0.001 vs 0.0001
bradthefixer
Hello, which resolution measurement is acceptable to measure pre machine shop work and post machine shop work? Small block chevy mild build weekend driver. Just trying to get input for an ongoing debate between a couple of friends. One says .001 dial indicator is just fine for a hobby builder, the other says you must use .0001 dial indicator.
IndyGarage
Indy
My knowledge might be out of date, but I would say most auto machining equipment is not accurate enough to notice much on the ten thousands scale.
It could be some race shops are tuned that well, but typical machine auto machine shops - no.
Aerospace yes, Automotive, no.
GeoBruin
It very, very, very much depends what you're measuring.
Milling a stationary part that something gets bolted to? Holding a couple thou flatness over an area of a few inches is perfectly acceptable.
Turning a round shaft that will be spinning rapidly? Maintaining + or - a couple tenths (.0001) diameter over the length of a short shaft should be doable,if it's even necessary.
Also, a plunger style dial indicator will typically only measure in thousandths. A dial test indicator is typically used for greater precision.
Shiftless
East Bay SFO
Let‘s wait for an experienced rebuilder to chime in.
Based on the limited one engine rebuild job I did with my buddy who was a pro engine machinist and from hanging around my FIL who worked in a machine shop at a major oil refinery doing prototyping for phD scientists, I’d say that .001 is plenty “good enough”. I doubt that a brand new engine from any manufacturer has parts that are precision manufactured to a tolerance of one ten thousandth of an inch. Can anybody verify that?
Rounder
WI
A shop rebuilt my crank on stand and tag gives runnout in .000#. Measuring runnout on the bike I measured .00# Not a pro. Just point out stand vs in machine.
Firebrick43
West central Indiana
For some one assembling engines .001” is fine and .0001” is a detriment.
There is nothing in assembling an engine that needs the precision to the .0001”. I would dare to say that a dial indicator itself is a luxury to measure crank end play, TDC, and valve lash as they can be done with feeler gauges and tdc with a degree wheel and mechanical stop.
In machining yes but I doubt the hobbyist is grinding their own crank and checking their work between centers or facing rod end caps and using an indicator to pick up center to rebore it to size
Mgdoug3
KY
My micrometers I use are 0.0001 resolution. 99% of the time I just read .001. The only time I worry about tenths is when I'm measuring parts that have a very small range. For a dial bore gauge, I use 0.0005 and that's close enough to check. When you're trying to measure tenths, if you're not in a climate controlled room or not 70 degrees, you likely can't measure accurately.
king nero
Belgium
Having worked at a well known ship engine motor manufacturer, I'll second itsNemo and alfadan.
Keep in mind you'll also need machinery that can consistently achieve 0.0001 in both accuracy and precision.
Which is not your typical home lathe or second hand mill.
We used temp measurements on the cast blocks during milling to account for thermal expansion, had measuring stations with double sets of doors (for temperature control), and a rotation in the CNC machines, that were assigned parts in a certain tolerance category depending on their wear.
I'd rather have a good .001 dial indicator than a crappy .0001.
Packard V8
Spokane, WA
Yes, No, Maybe. Every part has a plus/minus allowable variation; we work to the middle of the allowable spec and hold sub-.001" specs every operation.
The good news is today's aftermarket pistons and connecting rods come out of the box ready to go. We always confirm, but they're within +/- two grams, rod big ends round and center-to-center length perfect, pistons all same diameter.
We measure piston diameters to tenths and then cylinder bore diameter to a specified tenths+ and finish all the holes to within .0005"; holding to more equal than that requires letting the cylinder block cool to ambient between each operation and would take all day to hone one block.
Same with connecting rod reconditioning. We measure and record the crankpin diameters, then finish the big end bores to a specified clearance, holding to within .0005" range.
Same with line honing crankshaft main bores; they should all be to spec and no more than .0005" variation.
One of the more important considerations is the balancing tolerances. The closer to zero the operator must work, the more time and the more it costs. As the saying goes, "Speed costs money; how fast can you afford to go?"
jack vines
cannuck
Rural SK
My second measurement peeve is when someone calls out a print to 0.001mm, then tells me they measured parts with calipers
I had a set of relatively cheap calipers that read to 0.0001" but never took them seriously.
