My Valve Cover Desk Lamp Project
aka Larry
Eastern, NC
For a while now I have been wanting to build a piece of furniture from some combination of automotive parts. I've had a few ideas, but I didn't want to build something that wouldn't be ever seen or used. The boss is not going to let that kind of stuff in the house, and out my the shop it wouldn't get much exposure. With that in mind, I remembered that my friend has an insurance business and his office is decorated with various automotive stuff. I had an idea of something to build, but wanted to be sure he was open to the idea first, so I gave him a call and he was excited about it. Cool, time to move forward.
My idea was to build a desk lamp using a valve cover. This is not a 100% original idea, but all the ones that I found were made from a stamped steel piece from a typical V8. After some searching on Ebay, and not liking the prices, it hit me that I already had a valve cover. About 10 years ago I bought one for a Mazda Protégé to replace the OEM one on my NA Miata. So I went up into the attic and dug through the boxes and finally found it to move forward on the project.
I spent a lot of time thinking about the base and support post, finally deciding to use a brake rotor and square tubing. The rotor would serve dual purposes as part of the automotive theme as well as weight to keep it stable. The square tubing for the post was what I had on hand, and it's easy to work with.
When I first bought the valve cover, I painted it with the VHT high temperature wrinkle paint. so it was already done. For the post design, I decided to use two uprights welded to a single cantilevered arm. Those two uprights would be welded to a round plate at the bottom, with that plated being bolted to the brake rotor.
I wanted it to actually function as a desk lamp, and of course LED strips would be the source for illumination. I already had a few strips, so that made it a little easier. The trick was finding a way to mount them inside the valve cover. It's not all nice and flat where I could simply stick them on. I also wanted to mount some sort of lens just to tidy up the underside. If the valve cover was steel, I would just weld on a pair of plates, but I had to come up with a another plan. As it turned out, I had some 1/2" aluminum channel so I drilled a couple of holes in that. I used the existing threaded bosses on the valve cover to attach the channel with some screws. I used some 1/4"-20 thread spacers to attach the lens I was going to use.
For the lens, I used some leftover Lexan from another project. I measured and marked it so I could cut it out with the jigsaw. After I was happy with the fitment, I used some spray frosting to make it more functional and to hide the LEDs and wiring.
After match drilling the steel base plate of the post to match the rotor, I primed and painted it satin black.
With most of the fabrication and painting work done, I moved all the parts in the house where I could work on the kitchen table.
After some thought, I decided I wanted to personalize the lamp in some manner. The brake rotor seemed like the best canvas, so I started with a brand new one for a NA Miata. I considered using decals, paint via a stencil, and maybe even laser etching. After I made a post on here asking about the laser etching, it was suggested I might use a DIY acid etching method instead. After a quick Google search, I found a few videos on YouTube on the etching. I decided on a design and had the local sign shop make me a vinyl stencil.
The actual acid etching is pretty straight forward. Using vinegar/salt solution, a 12 volt power supply (jump box), test leads, and some Q-tips, I was all set. First I cleaned the rotor and applied the stencil. Next, with the positive wire connected to the rotor, and the negative wire to the Q-tip wet with the vinegar/salt solution, I etched each letter. After removing the stencil, the etching was revealed and it turned out great! Since the rotor was bare metal, I decided to clear-coat it to keep it nice and shiny.
While the clear-coat was drying on the rotor, I worked on installing the LED strips inside the valve cover. After soldering and adding heat shrink, I did a test to be sure everything was indeed working.
To keep the theme, I wanted to use lug nuts to attach the post to the rotor. Actual lug studs are way overkill here, so I used epoxy to glue 1/4"-20 threaded spacers inside the lug nuts.
Finally I assembled the post to the valve cover, and the post to the rotor. I glued some stainless steel cap screws in place around the valve cover, along with adding an aluminum oil cap and breather element to finish it off.
I'm pretty pleased with how it turned out, and I'm taking it to my friend's office tomorrow for the big reveal. Hopefully he will be pleased and want to proudly display it in his office.
LXCam
Holy **** Larry that's just flat out killer. I especially like the etched rotor, very nice touch.
4xdog
Santa Fe, NM
That's terrific! Well done.
How's the stability? It looks kinda weight-forward in the photos.
pmason0
East Tennessee
Very nice, I have a head from a 99 miata that I need to come up with some project for it, but don't have the cover for it.
csp
Franktown, CO
Is that notch cut into the edge of the ID hole of the rotor where the switch is located? I think I see a little rotary switch in the base of the stand you built.
therealjakeg
Awesome on the etching and the whole project. My wife has a vinyl cutter. This is bringing some good ideas.
cnc-me
MI
Looks great, now how about some spark plugs too....and sparks
A
aka Larry
Eastern, NC
Thanks for all the kind words everyone!
To answer a few questions as asked so far:
Due to the weight of the rotor, it's pretty stable.
Good eye! Yes, you are exactly right, that is a simple rotary on/off switch.
Neat. The hidden wire is a nice touch. Got a pic of it lit up?
Sorry, I didn't get a pic of it lit up. It was too bright in the kitchen at the time, but I should have gotten one later. :(
ilovevocs
Toledo, Ohio
That turned out awesome. The acid etch and cleared rotor make it look like a high dollar piece.
Lahti35
Bay City, MI.
Very cool, nice build!
I've got a Buick straight 8 valve cover I'm making into a light also... I love using up leftovers!
kbs2244
I can see a make to order dollar thing here!
It belongs on a service manager's desk.
Could you have hidden the switch in the filter or the filler cap?
afbrian13
That's awesome! I saved an extra from my 280z I6 to make a workbench light. Your's looks great!
A
aka Larry
Eastern, NC
Probably, and I considered doing that, but ran out of time. Since the switch is on the back side, and is the same black color, it's hardly noticeable.
Thank you! I was pleasantly surprised at how the acid etching turned out. It was a little tedious as it took me abut an hour, but the end result was worth it. Once I added it all up, I was surprised that I had about $120.00 into the project. All the little things add up, and I'd be embarrassed to tell you how much time was put into it.
rharman
SoCal
Before reading this, I was hoping to find out that the little air filter was the switch.
A
aka Larry
Eastern, NC
Thanks or all the kind words from everyone who has looked at this thread and commented thus far. All the comments made on here on GJ mean more to me than any others because there are some seriously talented folks here.
JTG
New Jersey
That lamp is cool! I was going to toss a couple of rotors I had laying around but may keep them just in case.
LX-Markham
Markham, Ont.
Way cool!
Another thread here inspired me to make a power bar out of a valve cover. Now I think I might use the other valve cover for a light. Thanks!
