1/2 drive.... how important
bratwurst
Wa state
I really want to know how necessary you guys think having 1/2" ratchets and sockets are.I personally use 3/8 most of the time.
Packard V8
Spokane, WA
Random comments:
What do you work on? Try telling a Cat mechanic 3/8"drive is all he needs. Try finding a motorcycle/snowmobile tech who ever uses 1/2".
The trend toward using 3/8"drive in impacts and on larger fasteners where 1/2"drive was the last century norm has caused the tool truck guys to have to replace many more 3/8"drive sockets than they did last century 1/2"drive.
The trend for automotive industry to use smaller higher strength metric fasteners has made it possible to use 3/8"dr where 1/2"dr would have been necessary in the past.
jack vines
danb35
SE Georgia
For automotive work, I use 3/8 drive most, 1/2 drive occasionally. For home stuff, 3/8 drive will be most versatile, though you could do a lot with 1/4 drive. When I was doing work on an airplane, almost everything was 1/4 drive.
lowside67
Vancouver, BC
As an automotive hobbyist, I could get by without a single chrome 1/2" socket - just retaining my 1/2" impact sockets for use with my electric impact. I use 3/8" most of the time I am using a ratchet.
-Mark
General Geoff
Allentown, Pennsylvania
I use 1/2" drive on everything from my motorcycles to my truck. Lug nuts, axle nuts, steering/suspension stuff like ball joints, they all require (or at least are best served by) 1/2" drive. And they're not all easily accessible by impact, so I do use 1/2" ratchets and chrome sockets/extensions regularly as well.
You don't strictly need chrome 1/2" sockets or extensions, though. Impact sockets/extensions work just fine with a ratchet and torque wrench as well.
Pig_Pen
You need 1/2” if you’re going to be doing any suspension work.
Tallpilot
Orlando
The 1/4" T72 series from Snap-on has a 90 ft/lb proof torque. Tekton is claiming 240 on their 3/8 stuff and 560 on 1/2. That is a huge increase from last generation's tools.
As someone mentioned in another thread it has almost obviated the breaker bar. Being able to size down has also made working in crammed engine bays easier without disassembling everything in your way.
It is more comfortable working with 3/8 all day since everything is lighter. But once the handles start flexing I like to go up a drive size even though I know the tool can handle it.
Like most things you can wait until you need it if you are just starting out and funds are tight.
gtsgarage
California
I just posted a “recommend a ratchet” thread this week. I was originally looking at a 1/4”, 3/8” and 1/2” combo. I decided to just get 1/4” and 3/8” because with 1/2” the stuff I have works well and things like smoothness and refinement don’t matter as much with a bigger ratchet.
I actually just bought a master set of 3/8” impact sockets that I do think are a bit of a game changer with the 3/8” impact guns now available.
Fedwrench
Valley of the sun
It all depends on what you work on. I use 1/4 & 3/8 drive far more often than 1/2 drive but, when you need 1/2 drive, you need it. I do believe that when you're using 1/2 drive, you can get by with impact sockets but, that's just me.
65k10
somewhere
Depends what you are working on. I use 1/2 drive very often when working on farm equipment. Sometimes it's because I need the strength the drive tools provide, but usually I have the clearances to use 1/2 drive and if I'm working away from the shop, it's just handier to grab a small hand carry box loaded with wrenches and a 1/2 drive set. The small amount of vehicle work I do, I'm generally happier with 3/8 or 1/4 drive. Still, 1/2 drive is handy at times on a vehicle and I'd want at least a basic set.
Wamsutta
Amarillo, Texas
The 1/2" drive ratchets are more important than the sockets because to can always step down to 3/8" drive sockets. You need the big ratchets for leverage sometimes.
LX-Markham
Markham, Ont.
If you're getting by using a 3/8" drive for the jobs you're working on, stick with the 3/8".
Most of my ratcheting is on my car, so it's 1/2" drive for me. Just changing tires is probably 90% of 1/2" usage.
gdudik
A lot of it depends on whether I find the right size in 3/8” or 1/2” first!
mcj115
Hershey PA
Am I the only odd ball that for homeowner use has 3/4 sockets and impacts and uses them? I needed to change an axle(CV) on my Accord a couple of weeks ago and need the bigger stuff.
vavet
Ashland, VA
I have a single 3/4 socket in my toolbox. I bought for ball joints on a 95 Ford F150 4WD. I bought a step down adapter to go with it so I can use that 3/4 drive socket with a 1/2" drive tool.
I wrenched on many cars and light trucks. Never had any other need for a 3/4 drive set. I saw plenty of them when I was in Army motorpools, though.
bustedcrawler
Denver
Nope, I have a 3/4" set and it get used plenty. Need to do a wheel bearing or axle joints on my 3/4 Ton dodge... for example, that set has the size I need. Same with some of the ball joint set's I've done in the past, that set has been handy.