As others have mentioned: not too much of anything actually needs to be machined or measured to anything other than 0.001" with a +/- 0.001 tolerance other than hydraulic (fuel system) stuff - that one does NOT do in anything other than an injection (usually diesel) shop. That being said, many machinists pay attention to WHERE on the scale a measurement lands and do fits or finishes to compensate. Even 0.001" with a cutting tool is a bit of a pipe dream due to deflection of the workpiece when the cutting tool engages. 0.0001" means grinding or polishing under controlled temperature with similarly temperature controlled and constantly checked for calibration measuring tools - i.e. NOT what happens in the average engine shop.
strutaeng
Dallas, TX
0.001" is good enough for that old Chebby engine.
As mentioned, 0.0001" probably won't make sense just from ambient temperature readings, tolerances and even user error in measurements.
larry_g
oregon
Having assembled engines as a young man I would measure parts with a .001" mic and that was to make sure that the machine shop did not sent me .010" bearings to fit a .020" under crank pin. When I started machining and having to hold parts to a tolerencence I learned that the measuring tool used had to have a resolution 10x the measurement you were trying to measure. That is basic metrology. With my thinking I was not checking that the machinist hit tolerance, just that the part was not grossly out. If I question the machine work then I take it back to the machine shop and have them check it for me. No reason for me to set up a metrology room at home for occasional work.
lg
no neat sig line
seber
Deep East Tx.
Required tolerance is always dependent on the use. General machine shop tolerance is plus or minus .005. anything tighter will be due to the purpose of the part. I'm not an engine rebuilder so I can't give individual part help.
CHI_Tool&Die
Chicago, IL
I’m not an engine builder but I machine dies and their components regularly to tenths. The engine builders next to us do not do any work that isn’t more intricate than +/- a thou.
Also, I’ve noticed that I can indicate to +/- .0002” with my .0005” Interrapid dial indicator. The .0001” ones **** to use because they are so freaking sensitive when I’m running them in the spindle. I can get it done but it always is a pain.
Retired dozer fixer
Leesburg Indiana
Just how many of you folks are even trained to read measuring tools that read in .0001”? I have overhauled many large diesel engines and large transmissions during my working career and got along fine with measuring tools that read to.001”. These machines have operated for thousands of hours without any problems. Maybe precision machine shops need that kind of accuracy but in the real world.001” is fine
dnschmidt
Phoenix, AZ
Things are different now. The crankshaft to engine bearing specs and the connecting rod to rod journal specs are now below 0.002 on a modern Toyota engine making tenths measurement sort of a necessity. My Toyota for example uses 0W-16 motor oil which is thinner than water so these clearances need to be really tight to maintain an oil film. There is a reason Sunnen Dial Bore Gauges go down to tents. In the old days with 10W-40 oil looser( .003-.004) was acceptable. Not really the case with these modern engines from which they're trying to squeeze out every MPG.
ItsNemo
Canada
Reading the number is fine, any idiot can do that...being able to work to and hold that number is the problem.
I have a couple tenth's measuring tools out in the garage, I can certainly read them and use them, but I'm not able to get consistency on my equipment more than half a thou really.
cannuck
Rural SK
What makes an oil film "strong" enough to support bearing loads is its rate of shear. The greater the difference in velocity between journal and bearing shell the higher the actual viscosity. That is why small, higher revving engines can use much "lighter" lubricating oils. BUT: since lower RPM works for less frictional losses it backs the designer into a corner where more shear would be better. Just going up in oil viscosity doesn't actually do much except increase pumping losses, so about all that's left is to make the clearance less so the rate of shear goes up between the moving surfaces (think of the film as a lot of layers moving in opposite direction meeting in the middle at zero. Cut the number of "layers" and the differential in velocity between each goes up). To make a no-so-simple thing even more interesting: the shaft does not site in the middle of the journal hole, it is offset jaming the oil into a "hydrodynamic wedge" where the shear rate, thus the actual viscosity and resultant film pressure is extremely high - high enough to float the rod brg on the crank journal.
So, you are very correct in your assumption/assertion about tolerances needing to be much tighter. You can indeed USE a 0.0001" resolving instrument - but for all of the reasons many have mentioned it is unlikely you will be able to achieve sufficient accuracy in a workshop environment for it to be significant. Having done this for many decades - and spent a bunch of time analyzing engine and lubricant failures I will say you certainly can use high resolution measuring tools for COMPARATIVE measurements, just don't expect them to be accurate for absolute values. Most people with a lot of experience as I believe I had mentioned before read not just the 0.001" resolution on their micrometers, but WHERE/how far it reads between previous and next alignments - possibly giving enough 1/2 thou resolution to actually be significant at 0.001 inches spec size.
