan
Did I mention that good lighting is important???
Plenty of room for the snow-blower now, without having to stack things on top of it in the summer.
I'm going to purchase a workbench that will go between the window and the walk-in door.
I will probably put in an overhead door opener at some point.
It took a couple of hours to get the overgrown grass removed from the sidewalk.
I set some stepping stones...... Now keep off the grass!
I put up a shelf for my owl to sit on.
I installed another light to hang under the garage door.
It hangs from the roller rails for the door.
It's movable, and doesn't interfere with the door.
The door opener I'm going to install opens the door via the tube for the torsion spring, so the light won't interfere with that.
J
jon72vega
Niles Michigan
This is my new work-bench.
It took alot of sanding, then several coats of Linseed Oil, followed by 4 coats of paste wax.
It will almost be a shame to use it as a work-bench.
This is my garage door opener that I installed.
It's a Liftmaster 8500.
It was relatively simple to install, and works nicely.
I put up some decorations over the door.
Here's the tire rack for the summer tires in the winter, and vice versa.
Thank you to my boss for the winch.
It made installing the bed topper on my Sport Trac easy.
The bed topper is hanging, ready to go on the Sport Trac.
Ready for winter.
I can even get the snow blower outside easily when needed.
Phil_R
Indiana / Tennessee
Hey Jon,
See your from Niles. I spent many summers as a kid in Niles as my grandparents use to live north of Niles on Knott Road. Small world!
Phil
J
jon72vega
Niles Michigan
Much nicer than the old garage!!!
Thanks for the pics and glad you have a new space to work on things including that cool Vega!
Phil
Hey Jon,
Phil
Phil_R,
Thanks for stopping by!
It really is a small world!
Knott Rd is by Matthew Rd.
I know exactly the area.
J
jon72vega
Niles Michigan
Do you take the vega to the car shows on Wednesdays during the summer in Niles?
Thanks for visiting, fastjohnny.
The "Bring IT" Wednesday night cruises have been VERY popular.
The rumor for 2015 is that they will not happening because of the Main St
bridge replacement.
The logistics of all those cars downtown would be difficult with the bridge closed.
Here's a picture from 2012 of downtown Niles on a Wednesday evening.
captain14
Is that the vega under the green car cover/tarp?
Any plans to install insulation and heat? It gets cold in Michigan if you need a snowblower too.
Nice project and sized. I like how you did some of the work after the garage was finished . It's the little things like that make it yours.
J
jon72vega
Niles Michigan
thats quite an upgrade!
Done well, great build and thanks for sharing..:thumbup:
Looking good, some great progress.
looks great
Thanks guys, It really makes me feel good for others to appreciate what we have been able to get accomplished this year.
I have a GREAT wife who has been very supportive thru-out the whole build.
She is the one that kept telling me to get it built.
J
jon72vega
Niles Michigan
Good looking garage, and in my old neck of the woods. I just moved away from South Bend, IN a couple years ago.
Thanks!
It's amazing to me to see the people that are or where from the area.
Well done !! Looks fantastic !!
Thanks!
Congrats.
Nice garage. Vega looks to be in excellent shape. Why the extra fender and hood?
Thanks!
Extra fender is one of "lifes most embarrassing moments".
I've kept it to remind me to "think before I do".
(The fender is damaged because I used to have a tunnel ram intake manifold on the engine, with a different hood on the car with a VERY TALL hood scoop.
As in hard to see what's in front of you on the passenger side.
Short cement post in a parking lot.
Didn't back out of the parking spot I was in very carefully when I was leaving......)
Extra hood is because I seem to have a hood fetish.
I have had the car 35 years, and the current hood on the car is #5.
Beautiful garage and a beautiful Vega
Thanks!
J
jon72vega
Niles Michigan
That is the Vega.
I put it on wheel dollys to move it over enough to get my Sport Trac in the garage.
I would like to do that in the future.
Thanks!
I'm beginning to think it may never be finished. I keep seeing things I want for it or move something ...etc.etc.
captain14
It will never be finished if you read this forum and pay attention. Someone does something and you think great idea! I like that and I can do that this week after I finish the last project. It's the little things that make it yours.
