BEFORE & AFTER....A Tool Polisher's Haven
JMLangford
Upstate SC
Hello Folks....My name is Mike and I'm a tool polisher :rocker:
I'm starting this thread so I (and any other tool polishers) can post pics of items I've found in need of some TLC ......
Armed with paint, wire brushes, vinegar, grinders, degreaser, scrapers, etc....whatever it takes to refresh/restore/refinish or simply clean up an item.
I hope other fellow tool polishers will post up some of their polishing projects too.....it's all good ;) maybe share your ideals and techniques,etc.
A TOOL POLISHER's HAVEN.....
Depending on how "involved" I get "polishing" something, I may have several pics with text or I might simply post Before & After.....
1st one....
BEFORE:
20171122_164412.jpg 20171122_164459.jpg 20171122_164656.jpg 20171124_154602.jpg 20171124_175543.jpg 20171124_190223.jpg 20171203_143327.jpg
don long
southern california
I'm a tool polisher restorer.
I've been at it for a couple of years and find it very rewarding
Here is a couple of my tools before and after.
My circular saw
38856905242_868646b0f0_c.jpg1 (3) by don long, on Flickr
38856907912_64c1e7d27b_b.jpg2 by don long, on Flickr
27110799859_9d95e98a64_b.jpg2014-09-19 18.45.12 by don long, on Flickr
38857088152_877dfc54f7_c.jpg2014-09-19 18.47.31 by don long, on Flickr
My tire spreader
38887187341_1337f48884_c.jpg2016-10-15 16.34.40 (2) by don long, on Flickr
24022255017_c2ce914588_c.jpg2017-06-06 16.58.34 by don long, on Flickr
And my gas caddy
38887176081_4841bd6e7b_c.jpg1 (2) by don long, on Flickr
38887180611_1eabb420be_c.jpg56 (2) by don long, on Flickr
My vintage compressor and cart
25015913898_8156c25514_z.jpg2015-10-17 16.23.42 (2) by don long, on Flickr
25015918498_73bd62e423_c.jpg2016-01-14 11.37.53 (2) by don long, on Flickr
I have pictures of the process but too many pic's to share on these projects but I'll do shots as progress on new ones
C_F
Utah...SNOW BLOWS!
Wow, very impressive you guys!:bowdown:
That old tire spreader is cool, we had a similar one in my HS auto shop. I used it to patch at least a half dozen tires while I had that class. :)
J
JMLangford
Upstate SC
Some of y'all may have remembered this Milwaukee angle drill I got at a yard sale for $5 bucks......
https://www.garagejournal.com/forum/showpost.php?p=4893118&postcount=2932
Case was in real rough shape but he said the drill worked and it also came with 7 rusted ship auger bits and a extension......
Got busy and removed the front gear housing and then the armature, etc...
More to come.....
J
JMLangford
Upstate SC
I'm not "restoring" this drill, I'm just giving it a real good cleaning to "refresh" it :D
I had my work cut out for me.....this thing need a lot of TLC....
Refreshed the plastic handles too.....
More to come.....
Lelandwelds
Central Texas
That work doesnt look like sisal, cotton, or felt wheels. Some looks like wire wheel, some sandpaper rolls, and some looks like flap wheels.
Thats my guess. What are you using? How do you keep from rounding the edges and corners?
J
JMLangford
Upstate SC
So, here's the BEFORE:
And here's the AFTER:
Couldn't do anything for the case (I should have stripped it and re-painted)
I advertised it on Craigslist......the ad ran for about a week and an electrician from N.C. came down and paid $130 for it.
Glad he could use it :thumbup:
don long
southern california
Mr. Long -- what was your process to polish the cast alu on that Craftsman saw?
I just wet sanded some cast alu. and then hand buffed with metal magic... I now know how much work is involved!
catalytic
When I want to polish an old craftsman tool (which I have several) I start by dismantling it completely. I take my 3" sander with a 150 grit disc on it. I sand down the parts until ALL the scratches are gone. Then I repeat the process with 220 grit then 400 grit return with a 600 grit disc on my pad and with an 800 grit disc I start polishing the piece and my final sand down is with 1200 grit sand paper When the sanding is done the part has a dull shine on it so I take the part to my Baldor polishing machine and with red rouge on the wheel I buff out the part. Then give the piece a thorough cleaning with some wax and grease remover before spraying automotive clear paint on my pieces. I let them sit til cured maybe 3 days before reassembly.
(LOTS OF WORK)
don long
southern california
I love brass tools. And I love to polish brass up to a high shine.