From what I have seen (that is not much in tiny gasoline engines these days) some Toyota main brgs spec 0.0005" to 0.0016" that I would interpret as "we want 0.001" +/- 0.0005" but we would rather you stay on the high side."
cmandp
New Jersey
Keep in mind that what ever decimal place you are measuring to, in theory the tool you use needs 10x the resolution in order to have confidence in the measurement.
So if you are measuring to the 0.001" your tool needs to be able to measure to the 0.0001". In that case a micrometer would be needed, the most accurate caliper is only good to about 0.001" and that's even a bit of a stretch.
cannuck
Rural SK
You make a good point, but as I had mentioned most machinists read not only the number but where the thimble stops between one and the next. Personally, I use digital calipers for rough work but for anything requiring precision I use strictly mechanical micrometers with gauge blocks in each box to check. Reading the location of mechanical mic indication between 0.001" increments of a decent tool with a careful hand is as accurate as having a 0.0001" readout display. Not a fan of electronics on micrometers, but if doing so then you are correct - you should have the higher resolution to know what a machinist easily sees on his (or her) 0.001" resolving mechanical tool.
Firebrick43
And how are you going to read any of the measurements you talked about with a dial indicator? That is the instrument we are talking about.
Crank and rod journal clearance is plastigauge and it’s a rare home shop that has dial bore gauges and the setting rings for them
bpwoodworking
I worked in an automotive machine shop as a yoot. The crank grinding operation (performed solely by the shop owner) was measured in tenths. We worked on a fair number of imports in addition to the typical small block/big block Chevy/ford stuff.
We used a bore gauge for the housing and a micrometer for the journal, never once used plastigauge.
Lassen Forge
I've dealt in .0001, but that was building motorcycle engines... The other time I've had to deal in tenths was in school - the teacher would check our work in .0001, and for some assignments if you were more than .0005 out, you didn't pass... you can "fudge" it reading between the lines on a .001 caliper, but if you're shooting for accuracy, and it counts, then "fudge" is best left at the bakery.
Used to be in most cases .001 was "good enough", but good enough isn't good enough any more.
Firebrick43
Again, we are talking about a home shop assembling an engine.
We used dial bore gauges all the time at cat but final checks were air gauges, marposs, and CMM. None of those are in home shops either?
Lassen Forge
Hey, this IS Garage Journal... if we don't have them (yet), bet you COULD order them on line... Then we can say "WTF? you DON'T have a bore gauge that measures in .2 tenths??? Piker!!!" (cueing diabolical laughter... Bwa ha ha ha... )
milkovich
Akron Ohio
I tried to do something special with my buick 455 which are infamous for having a terrible oiling system. I can't afford to bleed off oil pressure through the entire engine and starve the last rods/mains in the oil circuit. I used several sets of bearings from different manufacturers as well as the same manufacturer to REALLY hit the number and end up with clearances I wanted. On the cylinder/pistons and crank endplay, .001 is fine all day (indicator), on the rods and mains .0001" matters for racing engines or weird old junk where you're moving bearings around to hit a number within a pretty tight range. I've put plenty of small chevies/pontiacs/fords together with feeler gauges and plasti-gauge, but really, with the frequency that I put stuff together (every few years or so) now and the high price of machine work, I'd rather be at the .0001" on the important stuff.
Anyone who is wants to play in the "tenths" range (0.0001") need a granite surface plate and some really expensive measuring devices !
Agree 110%
cannuck
Rural SK
How else do you measure bores, or what your machining.
I'd assume most building engines "at home" also have a Mill and a lathe.
Maybe not.
Duh! Inside micrometers are what I have always used. Most bore dials are mounted on a skid to measure bore taper, not absolute diameter.
Firebrick43
Maybe not.
Most modern engines are not going to be rebuilt with a mill and a lathe. They are just assembling the engine. You still need some measuring tools for assembly however.
They are paying an engine shop to do the machine work Its all done with specialized equipment. They are having a machine shop use an cylinder boring bar and hone to do the cylinders and a line boring machine to do the main journals if needed. Even the facing is done on specialized machines.
The only standard machine tool my engine builder has is a Bridgeport. It has a special fixture that is motorized to turn a crank and accelerometers measure unbalance of the crank and tell you where and how much to remove to achieve balance. Again, not a home shop piece of equipment. Its is literally being used as a drill press with precision X axis moves, No really milling done.
