mrzoop
....so here my story begins. For years I lived with an old 22X20 block garage that you could easily see daylight through the mortar. The garage was built in the 50's directly on the clay surface with no footings for the walls or stone base for the concrete floor. I kept it looking nice with some fresh paint from time to time, however this season would be it's last.
I had intentions of salvaging the roof to be used on the back of my property as a pole barn, but the dream was too difficult to be true. It was decided to just pull the roof off and demolish the block.
I started by pulling down the back wall between the windows and knocked out the top row of blocks. The roof was just floating on a couple of the supports that we added to keep it steady.
And now the fun begins.... I hooked up the big tractor to the main support beam inside with some chain and we had ourselves a tractor pull. After a couple pulls the roof fell taking out the walls. We cut up the roof into 5' widths and stacked it out of the way for later disposal. I was able to use the crushed block as fill.
Everything cleaned up during 1 weekend and now here is the future site of the new Barn at the end of the driveway.