Zewnten
I use 1/4 for interior work, 3/8 for the majority, and 3/4 for the heavy. Usually it has been my experience that if my 3/8 won't move it the half wont either. Aircat rates their 3/8 impact gun for a 1/2 bolt, their 1/2 for a 9/16 bolt and their 3/4 for 1" bolt, no point to half inch sockets that I see.
Psychwarfare
As an auto resto enthusiast and hack...I probably use:
1/4" - 10%
3/8" - 60%
1/2" - 30%
The extra oomph is often needed for fasteners that succumbed to the elements or simply haven't been touched in years.
1/2" ratchet, impact socket(s), 6' small diameter steel pipe (black job with orange ends from HD) is about the most I've ever needed for bearing/axle work on a Jeep and smaller vehicles.
Wouldn't mind a 3/4" ratchet...just to have...haha
Mr Ratchet
3/4" impact is overkill for most auto tech's let alone most homeowners. Having said that, I do own a complete set 3/4" chrome. I can break loose fasteners with my 3/8" 18" breaker, my 1/2" 24 breaker or 3/4" 40" breaker. It's far safer to use the big one if space is available but, no room for my impact.
visionguru
Chicago
1/2" drive is a must for suspension work or bolts larger than 17mm (head).
For people who have 1/2" and 1/4", 3/8" is not essential. But if you have 3/8", you still need 1/2" and 1/4" stuff.
shirk
North Vancouver, BC
I just bought all new sockets and ratchets and skipped 3/8.
For me working on a newer vehicle at home it's been brakes and suspension and the 1/2 is needed for the 20mm and 22mm bolts.
The other thing is my new 1/2 ratchet is a Facom and it's a bit shorter and lighter than some of the other brands 1/2 ratchets so it doesn't feel as big in the hands.
gtsgarage
California
I have one 3/4” socket and a half to 3/4” adapter. Seemed to work fine but cranked on it. Used it to attach a pitman arm.
GirlnAgarage
Texas
Very.
1/4", 3/8" and 1/2" are essential for maintaining a well-rounded household.
My truck's lugnuts alone require it - 15/16" @140ft lbs.
KWtech90
As a HD truck and equipment mechanic I find 1/4 3/8 1/2 3/4 and 1 inch drive all to be necessary, however I will say 3/8 is my most used drive size followed closely by 1/2 inch. The only reason the 1/4s ever get used is because it's so convenient to have a complete boxed socket set no larger than a book especially when working inside of the cab.
AA/FC
It's kinda like asking how important is it to have a set of SAE tools... In my opinion, YOU don't get to decide which tools to own. The fastener decides which tool is required. If 3/8 drive tools are not large enough without putting a cheater bar on the ratchet, then you need a 1/2 drive set. Simple. And really, why WOULDN'T you want a 1/2 set? This is Garage Journal, most guys a LOOKING for an excuse to buy MORE tools, not for a reason to own less. lolol. I have tools in my box that haven't been used in 10 years but I wouldn't consider getting rid of them for ANY reason. Sure as ****, as soon as I got rid of something, I would need it a week later. lol
Good luck.
ChrisLS8
For the maintenance on my 3 cars I literally only need 1/2 inch for axle hub nuts. Everything else can be done with the two smaller sizes. Hell almost all the bolts including suspension bolts I can do with my Milwaukee 3/8 stubby.
What a time to be alive
danielbuck
as everyone else stated... depends on what you're working on.
I work on my jeeps and F250 truck, all 4wd. And occasionally my friend's jeeps/trucks. I use 1/2" for most things, and 1/4" for the rest. I find myself using 3/8" less and less. I don't know where the breaking point for 1/2" going up to 3/4 or 1" is, but for most passenger vehicles & trucks, 1/2" is probably sufficient. I imagine once you get larger than 1-ton vehicles, 1/2" might start to seem small.
Any 4wd vehicle I would say 1/2" is probably a good thing to have, especially for stuff like pinion nuts, suspension, steering. most things are larger on offload vehicles.
GerMec
Working 95% of my time on motorcycles and all I need is 1/4 and 1/2. 1/2 for everthing like frame, swingarm, axles, engine mounts...
But I have to admit 3/8 is not the most common size here
Tonyuk
Scotland
Most of my impacts and impact sockets are 1/2 drive.
Most of my hand tools are 3/8 or 1/4
bonneyman
Desert SW
1/2" and 1/4" are all I use unless there is a need they don't meet.
That's when you call me....cause almost all I use is 3/8" drive!:lol_hitti
Although having a set of 1/2" drive impacts and a nice impact gun would probably be a good thing to have around the shop.
txvwnut
Bedford, Texas
This is the Garage Journal, while it may not be necessary to have a certain size drive of ratchets and socket your required to own all drive sizes.