Like this brass pump and fire extinguisher holder
38189577744_2a1e687eff_c.jpgIMG_0046 by don long, on Flickr
38869278472_fdd7570145_c.jpgIMG_0055 by don long, on Flickr
24040583297_6b50fb3f8a_c.jpg1 by don long, on Flickr
25034081978_e3f5148e2b_c.jpg2016-05-10 14.47.34 by don long, on Flickr
27128888119_e6315179af.jpg2016-05-10 14.47.52 by don long, on Flickr
Here is a project that i'm currently working on
this is a blow torch with a rectangle tank (this one is a steel torch)
38905213201_8aaf81d14a_c.jpg1 by don long, on Flickr
I sand blasted the tank. I also polished the brass pieces
37037307654_ca9439caf3_c.jpgIMG_1466 by don long, on Flickr
I took the dents out of the tank, primed and painted it 2tone Blue and yellow and sent it over to a friend to logo and letter it.
Hope to get it back soon.
38869920712_7617a9a6f2_c.jpg2017-10-16 13.03.49 by don long, on Flickr
38018969085_0aeb608685_c.jpg2017-10-24 17.59.34 by don long, on Flickr
ndnchf
Fredericksburg, Virginia
Maybe a little OT, not exactly polished bright. But cleaned up and pretty, showing its well earned wrinkles. This Kellogg air pump (compressor) is well over 100 years old. It came out of an old barn where it had sat for decades before earning its keep in a garage. I took it all apart, cleaned, lubricated and re-assembled it. I added a higher pressure, but original period gauge and a pressure relief valve. It runs like a champ now. I use it occasionally to pump up the tires on my 1924 Ford touring car.
  • Like
Reactions: DSS
J
JMLangford
Upstate SC
ndnchf: You did a great job of cleaning and re-doing your air pump back to service :thumbup: I don't necessarily shine everything to a high shine....most of my cleaning and polishing is not perfect but I enjoy trying.
Most of what I do is on a small scale....cheaper that way ;)
I wish I had the talent and resources to restore stuff like Don (the master) does.....but it's all good!!
How did you get those bits cleaned up so well?
Swingpress: If you are referring to the auger bits.....I simply used a fine wire wheel on my bench grinder.
They actually had just surface rust that came off really easy!
I usually wipe down any bare metal with a very thin coat of gun oil.....
J
JMLangford
Upstate SC
Picked up a well neglected Lee Pro 1000 progressive reloader (missing a lot of parts and pieces) and an lightly abused Lee single die press for a crazy stupid low, low, low, low, low, price (more on that later)......
It came with 40 S&W dies (great cause I've got a couple of 40 cals) and I wired brushed one right away to see how well they'd clean up.....It was the most rusted also.....
The single press was basically complete (other than needing whatever die you'd use and whatever shell holder you'd need) but still needed some TLC.....
J
JMLangford
Upstate SC
I started with the easiest one first....the single press :)
Disassembled and scraped and painted and polished and reassembled....then mounted it to a piece of oak to clamp to my bench.....(I installed the decapping die but I don't yet have a proper shell holder).....
J
JMLangford
Upstate SC
Next, I took apart and cleaned all the dies then started on the body of the progressive press.....
I cleaned these three uprights then re-blued them.....(they look brownish but I think it's the reflection of the bench top....they're actually black)
Found an oak board to mount it to also :beer: (I've got a lot of stair thread cut-offs from a wood shop years ago)
J
JMLangford
Upstate SC
Next, I began taking every piece of the press apart for inspection and cleaning....
Reassembling and timing everything so it comes up at the proper station in the process.....
Got the oak board tung-oiled, then re-mounted the press for reassembly.....
J
JMLangford
Upstate SC
I had to buy a few parts that was missing from the Pro 1000 press....
Auto powder measure and hopper
Priming attachment
Case feeder tubes
and a 9mm shell holder for the single press.....
I mentioned at the first of these posts, that I got these presses extremely cheap....and it's a good thing :mad: cause at the time I bought the missing components (about a year ago) I could have bought the Lee Pro 1000 with (new) dies for not much more than I'll have in this one.....Now, it and the single press has come down even more since last year......but what the hey :lol_hitti
Dropped in the dies and adjusted them (thanks Youtube) put some cases in the tubes, and did a dry run to make sure everything worked....Got a (imaginary) completed round at every pull of the handle!!......:thumbup:
J
JMLangford
Upstate SC
I just noticed something :lol:.....Most everything I've posted so far has been RED :lol_hitti
ndnchf
