'06 Charger Shifter Locked
larry_g
oregon
My son's '06 Charger will not release the shifter out of Park. When you hit the brake you can hear the solenoid in the shifter click but it does not release the lock allowing the shifter to move into drive. His research says that there is a plastic part in there that breaks. It has the Hemi motor is that makes a difference.
So to the brain trust here; Is there an easy way to get this shifter to move so that we can get it into the shop for repairs? Or are we going to have to remove the console and fix it out in the weather?
Thanks in advance
lg
no neat sig line
DirtyJersey
Manually shift the linkage at trans?
Is there a hole/covered hole on shifter plate? You can slip a flathead in there and shift through all the gears.
Sent from my LG-D801 using Tapatalk
ChevyEFI
Phoenix, AZ
I can't speak for the Charger.
But I found 2002 GM pickups amazingly easy to put into neutral from underneath.
Be safe.
CatSplat
Alberta
Yep, classic Pink Thingy failure. I pre-emptively replaced the one on my Magnum with a Dorman unit just in case. You can remove the console trim around the shifter and manually actuate the thingy until you get it fixed.
lakeroadster
Central Colorado
Your vehicle owners manual tells you how to disengage the shifter lock.
On our '07 Jeep there is a slot near the shifter that you push a screwdriver into.... just as discussed in the long winded You Tube video above.
Also good to know when your battery dies and you need to move the car.
CatSplat
Alberta
Sadly, the shift interlock described in the manual that can be accessed via the console slot is not the one that typically fails on LX-platform cars. The reasonably accessible one is the Park interlock, and indeed can be handy in some situations where you need to release the parking pawl. However, the item that has failed on the OP's vehicle is not the Park interlock, but the secondary interlock that allows you to shift into a drive gear once the Park interlock has been disengaged.