Did you son use a ditch witch for the power line or Manual Labor?
Can you sue the workbench wall with the Vega in that side? Or was that temporary?
One idea for the insulation is buy a roll or two whenever you are at your supply place and install it. Then it does not seem like a big cost all at once. And how long does it take to fill a couple of bays with it?
Thanks
J
jon72vega
Niles Michigan
Manual labor. It's good to be young.................
Temporary....the Vega off to the side is only for the winter.
I moved the bench to the back wall.
When spring arrives the Sport Trac will stay outside, and I will move everything back how it was.
That's probably how I'll do it.
Thanks
Thanks for your interest.
J
jon72vega
Niles Michigan
Here's another picture from a different angle showing both vehicles inside.
I already wish I would have had built to 20' wide instead of 16', but I live in the city & have a small back yard.
It is what it is...LOL
fastjohnny
SW Michigan
bridge replacement.
Looks like you're about in front of Pizza Transit:thumbup:
My youngest son at 8 y.o last summer went every chance he could, whether with me, his older brother, or his grandpa, and wouldnt stop until he had taken pictures of EVERY entry. Just a bit of a car nut:)
HSpencer
South Central US
Beautiful new garage. Well done in every respect. Also extra nice landscaping you put in.
Looks great!!
Best Regards
Herb Spencer
J
jon72vega
Niles Michigan
fastjohnny,
Sounds like you are training your son right. :thumbup:
J
jon72vega
Niles Michigan
Looks great!!
Best Regards
Herb Spencer
Thanks for stopping in Herb!
I appreciate the kind words!
Also... I took several hours yesterday to go thru your "Small Two Car Operation".
You do beautiful work, & what excellent craftsmanship!:thumbup:
HSpencer
South Central US
Thanks so much for your kind words as well! I am so pleased you found something of interest in my thread.
I was stationed in the US Army for a short while at Camp Grayling, MI. I visited all over MI, and usually went to Traverse City on weekends. I was there in warm weather, but the post engineer told me the water lines were buried eight feet deep up there. WOW, and that lake freezes over enough to drive a car across. I also toured up into Canada while I was there.
Do you know if that place is still going? It was beautiful country. Also liked the city of Grayling.
I enjoyed your thread photos very much!!
Thanks and Best Regards
Herb
J
jon72vega
Niles Michigan
Herb
Herb,
It's a small world.
Camp Grayling is still in operation.
I have memories of Grayling also.
The summer before my junior year of high school I worked at a summer camp for kids in Grayling, Camp Au Sable.
When we would get a rare break from all the activity, we would go into town.
Soldiers would always be hanging out at the drive-in we would go to.
Funny it's been so many years, I don't remember the name of the drive-in.
I also worked in Traverse City at a cherry canning factory the next summer.
Take care,
J
jon72vega
Niles Michigan
I actually got this hung and wired 3 or 4 weeks ago, but I am updating my build with the picture.
It's a Fahrenheat FUH54 5,000 watt electric heater.
I still need to add a remote thermostat or switch to it.
I saw another message thread in the Heating and AC section the other day on how to do it, so that will be an upcoming project.
It sure helps to take the chill out when I go out to the garage for a project.
Soon I will have to start insulating the walls.
xtremek
St. Johns, Mi
Looks great, Jon. I'd do the ceiling first. I'm not one for tearing down a building, but in your case, that old shack had served it's purpose. Looking forward to watching is evolve.
J
jon72vega
Niles Michigan
xtremek
Thanks for looking in, and the kind words.
The old garage (according to the demolition guy) was still standing only because of the many "bandaid" fixes I had done to to it over the last 20 years.
J
jon72vega
Niles Michigan
Real super nice job. can you tell me what that all costed you to have the garage built? thank you
ijason
Thanks!
It cost $1800 to have the old garage demolished and everything hauled away.
It was another $8400 to have the new one built, including the slab.
For our area, I feel like the build price was very reasonable, as we had another contractor come in with a bid of almost double.
